03-25-2013, 02:07 PM | #4203 |
Rep 2,485
Drives: 340Xi MG 2017
Whole Nik's collection is on sale for cheap:
http://www.niksoftware.com/nikcollec...o%2Fmain.shtml $149 for all 6!
03-25-2013, 04:11 PM | #4204 | |
Free Thinker
17101
Rep 7,456
Supposedly the code DZISER gets you a discount on top of this sale.
03-25-2013, 11:04 PM | #4205 |
Rep 2,485
Pulled the trigger before seeing that... dammit.
Hey I dont know if any of you PC users missed this one out (like me), but Microsoft released a camera codec pack that allows Windows to generate jpg thumbnails previews for all RAW files for its file browser. This is an advantage I've always liked in Mac's; they didnt have to open the raw files into an image processing software to know which raw file is which photo; you see the previews right out of your explorer. Link : http://www.microsoft.com/en-us/downl....aspx?id=26829 About time Microsoft gets up to specs on this one; Like Canon just did for their lens caps ;p
03-25-2013, 11:06 PM | #4206 |
Rep 2,485
Confirmed: The coupon gets you 15% off. Will drop them an email in case they can adjust the price.
03-26-2013, 08:40 AM | #4207 | |
Rep 7,389
Dave
03-26-2013, 08:46 AM | #4208 |
Rep 2,485
They released this in november and it completely went under the radar.
To me, that's a major plus. How often do you have to open lightroom (or any other software) to sort out the pictures that are on your card that are from multiple minor events / shoots... Then go back to the file browser to copy your files in the respective folders of your computer. Its kinda rare that i'm amazed by a microsoft new feature; but this one really helps my workflow. And from what I see; the colors of the RAW thumbnail are pretty much spot on. I have to test if the thumbnail takes the .xmp sidecar file (thus the alterations) in consideration tho. That would be totally awesome.
03-26-2013, 08:55 AM | #4209 |
Free Thinker
17101
Rep 7,456
The codecs have been around for ages. This "new" one has a bunch of updates for the new(ish) cameras. Still no codec for the 6D.
03-26-2013, 09:21 AM | #4210 | |
Rep 7,389
Previewing it in a Microsoft picture viewer won't save me any real time, but why use another program? If MS is going to be slow with codecs for new cameras, that'll be enough to turn me off to using it, but I'm going to try. BTW, I ETTR (expose to the right), so the preview doesn't even come close to looking good. I simply look for pose, sharpness and processing potential. Dave
03-26-2013, 12:34 PM | #4211 |
Rep 2,485
I totally understand; maybe I wasnt clear; I use the thumbnails for sorting purposes; not for viewing the files.
For me; it'll definitely helps. I take pictures all week long but rarely post process during the week. So when I sit down, I have pictures from 2 or 3 different subjects and each "shoot" got its own dated folder to make it easier to find the shots afterwards. So I like to see the thumbnails since that facilitates the sorting of the pictures prior to PP. It wasnt slow for me, thumbnails showed up lightning fast on a 150+ shots folder. Mark: I stand corrected. Its the first time I ever read about this. Maybe the updates were a bit late? I searched for an app like that when I got the D7000 in oct. 2011 and couldnt find anything.
03-26-2013, 12:42 PM | #4212 |
Rep 7,389
Yes, we all work differently. As long as you have a routine and stick to it, you'll be ok. That's the key for me, developing a routine.
Many less serious photographers have no method to their madness and let many event accumulate on a card and then have no idea what to do with it after six-month, even though they may barely do any pp. Dave
03-26-2013, 01:35 PM | #4213 | |
Weebl wobbles but eats Pie
95
Rep 1,794
works for me. Not really but do have a lot of trash that I should delete and I sure don't know how to catalog in LR.
Kevin Goto
2000 740i-Annalisa (sold 2018) 2008 335i-Weebl. Weebl may wobble but has DTC 2012 X5d in Sparkling Bronze ( The Ultimate Cat Carrying Machine)-RIP BMW buyback 2019:2017 A3, 2018 Audi SQ5 |
03-26-2013, 02:08 PM | #4214 | |
Free Thinker
17101
Rep 7,456
It's weird how the files change so much between cameras. I can see the RAW files from my T1i and my 7D, but anything from the 6D still just shows the CR2 icon. I usually just go to Bridge anyway. I should mess around with the default apps setting and see if I can set the CR2 files to just launch in ACR right from Explorer.
03-26-2013, 02:26 PM | #4215 |
Rep 7,389
Delete the trash. If there's any doubt, Delete.
03-26-2013, 02:43 PM | #4216 | |
Rep 2,485
03-31-2013, 02:57 AM | #4217 |
Rep 273
for all my Canon brethren... what is the best option as a master unit ? I've got two 430EX II's... Should I snag one of the transmitters or save a bit of coin and buy a 580 or 600? Thoughts? What works best for you? I'm certainly no pro...
03-31-2013, 10:49 AM | #4218 |
Free Thinker
17101
Rep 7,456
I have a Cowboy Studios trigger setup. It works very well with my 430 EX II. It *does not* do TTL flash, so you'll have to set the flashes manually. If you want TTL flash settings, you'll have to spend quite a bit more money.
The thing I like about the Cowboy Studios setup is that it does not require line-of-sight to work. The flash can be a considerable distance away or even in another room.
03-31-2013, 11:26 AM | #4219 | |
Rep 6,798
03-31-2013, 12:05 PM | #4220 |
Rep 5,114
The 430ex doesn't hook up to wireless transmitters, but do respond to infra red transmitters, so if you were to get either the 580 or 600, you'd be better off with the 580.
The 600 also won't wirelessly trigger aftermarket wireless receivers sadly, I found this out the expensive way and was not pleased. So, if you plan to still use the 430s only, stick to the infrared only 580. And save money if there's a price difference. (Haven't looked at prices lately) |
03-31-2013, 02:44 PM | #4221 |
Rep 273
So the 580 is the way to go at this point then? If I want to keep my 430's, ETTL and add another flash. Considering the cost over say the St-e2 transmitter? Anyone have any experience with that?
The radio poppers and pocket wizards look like the bees knees, but again thats a whole 'nother realm of coin Id end up dropping.. |
03-31-2013, 07:19 PM | #4222 |
Rep 5,114
I have two pocket wizards, they are nice, but they won't pop the 600 wirelessly, unless I connect the other wizzard to it, which defeats the purpose of a wireless system in the canon flash.
Better off getting a 580 with the two 430s to control them since they don't take poppers. If you're starting from scratch and selling everything to start new, it might be a different story. I just feel like the 600 is a cash grab for canon. |
04-01-2013, 11:41 PM | #4223 |
Rep 273
Fair enough! Thats why I asked.
Now what about the canon infrared trigger.. the ST-E2? At just over 200.. it's less than half the cost of the 580, albeit I wouldnt get the additional flash unit |
04-02-2013, 11:36 AM | #4224 |
Rep 3,718
wow, after 3 years on this forum, i never knew there was a photography thread....awesomeeeeee!
facebook.com/jmeasphotography | jmeas.4ormat.com | IG: jmeasphotography |
