09-24-2016, 06:16 PM | #1 |
Rep 22
N55 GFB DV+ Installation
Has anybody done this install on the current N55? I've seen great instructions for the N20, but none for the N55. I am going to do my intercooler, TIC pipes, and charge pipes soon and figured it might be easier to access it at the same time.
2014 BMW 435XI w/ MT - Injen Intake - BMS JB4 - Wagner Tuning HFC DP - Wagner Performance FMIC - ER Chargepipes
09-25-2016, 11:39 AM | #3 | |
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
FBO-PS1 and stuff
09-25-2016, 08:15 PM | #4 |
Rep 71
09-25-2016, 08:29 PM | #5 |
Mike: Everyone's Pal
2044
Rep 2,972
Drives: F80 M3
review? Im really thinking about this.
Alpine MSS Stage 2+ E30 tune|MST Intakes|VRSF Single Mid Pipe|Agency Power Intercooler|VTT Full solution crank hub fix |
09-26-2016, 12:42 AM | #7 | |
Dejan
1753
Rep 4,197
The oem breaks especially the diaphragm when pushing higher boost so if you mod and push above 19-20 psi this is a must.
FBO-PS1 and stuff
09-26-2016, 01:23 PM | #8 |
Rep 190,805
Good to know that people have tried it with ER CP and it fits
Jadar1752.50 |
09-27-2016, 02:34 PM | #9 |
3441
Rep 79,211
We've sold dozens and dozens of these units. For those who came forward they've noticed increased throttle response. Otherwise were leaking boost and they never knew.
For a brand new vehicle, it's likely not worth it, yet. Once these cars get some mileage on them the stock DV is weak. |
10-01-2016, 05:37 PM | #10 |
Rep 22
Went to do it today, but I was only able to get my chargepipe and intercooler installed. I still have the stock TIC chargepipe...even though I am in possession of the ER one, and I didn't even attempt the DV+. I can tell you that this is near impossible with the x-drive model, which is what I have. I spent a good 1.5 hours f'ing around with the lower t-clamp on the chargepipe...what a pain!!
10-01-2016, 05:40 PM | #11 |
Rep 22
I am assuming you have RWD? After being under my car today for intercooler and chargepipe install...it is essentially impossible to access the diverter valve without a full day of dropping everything out of the way.
10-02-2016, 09:08 AM | #12 |
@obriennathaniel_f30 on Instagram
515
Rep 1,063
Drives: 582whp/596wtq '13 335i
ooooo, I didn't know you were x-drive....not sure how well my instructions will help you.
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| |
10-02-2016, 08:07 PM | #13 |
Rep 71
11-16-2017, 05:21 PM | #14 |
Rep 58
I installed mine yesterday on a 2014 Xdrive 335i, what a royal pain in the ass. I'm a Audi dealer technician, and with a wide array of tools, this took about 2 hours. Most of this was spent trying to get an angle on the hex head bolts.
To remove the top bolt I had to go from the front fan shroud with 3 wobble extensions and a ball head hex 5mm. What makes it worse is that all these bolts corrode in the turbo housing, which means you cannot spin them out by hand. Unless you have a lift, I'd say don't attempt this. I don't see a RWD car having much more room. The install process was a little easier, I put vaseline on the threads of all the new supplied bolts, and was able to get 2 out of 3 in by hand. |
11-16-2017, 08:02 PM | #16 | |
Rep 547
2014 435i xDrive M-Sport, Fabspeed cat, Active Autowerke axle back, CTS Turbo intake, ER charge pipe, ER Competition Intercooler, MHD Tuning Stage 2+
11-16-2017, 10:49 PM | #18 | |
Rep 547
05-08-2018, 11:30 PM | #21 |
Gettin It Figured Out
1820
Rep 2,669
BMW DIY Guy3074.00 |
05-11-2018, 11:57 AM | #22 |
Rep 3,022
Drives: 2019 M2 Competition
Yup.. I did the full install DIY and will take some time but isn't hard to do.
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
