04-17-2017, 08:45 PM | #111 |
Rep 272
Been a while since I posted here, life has been crazy. FINALLY got a chance to sit and do a thorough tune for my F31 LHD with Bavsound Stage 1, Bavsound Underseats, and a dedicated rear subwoofer.
Hope this helps someone out, I spent some time to take measurements and set up the time correction this time, and bypassed a lot of EQing for the mids and highs to start, as I try to not use it if possible. I think I arrived at a solid tune for all genres (I listen to many). I boosted the gain a little across the board, as I listen with the windows and sunroof open a good amount so have to compensate for extra ambient noise i suppose. Will use this one for a while and update if I make any further changes, really happy with the outcome though. Much better imaging and sound stage now that the time correction is setup. I tried to blend the rear dedicated subwoofer with the bavsound underseat woofers as well, and think I got it right this time. Depending on what kind of subwoofer setup you have (if any) you will need to adjust to suit. I would recommend starting with adjusting your subwoofer amplifier gain to blend with the rest of the tune. If anyone has some suggestions, by all means let me know. Just tried to find what sounded good to me following the tuning manual provided by the manufacturer.
2014 F31 328i xDrive - Alpine White - KW V2 - 19" MORR VS8.2 - BSW Stage 1 - BSW Under Seat Woofer - BimmerTech Amp - Infinity Kappa 100.9w/500W Mono Amp - M-Sport Rear Bumper - M-Performance Diffuser - M3 F80 Style Front Bumper
05-19-2017, 06:01 PM | #112 |
Rep 97
Just received my amp today. When installing a tune via the software, does the amp have to be connected to the harness in the car or can I install a tune from my desktop without the harness and only the usb?
05-19-2017, 06:38 PM | #113 |
Rep 142
Yes you would need to have it plugged into the car because it needs to be powered on. Not to mention how else would you be able to fine tune it if you can't listen at the same time.
05-21-2017, 01:46 AM | #114 |
Rep 2
Bavsound Stage 1 + SWS 8xi
Hi All,
Thought I'd share my Bimmertech amp tune since I haven't seen one posted for the setup in my 335i: Bavsound stage one + SWS 8Xi subs underseat. Thanks to Technic for the SWS recommendation and adapter rings. I do not have a dedicated trunk sub. I started with the Bimmertech bsw V3 tune, but mid-bass with that setup was a bit messy with the SWS speakers. Here's what's I changed: 1) Adjusted crossovers to match the lower range of the SWS's 2) Used my calibrated mic with the software to match Audiotec's default curve on each channel 3) Turned down the center channel a bit more to improve separation 4) High's had come down a lot after #2, but I liked the bimmertech's tweeter presence so brightened things back up a bit, though not as much as the original. Really happy with the definition across the range. As many have said the SWS's don't bump like a true sub down low but are otherwise great. |
faye1162.00 |
06-02-2017, 08:30 PM | #115 | |
Gettin It Figured Out
1823
Rep 2,669
Hands down the best tune on here, and my personal favorite! VERY well done sir!! . .
06-06-2017, 01:56 PM | #116 | |
Rep 272
Also, as bad as it sounds I kind of like the Active Sound if properly blended. Since this is the case, I lowered my overall gain a bit to make it sounds less fake and noticeable. I try to keep the tunes I upload at a higher gain for people that have coded ASD off. I am running the N54 sound on my N20 328i and it actually doesn't sound too horrible, sounds much nicer at WOT and high revs with an I6 sound rather than the I4. The car is daily driven by my wife, so it is nice to hear the sound when I drive in Sport/Sport+ but she doesn't hear it in Comfort. Almost like having a variable valve exhaust, haha.
06-19-2017, 01:50 PM | #117 |
Rep 4
Hi, looking for some advice for my UK spec F31 with base sound system (yes not even a seperate amp!). Have ordered the BimmerTech amp and full install kit which should arrive soon. Also looking to replace the door speakers (will replace rear with coax and front with components) and underseat woofers with something better. Need all my boot space so can't add a sub. I see lots of people using Bav Sound which I would be pleased to use too but these aren't easy to get hold of in the UK unless you import them yourself which is very expensive on tax and duty, anyone on here knows of a UK or EU importer? So another pretty much PnP solution in Europe is Blam which a lot of people seem to use over here but not seen anyone use them with this amp and don't if there's a better solution for the money? Anyone got any thoughts or advice for a BMW newby?!
Thanks a lot |
06-27-2017, 12:36 PM | #118 | |
Rep 120
Honda Accord -> Subaru STi -> E93 -> F30 + F15 -> F30 -> F31 LCI -> G31
06-27-2017, 09:16 PM | #119 |
1823
Rep 2,669
Newest (.afpx) version .
06-28-2017, 01:30 AM | #120 |
Rep 120
Sorry, i meant to ask whether 2.93 or 3.40? I read somewhere between posts, that 2.93 is more stable and majority of config files here better support 2.93. Is it no longer true?
06-28-2017, 07:29 PM | #121 | |
1823
Rep 2,669
No longer true...go v3.20 or higher for .afpx .
06-28-2017, 07:36 PM | #122 |
Rep 2,036
Any of you ever uploaded files via MicroSD card?
I have no laptop anymore and wanted to know if this was a successful option. MicroSD card reader The Micro SD card reader can be used to download firmware and software updates as well as complete DSP setup les containing all DSP settings. After having inserted the MicroSD card into the card slot of the PP 82DSP, the le will be automatically copied to the internal memory of the amplifier. While the copy is in progress, the status LED ashes red. It changes to green or orange once the process is finished.
07-25-2017, 01:09 AM | #123 | ||
Rep 43
This is for the F36 Grand Coupe with stock hifi 676 speakers and the bimmertech pp82 dsp amp. While mine is left-hand drive, I had the levels/timings match symmetrically to work with both LHD and RHD. *Update* 9/4/17 Slightly adjusted center timing more and RTA'd/revised again; most likely the final revision and removing the "car centered tune" as this one has so much more hours for refinement after learning more. Also attaching the external sub file since devil84 requested it. *Updated 1/16/18 I've been driving with the seat back further for smoother drives (my wife thought my driving was too jerky and aggressive before) so I've added some timing revision to as a new file 1/31/18 Removed the new file as the original still produces a more natural soundstage and better imaging. The original is my self-proclaimed universal stock speakers + bimmertech amp tune Last edited by foveon; 01-31-2018 at 11:48 PM.. |
07-25-2017, 08:46 AM | #124 | |
Rep 18
I will try it tomorrow and give you feedback. |
07-25-2017, 04:56 PM | #125 |
Rep 43
07-25-2017, 05:08 PM | #126 | |
1823
Rep 2,669
Could you please up load in .afpx.pdf format rather than zip (as stated in 1st post)? .
07-26-2017, 12:11 PM | #128 |
Rep 18
07-26-2017, 01:32 PM | #129 |
Rep 43
07-26-2017, 03:31 PM | #130 |
Rep 191
Drives: 2013 BMW 335i M-Sport
2013 335i M-Sport 8spA
2011 M-B GLK350 2000 Dodge Ram 2500 QC 4x4 CTD |
07-26-2017, 04:13 PM | #131 | |
Rep 43
07-26-2017, 04:49 PM | #132 |
Rep 18
