BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Fast Coolant Leak (2018 430i F32)
      09-24-2021, 01:56 PM   #1
aliensinner
Drives: BMW 430i
Exclamation Fast Coolant Leak (2018 430i F32)
Hey guys,
Hope you can help with my little dilemma. Was driving and suddenly got a coolant low stop before engine overheats message. Found out the coolant just drained completely out. Checked up top and there doesn't seem to be any leak closer to the top of reservoir or radiator or any hoses visible from up top. Put in some water to see where the leak is coming from. It's literally like a waterfall draining right out.
Got under and can't see the leak right off the bat since the car has so much plastics and insulation to remove under.
Any ideas which hose or if it's maybe the coolant reservoir tank or the reserve tank the leak is coming from? It's looking more towards the back of the engine. I have attached a picture for reference.
Thanks.
      09-24-2021, 04:12 PM   #2
Orion4
Since as you said, there is no apparent leakage visible from the top of the engine bay, your going to have to pull the under-panels to locate it. The way it is pouring out, by the pic, you have a fully ruptured hose or, possibly, a hose came off a fitting.
      09-24-2021, 05:15 PM   #3
aliensinner
Drives: BMW 430i
Thanks.
      02-14-2022, 12:18 PM   #4
430inPR
430inPR's Avatar
Puerto Rico
Drives: '19 430i M-Sport 6MT
Were you able to trace down the leak? I was just driving in traffic and all of a sudden saw some smoke from underneath my 2019 430i. I thought it was some other car but 5 minutes later as I got home I got a high temperature warning on the touchscreen. (Weirdly the temperature gauge never moved from its normal position). Let me know what you found
Current: 2019 430i M-Sport | 6MT | Glacier Silver Metallic/Black Dakota Leather | 763M wheels | DAP | HUD. Wife's 2018 Acura MDX
Past: 2013 MB C250 Coupe | 2012 MB C250 Coupe | 2004 BMW 325Ci | 2000 Toyota Celica GT-S | 1990 Miata and a whole bunch of Odysseys
      02-28-2022, 07:46 PM   #5
TwoBimmer
Drives: BMW 430i
Just had the same problem with my 2018 430i. Flatbed to the dealer. I’ll let you ‘now what it is
      03-02-2022, 08:20 AM   #6
TF07Z430i
Drives: 07 BMW Z4 3.0i roadster
I have read a common problem is the small coolant hose that runs from the reservoir to the intake manifold can fail without warning. I guess you have to pull the intake to fix it.
      03-02-2022, 06:34 PM   #7
TwoBimmer
Drives: BMW 430i
So my leak was the vent hose from the expansion tank to the cylinder head. Dealer fixed it under warranty in a little over an hour. They told it it is the subject of an upcoming recall and will be replaced again with the new re-designed part. The plastic fails under repeated hot and cool conditions. My dealer is Hendrick Southpoint in Durham NC. They are great.
      03-02-2022, 07:16 PM   #8
Orion4
Yup! That is relatively common failure. I've gone through 3 in 8.5 years. Granted I'm fairly high mileage at 177,400, so a lot of heat soaking.
      03-07-2022, 01:12 PM   #9
CoopersF15
CoopersF15's Avatar
Drives: F15 Xdrive 40e Performance
Yup I discovered this around this time last year. Complete PITA but got it fixed just before warranty ran out.
2017 F15 40i ePerformance -M Sport
      03-21-2022, 11:43 AM   #10
cfm56d7b
TwoBimmer, thanks for the details. I wonder if B58 engines are also affected by this issue.
      08-16-2022, 08:07 PM   #11
Jboowan
Drives: 2018 430i M-Package
Do you have a picture of the hose or the part number? I am experiencing the same problem
      08-20-2022, 05:14 PM   #12
Aziego
Drives: 2019 330, 2023 X5, 2023 i4
Everything is in this thread.
https://f30.bimmerpost.com/forums/sh....php?t=1889354
Call dealer, more likely than not the repair should be covered as there is a recall on the hose.
      08-25-2022, 08:03 PM   #13
Jboowan
Called the dealer and they said they were looking at the campaign and my car didn't qualify. I took it to a small shop that specializes on German cars. They said my car was leaking coolant from the oil filter housing cooler. So it will cost $1,742 - $100 military discount. I am a mechanic but I will not touch a German car so that shop it is! 🤣
      09-30-2022, 08:29 AM   #14
SaintOnge
Drives: 2019 BMW 430i
Just got this fixed on my 2019 430i - definitely a known issue at the dealer. All taken care of at no cost under service bulletin B170121
"Replace Cylinder Head Ventilation Line" Part# 17-12-9-845-173
      11-11-2022, 10:49 AM   #15
ST808
Drives: 2017 430I
same coolant issue costly repair
Same coolant issues that turned into engine damage..didn't realize how quickly the the coolant was draining... long story short- I need a new engine.
I have a 2017 430I, first time owning a BMW, converted from Benz owner. Received a recall/factory repair letter a while back indicating a possible problem with collant injection line with this model and year and to come in and BMW will fix for free. I had no indication of low coolant.
Car has just under 48K miles. I had no indication of coolant leak until last week. When light came on, I remembered the letter and scheduled for the repair. Then I bought coolant, refilled the coolant over the weekend. I drove perhaps a total of 20 miles after refilling the coolant. Over the weekend, while running an errand -less than 10 miles car went into limp mode- saying high engine temp, overheating. I pulled over waited and then re-started the engine and went home. Following day drove to the dealership, Same thing happened. Dealership called said they saw the coolant injection line issue fixed it but the overheating caused engine damage and I would need a new engine with a qoute of 21k and they would not cover it as it was out of warranty. I called BMW USA and they denied coverage as well. It is shocking to me the price tag and BMW refusal to cover. The broken coolant line is the cause of my engine damage in my opinion. I am just at a loss as to next steps and thought this community would have some good suggestions. Thanks in advance.
      11-12-2022, 09:34 AM   #16
drcc2
Drives: bmw 430i
Reimbursment?
I'm not anywhere near a dealership. Is the service reimbursed by BMW in some way if it's done at a shop other than a dealership?
      12-05-2022, 10:07 AM   #17
SAH.430GP
SAH.430GP's Avatar
Drives: 2017 430i grand coupe
This is a problem I started out with and only got worse I still have yet to find the problem…. Coolant stoped leaking but now oil leak I have a 17 430GC 80k
I’m about to give up on her tbh
      12-29-2023, 05:32 PM   #18
Charm111
Drives: BMW 430i Convertible
I am experiencing the EXACT problem you've described with my 2017 BMW Convertilble at 94, 571 miles. I just took it to the dealer on 10/24/2023 for coolant leak. They told me it was the Water Pump - I paid $900 to fix. then two months later, red engine overheating lights, I do exactly what you did. Then, ,I take it back to dealer right after Christmas thinking pump failed and they tell me its the oil filter housing and that my engine is probably no good (they are 75% sure) $20K for a rebuilt engine.
But on 10/24/2023, I asked if there were any recalls or known problems. they could've replaced the darn oil filter housing then and I'd still have a great CAR. I'm LIVID. I BELIEVE THIS IS ON THEM, BUT OF COURSE, THEY DENY ANY WRONG!
      02-15-2024, 12:03 PM   #19
KeeKee
KeeKee's Avatar
Drives: 2017 BMW430i
I am test driving my sons 2017 430i. It also dumped the coolant. The closes
Place to go was Firestone. They are saying leak in ofh.....really?
Also to replace uptake manifold gasket.$2500 bill!....I had just started my 2 day
Test drive. First day, "oil was low" alert 2nd day " stop car immediately alert"
I am sooo uncomfortable having Firestone work on this engine!
I'd have to tow it 40 miles to a dealer. What to do??
      02-21-2024, 09:55 AM   #20
KeeKee
KeeKee's Avatar
So on this cooling system.......we now have a $3400 service bill for multiple issues. Was there ever a recall out there for anything to do with the cooling system on the 430i? I sure would like to get reimbursed for something. We saved the engine by not driving after the warning started.
      02-28-2024, 10:02 PM   #21
quakerroatmeal
Drives: 2018 430i Grand Coupe
I've tried to get reimbursed from BMWUSA for the coolant expansion hose I paid a shop to fix and was denied.
      02-29-2024, 01:23 PM   #22
KeeKee
KeeKee's Avatar
Bummer
