06-13-2021, 03:24 AM | #15864 | ||
Rep 125
Here it is. |
06-14-2021, 02:43 PM | #15865 |
Rep 5
Hi,
i need help again with something i want to code on my vehicle with e-sys i have followed many ways to install and run the program but now i am very confused. Could you please let me know if there is a source or a sharing that explains step by step how to code my vehicle? my car is f30 3 series 2012 model thank you very much. |
06-14-2021, 03:05 PM | #15866 | |
Rep 40,785
https://mega.nz/#!VswHmAJZ!MA1Fh4I2_...DDpLbtcV19BEy0 E-Sys - VO Coding Guide.pdf: https://mega.nz/#!EgIFAZKb!H12P6g_2p...j4BT5UCMxck1bw
06-15-2021, 06:27 AM | #15868 |
Rep 40,785
PM sent.
06-15-2021, 08:20 AM | #15869 | |
Rep 5
I'll take care of it, hope I can. And I have one more question. I can't find a software update for my vehicle in Bmw. Can you help with this issue please? |
06-15-2021, 08:23 AM | #15870 |
Rep 40,785
PM sent.
06-15-2021, 04:00 PM | #15871 |
Rep 3
Hello everyone, please if you can help. I have a BMW F30 316 2014 year. Two years ago I installed LED lights but not factory but modified old ones. I stopped working the light on the right headlight, I solved everything I replaced but the vehicle processor blocked the voltage on the right light gives only 2 volts and should give 12 volts. I go to the master for self-diagnostics and the master says that the processor needs to be changed and that is too expensive for me. He gets an error on the software he uses when he wants to restart where it says "ERROR ECU EXCEED NUMBER OF ATTEMPTS " and he says there is no help. Please is there a solution? Use software: EDIABAS TOOLSET 32 Problem: FEM 20 0x02. https://i.postimg.cc/jdVXJYJt/IMG-20210615-195937.jpg https://i.postimg.cc/nhXh8g09/IMG-20210615-195940.jpg Thx
06-18-2021, 02:17 PM | #15872 |
Rep 10
Hey, anyone have some information how coding through usb stick works? For example I know how to do simple codings by esys. But how it is done by usb? I can not find any instruction in multiple forums.
If I would like to have m startup animation in my head unit I will code STARTUP_EMBLEM to variant_1 in esys. How I can do it via usb stick? Is there any program which generate usb file? |
06-20-2021, 06:10 PM | #15873 |
Rep 14
Any post that explains how to delete old VIN?
I installed CC with LIM function, but only work LIM button. Original: NEW: I followed the steps in the guide -> DIY Cruise Control F30 F20.pdf Thanks! |
06-20-2021, 07:01 PM | #15874 |
Rep 40,785
If you have car with 249 in FA but no CC, need to add 544 to FA and flash KOMBI, else only LIM works.
06-23-2021, 12:20 PM | #15876 |
Rep 40,785
06-25-2021, 08:54 AM | #15879 | |
Rep 40,785
https://esysx.com/product/esysx-32-64-bit/
06-25-2021, 04:32 PM | #15880 |
Rep 4
Hi Shawn, we have an upgrade f20 to the full on sat Nav apple play, so when we have tried bimmercode it says the head code isn't original, I've read you can still do it with e-sys. Do you have a working version I can download?? Cheers Clive
06-28-2021, 09:18 AM | #15882 |
Rep 40,785
Your Receive PM function is disabled. PM me when working.
