11-18-2015, 01:01 PM | #1 |
Rep 3,129
Dinan N20/N55 Intercooler & Stage 3 Now Available!
Part Number: D330-0021 - Dinan High Performance Dual Core Intercooler for the BMW F22 F23 228i, F30 F31 F34 328i, F32 F36 428i, F22 F23 M235i, F30 F34 335i and the F32 F36 435i. (see note below for exact application limitations) Labor Time: 2.0-4.5 hrs (depending on required bumper modifications) Details and Pricing: Consult www.dinancars.com. Greater power gains are achieved with a larger high performance intercooler. The Dinan dual core intercooler provides more than a 2x increase in total volume and surface area, substantially reducing the pressure drop to 0.8 psi, as well as providing for more efficient heat exchange and more consistent output power. Dinan's unique dual core design allows 2 separate cores to be working in conjunction with one another at all times. This doubling of resources is directly responsible for a 60% improvement in the delta from charge air temperature to ambient temperature (See diagrams below). "Cool down" time is also reduced, enabling the cars to produce full power under varying driving conditions such as stop and go traffic. This leaves the chances of being susceptible to heat soak nearly a thing of the past. The system has been engineered to be as direct a replacement as possible to the stock unit, requiring only minor modifications for a clean, factory-like installation. The increased thermal efficiency provided by the Dinan dual core intercooler will also enhance turbocharger reliability in addition to overall power. On a stock vehicle power gains can be had from 4000 RPM and beyond (when the car is in boost). In order to achieve the best performance however the intercooler should be paired with the Stage 3 DINANTRONICS Performance Tuner as it provides optimization of the intercooler. In particular it extends the power band to be more robust and powerful from 4000 RPM to redline whereas without tuning the bulk of the gains are from 6000 RPM to redline. Benefits of the Dinan High Performance Dual Core Intercooler:
(228i fitment only confirmed on the M-Tech bumper; STD bumper not yet tested. 428i fitment only confirmed on the M-Tech bumper; STD bumper not yet tested. 435i fitment only confirmed on the M-Tech bumper; standard bumper not yet tested.) F30 335i M-Tech bumper fitment may use an optional fascia kit to ensure intercooler installation is visually seamless. Dinan P/N D333-0025 Intercooler does not fit vehicles equipped with Active Cruise Control. The intercooler has not been fit checked / tested for certain combinations of bumpers / car variants. As testing is completed the application list will be extended to include further vehicles / variants. The intention is that this intercooler should fit every 2/3/4 series vehicle with exception of the F33 435i Convertible which has some additional bracing that makes compatibility impossible. With the release of the new Dinan dual core intercooler the stage 3 DINANTRONICS Performance Tuner is now becoming available for applicable models. This stage of tune is specifically designed to optimize the intercooler efficiencies. With its main purpose to extend the increased power band throughout the entire boost rev range, not just the upper RPM spectrum as what naturally happens without the tune and just the intercooler. What this means is that a more linear and extended power delivery can be achieved to go along with the dual core intercooler's inherent temperature and pressure advantages. Upgrades from previous stages of DINANTRONICS are simply the difference in price between stages. There are a few different performance data set numbers listed below depending on application and other factors. Please consult the Dinan website for specifications on your particular model / variant. DINANTRONICS Performance Tuner for the F22 / F23 M235i, F30 / F34 335i (w/ MPPK, Auto Trans.) & F32 / F36 435i (w/ MPPK, Auto Trans.) ONLY applicable to cars equipped with an electronic wastegate. Part Number: D440-1641-ST3 Applications: DINANTRONICS Performance Tuner for the F22 / F23 M235i, F30 / F34 335i (w/ MPPK, Auto Trans.) & F32 / F36 435i (w/ MPPK, Auto Trans.) ONLY applicable to cars equipped with an electronic wastegate. Install Time: 1.5 hrs BMW Factory Ratings: 320 HP, 330 lb-ft torque (326 HP, 379 lb-ft Measured) With DINANTRONICS Tuner, Dinan Exhaust, CAI, and Dual Intercooler: 399 HP, 455 lb-ft torque Part Number: D440-1641-ST3 Applications: DINANTRONICS Performance Tuner for the F30 / F34 335i (w/ MPPK, Manual Trans.) & F32 / F36 435i (w/ MPPK, Manual Trans.) ONLY applicable to cars equipped with an electronic wastegate. Install Time: 1.5 hrs BMW Factory Ratings: 320 HP, 317 lb-ft torque (327 HP, 353 lb-ft Measured) With DINANTRONICS Tuner, Dinan Exhaust, CAI, and Dual Intercooler: 401 HP, 436 lb-ft torque Part Number: D440-1639-ST3 Applications: DINANTRONICS Performance Tuner for the F30 / F34 335i & F32 / F36 435i ONLY applicable to cars equipped with an electronic wastegate. Install Time: 1.5 hrs BMW Factory Ratings: 300 HP, 300 lb-ft torque (315 HP, 330 lb-ft Measured) With DINANTRONICS Tuner, Dinan Exhaust, CAI, and Dual Intercooler: 395 HP, 417 lb-ft torque Part Number: D440-1631-ST3 Applications: DINANTRONICS Performance Tuner for the F30 328i ONLY applicable to cars equipped with a mechanical wastegate. Install Time: 1.5 hrs BMW Factory Ratings: 240 HP, 260 lb-ft torque (268 HP, 287 lb-ft Measured) With DINANTRONICS Tuner, Dinan Exhaust and Dual Intercooler: 323 HP, 336 lb-ft torque Part Number: D440-1640-ST3 Applications: DINANTRONICS Performance Tuner for the F30 335i (w/ MPPK, Auto Trans.) ONLY applicable to cars equipped with a mechanical wastegate. Install Time: 1.5 hrs BMW Factory Ratings: 320 HP, 330 lb-ft torque (320 HP, 365 lb-ft Measured) With DINANTRONICS Tuner, Dinan Exhaust, CAI, and Dual Intercooler: 393 HP, 437 lb-ft torque Part Number: D440-1640-ST3 Applications: DINANTRONICS Performance Tuner for the F30 335i (w/ MPPK, Manual Trans.) ONLY applicable to cars equipped with a mechanical wastegate. Install Time: 1.5 hrs BMW Factory Ratings: 320 HP, 317 lb-ft torque (322 HP, 364 lb-ft Measured) With DINANTRONICS Tuner, Dinan Exhaust, CAI, and Dual Intercooler: 396 HP, 426 lb-ft torque Part Number: D440-1638-ST3 Applications: DINANTRONICS Performance Tuner for the F30 335i ONLY applicable to cars equipped with a mechanical wastegate. Install Time: 1.5 hrs BMW Factory Ratings: 300 HP, 300 lb-ft torque (303 HP, 331 lb-ft Measured) With DINANTRONICS Tuner, Dinan Exhaust, CAI, and Dual Intercooler: 389 HP, 413 lb-ft torque Last edited by Dinan_Engineering; 02-01-2016 at 01:12 PM.. |
11-18-2015, 02:54 PM | #3 |
Rep 3,129
11-18-2015, 03:58 PM | #4 |
Rep 2,210
Drives: '17 jackrabbit on crystal meth
Can the stage 3 be installed without any of the supporting mods (intake, exhaust, IC). Granted, the claimed HP/TQ numbers will be lower.
A lot of people just want the added boost!
2017 BSM M2|6MT|Exec|black kidneys and gills|full alcantara wheel|CF spoiler|Dinan Stage 4|Dinan COI|Dinan free flow exhaust with resonator delete|Fabspeed sport cat DP|BMS clutch stop|465 bhp|4.75/5 stars
retired: 2014 435xi|MPPK|335 bhp|3/5 stars |
11-18-2015, 04:07 PM | #5 |
Rep 2,639
It probably could, but you would at least want to change out the chargepipe as the higher boost will crack the OEM one over time.
11-18-2015, 04:30 PM | #6 |
Rep 2,210
yep. chargepipe, drop-in filter, MPE...done
11-19-2015, 08:37 AM | #7 |
Rep 3,129
Stage 3+ will REQUIRE, at bare minimum, the intercooler to run properly and thus be warranted through Dinan. Obviously the advertised numbers will be affected accordingly with the lack of the other components.
11-19-2015, 01:26 PM | #8 |
Rep 68
Dinan_Engineering How much to upgrade from Stage 2? I'd obviously add the intercooler as well.
Currently have Stage 2 + Dinan CAI + MPE
2012 E93 M3 Convertible - BMW Individual - Azurite Black Metallic/Rust Brown - MPE - Dinan Software and Intake
11-19-2015, 02:17 PM | #9 |
Rep 3,129
11-19-2015, 02:23 PM | #10 |
Rep 66
One of the keys to that dual core intercooler is ducting ...and another is air flow management, so that air from one core isn't used to cool the other. From the airflow diagram, it appears you've accomplished this, and I'm sure you guys engineered the ducting to feed each core accordingly ...very clever.
Great work. |
11-19-2015, 02:45 PM | #11 | |
Rep 68
11-19-2015, 04:20 PM | #12 | ||
Rep 3,129
The only real downside is that due to the nature of having 2 cores the physical size means there is some bumper / brake duct trimming involved. This is part of the reason why we do not list it as compatible with all variants yet. There are simply too many variants (86 total to be exact) that need to be physically tested and instructions written due to the fact that trimming for all those variants will differ. |
11-20-2015, 07:07 AM | #13 | |
Rep 377
Also, do you guys install dinans in HQ? |
11-20-2015, 11:40 AM | #14 | |
Rep 3,129
The Track Handling Package is just a suspension upgrade. It does not affect the stock cooling and the intercooler. The intercooler can not be installed with active cruise control on the car since the sensor is directly in the way of the intercooler. In past generations we have had people relocate the sensor although we don't support that as the sensor is based on certain operating distances and moving it alters that. We have not had anyone try that with the new one though. Uncharted waters. That said, stage 3 requires an upgraded intercooler (ours specifically, as we don't know how others would perform given the disparity between our setup and others) so stage 3 would not be available without it. Can you force stage 3 on a car without the intercooler...sure. You just would not be warranted through Dinan without our intercooler installed is all. Not to mention the drivability in the upper RPM range would be suspect. As far as numbers go for that scenario, I really couldn't say since we never tested it in that configuration although torque being the same as stage 2 is basically guaranteed. For the future, stage 4 with the big turbo will also REQUIRE the use of the intercooler. |
11-20-2015, 01:59 PM | #15 | |
Rep 377
11-26-2015, 01:01 PM | #16 |
Rep 2,411
Drives: E30 M3 Cecotto, F85, G05, G07,
Im very interested in getting this for a F31 328i xDrive Wagon - when will the stage 3 sw be released? When will you test fit this on a M-tech bumper?
11-27-2015, 09:49 AM | #17 |
Rep 6,478
V impressive pressure drop (or lack of, I should say) for a twin core like that.
Would you be willing to disclose the core manufacturer? I don't doubt the quality for a second w/ DINAN products, just curious more than anything. Garrett? Nicely done!
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
11-28-2015, 08:15 PM | #18 | |
Rep 2,639
Do you guys know the ETA on the 2013 335i xdrive/msport/MWG/MPPK version? |
11-30-2015, 09:57 AM | #19 | |
Rep 3,129
12-13-2015, 08:32 AM | #20 |
Rep 365
I have a 2014 335 with signature package stage 2 exhaust intake and all the other goodies. Having stage three and inter cooler installed this week. Should I be concerned about the factory charge pipe? Everything on car is Dinan except for downpipe is AR design. Car is a beast.
Thanks |
12-13-2015, 01:50 PM | #21 | |
Rep 163
'14 Dinan4x /// BUILD THREAD
'25 X5 x40i /// Oxford Green on Extended Tartufo | M Sport Professional | Executive Package | Parking Assistance Package | Climate Comfort Package BUILD STATUS 111 |
12-13-2015, 01:58 PM | #22 | ||
Gettin It Figured Out
1820
Rep 2,669
and Diverter Valve...replace with GFB DV+ .
