08-31-2019, 11:09 PM | #199 | |
Rep 206
CURRENT: '18 340i |
08-31-2019, 11:12 PM | #200 | |
Rep 206
CURRENT: '18 340i |
08-31-2019, 11:13 PM | #201 | |
Rep 206
CURRENT: '18 340i |
09-01-2019, 03:23 PM | #203 |
Rep 77
I've been thinking about having these installed, I'm fully bolt on with stage 2 BM3 FMIC CP DP Remus exhaust AFE intake. But I heard this a pain in the ass to install. how much do u guys think they will charge if I have a mechanic installed them?
09-02-2019, 12:22 PM | #204 | |
Rep 206
Make sure to do it at a shop you trust because there are aspects to this install which are easy to screw up
CURRENT: '18 340i |
09-02-2019, 01:03 PM | #205 | ||
Rep 77
10-17-2019, 07:47 AM | #207 |
Rep 65
I read most of the post so if this has been sugested forgive me. Why don't you get a trusty stethoscope and find exactly where the flutter is coming from. If it coming from the DV+ then that is just the operation of the the DV. If it is coming more from the turbo then you could say it is coming from the turbo getting jammed from unused boost. I plan on getting one and was interested in this thread. The waist gate, on the exhaust side, electronically or vacuum controlled should be preventing this anyway as I see it.
Thanks.
2016 328i 6MT, M Sport Brakes, Suspension, Steering and Track Handling Package
MODS: BM3 Stage 2/93 Octane OTS, Active Autowerke BMW F Chassis Intercooler, VSRF Catless Down Pipe, GFB DV+, Injen Evolution Intake, Red Line MTL for Transmission, NGK SILZKBR8D8S gapped at .24", Dinan Shockware, Cooper ZEON RS3-G1's and Hawk HPS 5.0 Brake Pads all the way around. |
12-27-2019, 03:21 AM | #209 |
Rep 170
Honestly only thing that matters is how well commanded boost tracks actual pressure seen by the MAP sensors. Anyone happen to have a log of something like this?
My main concern is that the dme calibration is trying to dump boost. If we don't actually allow it to really strange stuff can happen. Or... the DME can find other ways to compensate. Regardless there is SOME consequence of holding boost when the DME expects to be dumping it. Remember the physical spring in the DV+ changes the control characteristics of the diverter valve meaning the DME controls SHOULD be changed to compensate for it. Essentially its physical "tuning". Car controls systems really only properly act closed loop if the characteristics of the physical system being controlled remain in a defined envelope. That being said tons of people seem to run them with nothing bad having happened to anyone yet (afaik?). |
04-01-2020, 04:50 PM | #210 |
Rep 272
Did mine today. That one inner bolt Sucked even with the rounded hex. Broke it lose with a T-30 screw driver then used the rounded head to finish. Putting it back on was the big hassle.
Right now I’m not even sure how I got the bolt lined up and threaded. It took quite some time because the bolt head is big enough to where it won’t fit straight on. I started to wonder, are there different variations with n20/n26 and or xdrive? I could not get anything on it at the angle that Kies Motorsport did. In the end I fingered the thing in and used a flat head to grab the little grip on the edge of the bolt to get it as far as I could after torquing the other two. Test drive says it seems to be good, I hope I never have to touch it again. If I was to do it again I’d try a forge product that replaces the whole thing and doesn’t act like a spacer in hope that it was a bit easier. |
sspade2464.50 |
04-01-2020, 07:10 PM | #211 | |
Rep 272
I’m dumb, after looking at pics. I oriented it wrong. After painfully reversing my mistake it went in much better with the rounded hex. 300 cuts later and a sore back it is in much better. |
05-26-2020, 07:03 AM | #212 |
Rep 414
Thanks to everyone here for their input into the installation. Took me far too long but I had to file down the Allen socket by hand and I didn’t initially take off the turbo inlet pipe.
After watching the kies install he recommended coating the piston in engine oil. Did anyone else do this? Last edited by GreenF30N26; 05-26-2020 at 08:39 AM.. |
sspade2464.50 |
11-08-2020, 01:22 PM | #213 |
Rep 77
For anyone who has done this install, are you willing to part with the ground down 5 mm ball head allen? I'd happily compensate for shipping and a six pack . Also could ship it back when I'm done.
I was in the process of making my own when my Dremel died! Working on fixing it, but it's also not the most efficient tool for grinding down hardened steel... |
11-09-2020, 08:07 PM | #214 | |
Rep 1,065
edit: realoem has the screw, #5 as the following M6x14 8.8 https://www.realoem.com/bmw/enUS/sho...diagId=11_5185 However the part number physically shows T30 or so as indicated by this forum member: Looks like grinding the adapter is the way to go. This is annoying. Last edited by sqwinny; 11-09-2020 at 08:58 PM.. |
11-12-2020, 12:29 PM | #215 |
Rep 1,065
So I got it in. Feels pretty stock/the same. It is more of a preventative mod than anything else. To jumble it in after taking out the stock one was a little difficult but you do it in pieces. Put the piston + spring + base in first, the oem diverter in second. I'd recommend putting in the hardest bolt to reach (the one you need the "made tool for" in half way into the stock diverter valve mounting hole, jumble the oem diverter in there with the screw half way in, and angle it I to the base with the larger piston. It'll be tight, but you can do it, and finally you can start "screwing in" the half way screw with the grinded down hex tool even though its not technically into the one turbo housing to "push the screw" through the mounting holes and finally angle it into the mount of the turbo itself. That's THE HARDEST part. After that screw gets started and you have it in around 3/4ths of the way, put in the other screws and it goes in like cake. This is literally the angle your "tool" will be at:
ktw54.50 |
09-26-2023, 04:32 AM | #216 |
Rep 40
Can somebody give me some insight/opinions about this matter.
I have a full bolt on 328i N20 with the GFB+. Not to long ago i installed a Massata upgraded intercooler and quickly noticed flutters when building quick boost in low rpms but it wasn't always consistent. Usually i could reproduce the flutter in 3rd or 4th gear between 2k to 3k rpms. At this point in time i had Stage 1 flashed. When flashing to Stage 2 the flutters where constant and i could reproduce them every time, same process by quickly building some boost at low rpms but now i can do them in all gears. Recently i flashed the car back to stage 1 and noticed that the flutter was being produced the same way i could do in stage 2. I flashed the car to stock and shockingly it was fluttering the same way as stage 2 where usually in stock form the car wouldn't flutter at all. Long story short i took the car for a drive and when exiting my garage the turbo started sounding like an ambulance siren. Immediately i knew that the turbo was blown. I just rebuilt this turbo with a brand new core this year and in total i covered around 5000km with it. My question is this: Could the turbo failure been caused by a bad solenoid or the GFB+ divertor valve went bad ? I have zero error codes. |
09-26-2023, 05:48 AM | #217 | |
Rep 218
Reu11.00 |
09-26-2023, 12:27 PM | #218 |
Rep 1,065
Sounds like just bad luck. Wrong thread to post this in though, make a new thread.
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block Build Thread: https://f30.bimmerpost.com/forums/sh....php?t=1742413 IG + YT: Sqwin_n20 |
Reu11.00 |
