12-18-2018, 12:14 AM | #1 |
Rep 182
How to make N55 355i sound like a 340i with MPPSK?
Every since I whipped around a 340i at a bmw event, I've wanted my n55 335i to sound like a 340i with MPPSK. What's the closest way to get to that sweet sweet growl, burble, and snap crackle and pop without any droning and a quiet mode when desired?
12-18-2018, 05:50 AM | #2 |
Mike: Everyone's Pal
2044
Rep 2,972
Drives: F80 M3
Get a 340i
Alpine MSS Stage 2+ E30 tune|MST Intakes|VRSF Single Mid Pipe|Agency Power Intercooler|VTT Full solution crank hub fix |
12-18-2018, 06:51 AM | #3 |
Rep 3,953
12-18-2018, 11:18 AM | #4 |
Rep 1,468
Catless downpipe, flash tune, dial in burbles so they are not too extreme. You will sound better than a MPPSK 340.
12-18-2018, 11:19 AM | #5 | |
Gettin It Figured Out
1821
Rep 2,669
This ^^ .
12-18-2018, 01:44 PM | #7 |
Rep 182
12-18-2018, 02:12 PM | #8 | |
1821
Rep 2,669
You're not trying hard enough. As "progressive" as CA is...make up a pronoun, slap it on and say your downpipe "identifies" with your car....problem solved. You're welcome .. .
gx5_027203.50 |
12-18-2018, 02:21 PM | #9 |
Rep 182
12-18-2018, 03:38 PM | #11 |
Rep 689
Drives: 22 TR X3MC
I wana know how to get that deep sound that b58 gives as well!
2022 X3M Comp
2013 335i xDrive (Sold) |
12-18-2018, 06:26 PM | #12 |
Rep 2,655
I might be biased but I like the way my N55 sounds over the 340
12-18-2018, 08:01 PM | #14 |
Rep 462
12-19-2018, 09:25 AM | #15 | |
Rep 1,468
Maybe stock v stock the b58 is better? Be cool to compare in person. Both sound great, better than the s55.
12-19-2018, 10:16 AM | #16 |
Rep 2,655
Yeah that's not the case. The B58 is a great engine and sounds amazing, but IMO an N55 FBO with MPE takes the cake
12-19-2018, 05:34 PM | #17 |
Rep 1,934
The engines are basically the same, other than the difference in waste gates, turbine and compressor being a tad larger, and how the charge air is cooled. Exhaust note isn't affected much by the wastegate being electronic, and definitely not by the water to air cooling. The difference in compressor and turbine will change the note minimally because the engine volume is still the same. It's more so the everything axleback.
The lci vehicles use a different exhaust muffler,and baffling. The MPPSK muffler on the 340s looks more like a Fabspeed/IPE muffler layout. In sport the exhaust gases completely circumvent the muffler, whereas the Pre-lci MPE only forces the gases out of 1 or both outlets by way of valving. In either case the pre-lci exhaust gases ALWAYS travel through the muffler and it's baffling. If you want to sound like MPPSK then go straight pipe axleback. Or find a LCI MPE and swap it in. The inlet is at an slightly different angle but I believe any exhaust shop will be able to handle it.
12-20-2018, 11:27 AM | #18 | |
Rep 182
EDIT: Looks like the MPPSK exhaust is a full cat back system with silencer bypass valves...not just a backbox (MPE) Here's what it sounds like in the new Supra: https://www.autoblog.com/2018/12/19/...-sounds-video/ :3 Last edited by ctbear; 12-20-2018 at 11:41 AM.. |
12-20-2018, 11:47 AM | #19 |
Not 1st = Last
Rep 16
I'm in the same boat as you.
2000 BMW 323ci (Sold)
2012 BMW 320i (Sold) 2013 BMW 335xi Sedan 2018 BMW 430xi Gran Coupe |
12-20-2018, 02:55 PM | #20 | ||
Rep 1,934
12-24-2018, 10:26 AM | #21 |
Rep 182
12-24-2018, 03:07 PM | #22 |
Rep 937
The reason B58 sounds deep is the extra 0.5" downpipe.
If you want to sound close to it go catless, delete resonator, MPE or other well made axleback. I just got a catless DP for my car and it sounds the tits. VERY minimal drone. 0 drone when I turn my radio up to 25% My DP is 4" btw so I think that's why its so close.
Hi
335, 340, mpe, mppsk, n55 |
