06-13-2023, 10:20 PM | #1 |
Rep 4
f30 328i vs e90 335i
This is my first time posting. I currently own a 2002 330ci. It has almost 190k miles meaning it’s starting to have a good amount of maintenance troubles that I don’t feel like keeping up on. I’m looking for another newer BMW that is still fun. I’m stuck between the choice of an f30 328i and an e90 335i. I could just use some insight on which is all around better.
06-14-2023, 04:22 AM | #2 |
Rep 210
Drives: 2012 335i Sport
That really depends on the specifics of the car you’re looking at: is the e90 the n55 or the n54 engine? What year f30? Has the timing chain been addressed on the 328i? Manual or automatic? Mileage? X-drive?
Back when I was shopping, I was also considering either generation like you. As a general whole, the F30 seems a bit more reliable than the e90 (better auto transmission, no window regulator problems, etc) but the n55 is generally considered more reliable than the n20 (but there is debate on that), especially with timing chain guide/tension failures on the earlier 328i models. N54 is significantly less reliable than n55, and early n55 models in the e90 chassis had a few problem spots (related to fueling, injector/ fuel pump or something like that). If you’re coming from an E46 though, e90 reliability and problems will be fairly similar (plus the n54/early n55 things). However, you’ll find high mileage examples of both generations running around. In my case, I ended up with a f30 n55, mostly because I was looking between f30 n55 and b48, and the tail end of the e91 generation. If you are going for a 4 Cylinder, the b48 is a better option if you can swing it |
06-14-2023, 04:49 PM | #3 |
Rep 6,277
Drives: 2018 340i M Sport
Garage List 2018 BMW 340i M Sport [8.58]
2020 BMW M340i xDrive [9.00] 2018 BMW 340i M Sport [7.38] 2006 BMW 330i Sport [5.83] 2004 BMW 330i ZHP [7.13] 2000 BMW 328i [6.17] |
Good post above. N55 E90 335i over an N20 F30 328i without question!!!! End of discussion. Some discussion could be had concerning a B46/48 F30 330i.
www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ |
dejja0.00 |
06-14-2023, 08:07 PM | #4 |
Rep 1,066
Outside of the timing chain the n20 is pretty reliable if you take care of it and actually do maintenance. It shares parts with the n54/n55/s55/n63 motors.
Easy to work on, very reliable. Trans tune + off the shelf tunes with a couple bolt ons you’re looking mid to low 12s with a car that gets 24-28 mpg if you don’t hammer the throttle stoplight to stop light. Plenty YouTube videos on how to fix/repair/maintain things
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block Build Thread: https://f30.bimmerpost.com/forums/sh....php?t=1742413 IG + YT: Sqwin_n20 |
06-16-2023, 08:53 AM | #5 |
Rep 425
can't say enough about the N20 though nothing else to compare. Most reliable vehicle ever owned! Great on gas, quick enough. easy to work on. timing chain "issue" is overblown, IMO.
2013 328i M Sport, Estoril Blue, Venetian Beige, Walnut trim, 8AT, Premium, Cold Weather, Lighting, Technology, Navigation, Driver Assistance, HK Sound
06-16-2023, 08:56 AM | #6 | |
Rep 3,209
06-16-2023, 10:27 AM | #7 | |
Rep 1,808
OP will probably enjoy the E90 335i more. Last edited by eff32fl; 06-16-2023 at 10:33 AM.. |
06-16-2023, 12:44 PM | #8 |
Rep 3,209
The biggest problem with the F30 is the steering, it's just not as good as it was on the E90/E46/E-anything for that matter. I agree, OP will likely enjoy the E90 more.
06-16-2023, 03:42 PM | #9 | ||
Rep 6,277
I have a 2020 G20 M340i. I came from a 2018 LCI F30 340i M Sport. And a 2000 328i, a 2004 ZHP, and a 2006 330i sport pkg. I didn’t have any big problem with the steering or suspension of the LCI F30. I prefer the simplicity of the pre-G20 generations and it would not bother me at all to go back to my F30.
06-16-2023, 04:48 PM | #10 |
Rep 3,209
06-16-2023, 06:20 PM | #11 | |
Rep 1,827
06-16-2023, 10:25 PM | #12 |
Rep 6,277
If the right one came up I would give it serious consideration. I’m active in a G20 M340i Facebook group and almost every day someone posts that they’re looking for a 2020 M340i. I love the M340i powertrain, but in all honesty, I prefer the simpler, less techie F30 overall.
