06-22-2017, 12:49 AM | #1 |
Rep 139
DCT shifter on F30 request
Hello everyone, I saw a thread earlier where some dude in China retrofitted the F80 DCT shifter on his F30 but all he said was that "coding was required" when asked how he had it retrofitted.
I know those shifters don't come with the 'park' button but maybe there's a way to tap into the lower button on the shifter itself? Maybe a retrofit plug for the park button can be done? This is the shifter I saw and it has that button in the bottom that maybe we can figure out to tap into to make the park button work. Or am I completely wrong lol |
06-22-2017, 01:18 AM | #2 |
Rep 6,069
06-22-2017, 02:24 AM | #3 |
Rep 147
Subscribed. That would be awesome to have. Hopefully someone figures it out!
B45wheeler2.50 |
06-22-2017, 11:51 AM | #4 | |
Rep 139
If someone maybe knows if we can use that little button on the bottom to make that the park button then I'm definitely down to retrofit it |
06-23-2017, 02:43 AM | #7 |
Rep 14,147
Drives: G82 M4C X-Drive
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
06-23-2017, 02:25 PM | #8 |
Rep 322
I've look into doing this as well however I can't get a clear answer on what needs to be done.
From all the Pics I've seen looks like you will need to add a manual Park button. Here are some Pics I found Online, F80 shifter on F30. |
06-23-2017, 02:30 PM | #9 |
Rep 139
So basically I don't have to code anything? just leave it on neutral and put the E-brake up, turn the car off and that's it? Will the car let me lock it if it's not in park?
06-23-2017, 02:31 PM | #10 |
Rep 139
That's not a park button. That's for the PDC
06-23-2017, 02:46 PM | #11 | |
Rep 322
06-23-2017, 02:52 PM | #12 |
Rep 14,147
The DCT behaves much differently than the ZF8. You must find a way to engage the parking pawl for it to function properly. My guess is a separate button.
06-23-2017, 02:58 PM | #13 |
Rep 14,147
Here's the car that did it:
http://f30.bimmerpost.com/forums/sho....php?t=1330524 AFIAK the F30 does not have the 3 tier shift mode button, and he clearly does. It might just be a dummy button to get the trim to work, but maybe he did code it as the park button. I'm sure he can clarify.
06-23-2017, 03:05 PM | #14 |
Rep 707
the transmission still locks out and put into "park" after the car is turned off. So, it doesn't have an "actual" park setting, but it isn't sitting sitting in neutral.
06-23-2017, 03:11 PM | #15 |
Rep 14,147
Yup, which is why a button is required, which it doesn't have because of said reasons. Theoretically I guess you could code it to park when you press the start/stop button.
07-04-2017, 02:29 PM | #17 |
Rep 2,981
Drives: 2013 BMW F30 EBII
Sub'd Would love to do this to mine as well.
Drives: 2011 Porsche 958, 1965 Chevy C10, 1988 Porsche 944 Sold:2010 e90 Montego Blue, 2013 F30 EBII, 2013 Tangerine Scream Ford Focus ST, 2006 Mini R50,2004 VW Touareg, 2012 Camaro Convertible, 2008 Porsche 911 Convertible, 2007 Corvette, 2004 BMW e64 convertible, 2000 Dodge Dakota, 1999 Ford F150, 1999 Porsche Boxster, 1999 Ferrari Modena, 1992 BMW e36, 1990 Nissan 240sx, 1979 Celica, 1974 Mustang II
My Build Thread |
07-05-2017, 07:04 PM | #19 | |
BMW Aficionado
1381
Rep 1,850
try this on your stock F30 shifter ... place vehicle into neutral, pull up on your manual e-brak and shut off the ignition and open hte driver's door. see if the vehicle automatically places itself into park. all late-model BMWs will automatically place the vehicle into park when the driver's door is opened with the transmission in any gear |
07-05-2017, 07:08 PM | #20 |
BMW Aficionado
1381
Rep 1,850
the X5M and X6M dont have a true DCT ... its an M-tuned version of the ZF 8-speed. Wish it was a DCT, as the beast would likely be quicker than 4 sec 0-60
Stlthnmrdrd156.50 |
07-07-2017, 09:30 AM | #21 |
Rep 2,981
If you are stopped in the F30 and before pressing the Park button, turn the car off instead, it will automatically go into park. Maybe this would allow the DCT shifter to work?
My Build Thread |
07-08-2017, 04:13 PM | #22 | |
BMW Aficionado
1381
Rep 1,850
can someone with a standard ZF trans try this? I wont be near my F34 for a few weeks |
