BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > iPhone X iOS 12.1 and '14 F30 NBT NAV Bluetooth Issue
      12-02-2018, 08:31 PM   #1
ask007
Drives: 2014 F30 328i xDrive
Hi Everyone,
Newbie here - I'm hoping that I'm able to find some help on the forums!
After upgrading my iPhone to the latest software, I noticed that the Bluetooth started sounding odd. At one moment, the audio will sound perfectly fine. The next, the highs in the audio will sound muffled for about 30-60 seconds and then go back to normal.
The issue doesn't exist when it is plugged in directly over USB. I've tried YouTube, Deezer, Spotify, Waze w/ Spotify, Apple Music and it's consistent across apps.
I recently upgraded to iOS 12.1, so maybe that is a contributing factor here?
Looks like others are having similar issues across car manufacturers as well. Unfortunately, I don't have another Bluetooth device to test with that isn't an Apple Product.
https://community.spotify.com/t5/iOS...2/td-p/4572223
Anyone else having this issue? Any help would be greatly appreciated!
Details
2014 328i NBT NAV HiFi (Latest Firmware)
iPhone X 12.1 Bluetooth connection
      12-05-2018, 03:12 PM   #2
IAmATeaf
IAmATeaf's Avatar
Drives: 2015 F30 335i
2015 BMW 335i  [0.00]
My 8+ connects but I get no audio over Bluetooth, been playing around with it for the last few days. I’m also on 12.1 but I’ve just this minute upgraded to 12.1.1. Another issue is that I used be able to get Waze to play through the phone speaker but take/make calls via Bluetooth, this no longer works and Waze no longer remembers that I had set it to audio through the phone speaker. Waze always now starts and diverts the audio to Bluetooth but I get no audio at all.
      12-06-2018, 07:45 AM   #3
Somebloke
Annoyingly, since iOS 12 my phone does not connect automatically with bluetooth. I need to toggle airplane mode on and off for a few second before it will connect.
      12-06-2018, 11:40 AM   #4
IAmATeaf
IAmATeaf's Avatar
Mine connects but I get no audio at all.
      12-08-2018, 08:12 PM   #5
ronanz
Gettin It Figured Out
ronanz's Avatar
Drives: 435i FBO PS2 bm3 w/ options
Curious...have you tried removing, then re-pairing?
My Build Thread can be found HERE
      12-08-2018, 09:17 PM   #6
ask007
I haven't tried this yet. I'll try tomorrow and reply back with my findings.
      12-09-2018, 04:45 AM   #7
IAmATeaf
IAmATeaf's Avatar
I had to remove and then re paired to get it to reliably connect but still can’t make calls using the cars sleaker and mic, really boiling my urine as I’ve tried loads of things.
      12-11-2018, 12:26 PM   #8
ask007
No luck with re-pairing to the car. I tried deleting all of the devices on my phone and the car and then reconnecting.
      12-11-2018, 12:27 PM   #9
ask007
When you connect, does it give you an option to select your telephone 1/2 and audio? I had to check the top telephone 1 box and audio box for mine to work.
      12-11-2018, 01:48 PM   #10
IAmATeaf
IAmATeaf's Avatar
Telephone 1 is selected, will have to recheck the audio though I’m sure I’ve stared at that screen many times.
      12-21-2018, 06:14 AM   #11
DaveKizie
Drives: 2012 320d sport
Hi all newbie here just got 2012 320d sport and when connection IPhone X it says not supported
Bluetooth works fine for calls but unable to play music
I checked for updates and it says vehicle is up to date
Any advise on playing music via usb from phone and if possible controlling from ideive
      12-21-2018, 07:27 AM   #12
IAmATeaf
IAmATeaf's Avatar
You probably don't have Enhanced Bluetooth which you need to stream music over BT.
Have a look in the coding section, you might be able to code it yourself?
      12-21-2018, 07:29 AM   #13
IAmATeaf
IAmATeaf's Avatar
I've now upgraded my 8plus to 12.1.2 and still can't get audio to work over bluetooth. I've checked within options and I have Telephone 1 and Audio ticked.
      12-21-2018, 07:37 AM   #14
DaveKizie
I do t want to stream via Bluetooth just via usb
      12-21-2018, 07:58 AM   #15
TheJungatron
TheJungatron's Avatar
352
Drives: 2020 M340i RWD- USA
Same thing, Plagued with issues. My amazon music app now causes errors and won't work properly.
I ended up unpairing and repairing and hard reseting my phone and it seemed to make things ok for the time being.
2015 335i NBT Nav
      12-21-2018, 09:28 AM   #16
KTE
Drives: A slow car
Not entirely relevant, however since upgrading my iPhone 7 to a XS the initial startup connection time has more than doubled. By the time the initial burp note of the exhaust was finished being loud it would’ve continued playing.
Same operating system on the device. Will update to see what happens. 12.1.1 at the moment.
Now it takes 30+ seconds, slower than a aftermarket stereo I had fitted in my previous hatchback!
2014 - EntryNav
      12-21-2018, 09:59 AM   #17
XxThe_RemedyXx
XxThe_RemedyXx's Avatar
967
Drives: 2016 340i xDrive
Try updating your iDrive to the latest BIN:
https://f30.bimmerpost.com/forums/sh....php?t=1564263
      12-21-2018, 10:15 AM   #18
valve float
Drives: b6 a4 avant 6sp, e90 M3 6sp
^this ... i was having zero connectivity with my new XR ... updated iDrive s/w via usb stick ... FIXED...!
      12-21-2018, 10:32 AM   #19
IAmATeaf
IAmATeaf's Avatar
I've already updated to to the latest it used to suggest for my car but no joy. I'm going to try with my wife's 6S to see if it is the phone itself?
      12-21-2018, 10:48 AM   #20
cfm56d7b
I had the same problem. Unpairing and repairing plus upgrading iDrive software via USB (downloaded from BMW site) helped. It's not clear if step one or two resolved the problem.
Plus my navigation occasionally froze and defrosted with maps moving again. The dealer reprogrammed the vehicle bringing the software level to the latest version. This specific step is all or nothing proposition. All control modules - including NBT head unit - will be reprogrammed.
      02-05-2019, 11:04 AM   #21
Ashhong
Drives: 2014 335i
I've had this issue since the beta for iOS12, and it is absolutely the phone+iOS combo. How do I know this? I've tried every single solution you could imagine. I've gotten 2 replacements straight from Apple.
The first one I upgraded to iOS12 immediately and found that I had the same issue whether I restored the phone or started new
The second one I kept it at iOS11 and have had no issues for months.
Today I decided to say fuck it and I upgraded that phone to iOS12, setup as new phone, didn't install any apps or even restore my messages/photos. Heard the issue within 5 minutes of driving.
I am going to try everything I can think of, but it definitely seems to be an issue with ONLY the iPhone X and iOS12. I have an iPhone 6S on iOS12 and it works fine. I still need to try it on an XS. I just pray that the 11 doesn't have this issue.
audio, bluetooth, f30, ios 12.1, iphone
