05-27-2020, 12:56 PM | #67 | |
Cheapskate
4450
Rep 4,993
Go check out the fitment on the miatas at your local autox. Everyone tries to fit the widest tire (more grip) on the narrowest wheel (weight). That'll give you an idea of what actually works. |
alohasurftoad3079.50 VAF3025.50 |
05-27-2020, 03:52 PM | #68 | |
Rep 3,189
kern4174449.50 |
05-27-2020, 05:38 PM | #69 | |
Rep 495
There are a few things to understand in regards to tire width. A WIDER TIRE:
05-27-2020, 07:28 PM | #70 | |
Rep 3,189
06-01-2020, 01:06 PM | #71 |
Rep 2,152
OG CE28N 18x9.5 +33 all around 255/40/18 Falken Azeris RT615k+ all around Rubbed in the front sometimes on full lock, no rub in the rear. -2.2 Camber all around. |
06-04-2020, 02:42 PM | #72 | |
Rep 4
Planning on lowering in the future, but yours seems quite low already! Was looking mainly at 19", but damn... plus potholes out here wouldn't be nearly as heart-wrenching haha |
06-04-2020, 04:48 PM | #73 |
Rep 821
Drives: Bmw 335i f30 N55 ( sold)
245/40/19 275/35/19 with 351M wheels for my 335.. just recently put on!
2012 bmw 335i sedan
VRSF catless DP VRSF 5? HD IC Stock intake(had open before and was sick of noise) BMS CP 550i 351m rims with 275/245 set up. No tune as of yet. |
06-05-2020, 03:03 AM | #74 | |
Rep 611
However, without lowering it will not look nearly as good as this car, as the fender gaps remain the same (and they are anyway 10 mm bigger on M Sport xdrive). |
11-28-2020, 10:53 AM | #77 |
Rep 272
The IMSA 328 is the thickest
285/30 295/30 |
oksymoroni249.50 |
11-21-2021, 03:19 AM | #78 |
Rep 17
Drives: BMW F30 328i
245/45/18 meaty tires
Running 245/45/18 all around, no rubbing issues.
Comfort is much better compared to 245/40/18, especially over speed bumps. |
11-21-2021, 07:18 AM | #79 |
Rep 98
Drives: BMW 335i xDrive
18x9 ET30 (square)
255/40-18 Conti DWS-06 Plus |
alohasurftoad3079.50 |
11-25-2021, 05:06 PM | #80 |
Rep 424
255/40/18 square ET30 on ARC8s, came down from 19s and love the meatt
//'17 F36 440i Mineral Grey
//MPPSK w/carbon tips //Apex ARC8 255/40/18 //MST intake //AutoTechnik brace |
alohasurftoad3079.50 Emerson33586.00 |
12-10-2021, 06:12 PM | #81 | |
Rep 383
01-20-2022, 10:45 PM | #82 |
Rep 2
01-24-2022, 11:13 AM | #83 |
Rep 141
I've been running 245/45r18's for over 6 years now without any issues on xDrive. Currently on some Nokian Hakkapeliitta 10 studded winter tire. As for the speedo, it's more accurate, if my HUD is showing 35mph, all the speed signs will show about 1mph lower.
2014 328i xDrive M-Sport EBII--M-Performance BBK/LSD/Aero--AA Signature Exhaust--Bilstein B6 DampTronic + Eibach Springs + H&R Swaybars + Millway Street Camber Plates + M3 Bump Stops + Dinan Shockware--Apex ARC-8 18x9.5et35+12mm Front Spacers w/Kumho Ecsta V730 275/35--FL-5/EC-7 18x8.5et35 w/Pilot Alpin PA4/Hakkapeliitta 10 Studded 245/45--BavSound Stage 1+Ghost Subs
01-25-2022, 02:03 PM | #84 |
Rep 36
Hmm I bought a cheap set of 245/45 snows on 18x8 et 30's , they rubbed at full lock in reverse on my stock f32 msport, must've been the 4mm difference in offset from the OEM 400ms?
01-26-2022, 12:07 AM | #85 | |
Rep 141
I also cannot remember, but I believe F32's have slightly worse clearance than F30's in the front.
08-25-2022, 08:21 PM | #86 |
Rep 28
08-25-2022, 08:23 PM | #87 |
Rep 28
08-25-2022, 08:31 PM | #88 |
Rep 98
I'm xDrive and replaced the stock springs/struts with Eibach 05-22 springs and Koni Yellow struts. No rubbing, however it's very tight in the front at full lock position.
