06-08-2019, 11:18 AM | #1 |
Rep 3,033
Drives: 2019 M2 Competition
BMW DIY Guy F32 435i build out thread
Hey all!
I figured I would start a full build out thread on my car so far, though deep into the process now rather than from the beginning. I moved from my E46 M3 convertible as I was just tired of the 30k valve adjustments, though I had heavily modified the car and really loved it. The change to a grey F32 coupe was dramatic and I really loved the car when I brought it home.. but now.. just woah now.. that (seemingly) tame bland car is anything but that now! Oh the changes over the last two years! As if 1/21.. she is sold but will live on forever for me for the most mods I have ever done, the most learned, and the incredible growth this car brought to me. What an amazing car when she came home and was a MONSTER when she went onto the next owner. Full build out as of 8/2020 440rwp 454torq as of 1/2020 Full Build out video series is available Part 1: Power Part 2: Handling Interior modifications Karbonius Carbon fiber interior AvinUSA 10.25'' 10.0 android display - updated 3/20 to android 10.0 Inbay QI Wireless charger //M Performance Parking brake //M Performance gear shift knob and boot //M Performance Alcantara arm rest (installed 3/20) M Sport steering wheel LCI lighted center console Bimmertech Alpha One speakers - full set Alpine MRV-M500 amplifier BMW OEM 6WB gauge console Headlight control trim (4/2020) AmbientModz frosted light tracks (rear) (5/2020) AmbientModz frosted light tracks (updated front) (6/2020) Exterior modifications M sport exterior kit - full kit Carbon fiber M style mirror caps Tricolor blacked out kidney grills LED backup and brake lights Sequential LED mirror turn signals Carbon Fiber GTS Hood LED foglights OEM 19inch 442m wheels (1/2020) Carbon Fiber CS style trunk lip from Kies Motorsports (5/2020) 12.5mm front spacers (5/2020) 15mm rear spacers (5/2020) ///M Performance carbon fiber front lip from Kies Motorsports (8/2020) ///M Performance carbon fiber door sills (OEM) (10/2020) Carbon Fiber rear diffuser from Kies Motorsports (11/2020) Carbon Fiber side skirt extensions from Kies Motorsports (12/2020) Performance modifications Active Autowerke charge pipe VSRF FMIC intercooler Bootmod3 Custom Tune by Cary Jordan Active Autowerke catback exhaust Wagner HF catted downpipe Ignition Projects plasma coils CTS Turbo Billeted oil filter cover NGK 97506 spark plugs gapped to 0.20 Burger Tuning Oil Catch Can TuningTechFS XDI-35 HPFP upgrade (installed 8/19 and WOAH!!) KC Design Front and Rear shock tower struts (installed 8/19) KC Design 17mm solid Rear Sway bar (installed 8/19) Powerflex USA rear subframe and differential bushings (installed 8/19) I KC Design 28mm solid sway bar (installed 9/19) Bilstein B16 PSS10 coilover kit (installed 9/19) Mosselman Turbo Systems Oil Thermostat upgrade (installed 11/19) R1 Concepts drilled slotted rotors and pads (installed 11/19) Powerflex front bushings (installed 1/20) Spec2+ clutch rated to 545hp (installed 2/20) CDV delete (2/20) Pure Turbos Full inlet pipe (installed 3/20) TurboSmart BOV (installed 3/20) M Sport/Performance brake kit (red calipers and 370/345 rotors) (3/20) Stainless steel brake lines (3/20) CSF high performance radiator and fluid flush (4/2020)
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread Last edited by BMW DIY Guy; 01-21-2021 at 10:17 AM.. |
06-08-2019, 11:19 AM | #2 |
Rep 3,033
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
Silverlining_m21743.50 |
06-08-2019, 11:24 AM | #3 |
Gettin It Figured Out
1823
Rep 2,669
1. About damn time you put up your build...
2. Link to your hood please.... .. also your thoughts on fitment and quality .
BMW DIY Guy3088.50 |
06-08-2019, 11:30 AM | #4 | |
Rep 3,033
I dont have an easy link for the hood as I spent like 2 months backtracking from an Aliexpress link (and a ebay listing that looked identical) in China. I finally found the manufacturer but they dont have a website for customers, as they dont normally deal direct. I bugged the @#$!#$!# out of them for a month and they agreed to work with me. fitment and quality.. Absolutely fantastic so far! There is a little more adjusting I need to do, and will likely drill out the hole spots for the washer fluid snap in posts (very common I hear on after market CF hoods, that you drill out what you want to have, so you can customize). Looks great, and I am leaning towards my partial painted idea more and more.
06-08-2019, 11:37 AM | #5 | |
1823
Rep 2,669
Solid idea, I'd also recommend converting your receipts to PDF to easily upload to adjuster if ever needed *knocks on wood If you ever come across a link...post it up please! . .
06-09-2019, 10:27 AM | #6 |
BMW CCA Member
490
Rep 808
So... suspension items... looking stock there. That coming?
And the LSD... you pull the trigger on the Auto version and going to modify or bit the bullet and went the manual? |
06-09-2019, 10:35 AM | #7 | |
Rep 3,033
Suspension though and a BBK is on my radar. The LSD is the auto model if it can work, and have one on order. I saw that one report back of it not working in a 6MT like mine, but hoping for more reports before mine arrives. I will cancel and save up for the proper one if so.
06-11-2019, 08:53 PM | #8 |
Rep 191,109
06-11-2019, 10:00 PM | #9 |
Rep 3,033
Thanks Mike! I am already missing it with my OEM back on while at the paint shop.
06-16-2019, 02:42 PM | #10 |
Rep 3,033
GTS hood is off at the paint shop, but since I had the tools out for exterior detail on the X5, might as well do the F32 as well.
orbital buffer for the win!
wdeerfield2754.00 |
06-16-2019, 07:00 PM | #11 |
A family of bimmers
2754
Rep 7,743
Car looks great! Have watched your videos. They are a great help to us enthusiasts. Wheels and a drop and the car will be done! Only thing I don't like are those grill stripes. If you are going to have the cca badge I'd lose the stripes to clean it up some. Looking forward to what you have in store next. Painted hood was the right move.
06-16-2019, 07:04 PM | #12 | |
Rep 3,033
The stripes.. yeah.. more of a nod to the M3 I traded in than anything else. Plus mineral grey is WEIRD for me, normally I am red or yellow. So just adding a dash of color. Thanks man.. doing my best to give back to this awesome community.
07-06-2019, 06:29 AM | #13 |
Rep 368
Hood update bro?
07-06-2019, 09:09 AM | #14 |
Rep 3,033
07-06-2019, 09:11 AM | #15 |
Rep 3,033
the GTS hood is back, painted and installed! I couldn't be happier!
07-06-2019, 11:01 AM | #16 |
Rep 681
Looking good! You need a drop and wheels soon! It'll really complete the look I feel. Really digging the GTS hood too; bummer they're pretty tough to get one-off haha
2016 328ix F31 - SOLD!
2006 997.1 C4S |
07-06-2019, 11:05 AM | #17 |
A family of bimmers
2754
Rep 7,743
I like how the hood turned out. Very creative and well done leaving that section exposed
07-06-2019, 11:27 AM | #18 |
Rep 3,033
I agree on suspension.. I can get more of the hoods. ig interested shoot me an email at bmwdiyguy@outlook.com asap.
07-21-2019, 10:49 AM | #19 |
Rep 3,033
its here!!! Install will be in two weeks!
disintegrator66426.00 |
07-28-2019, 06:45 AM | #20 |
Rep 368
07-29-2019, 09:16 AM | #22 |
Rep 3,033
Sadly no.. the auto LSD will not work in the manual cars and was confirmed. Huge bummer candidly, as I read about the massive difference it makes.
