06-08-2015, 11:54 AM | #45 |
Rep 390
Is the 14 ft USB cable used to connect to a laptop in the front seat while tweaking settings? Too bad there doesn't appear to be any Mac software.
Best,
Charlie 2013 328i MSport Estoril Blue, 6spd MT, Premium, Tech & Drivers Assist +, Bavsound Stage One/Ghost, Bimmertech Amp |
06-08-2015, 12:09 PM | #46 | |
Rep 3,834
Daily: G12 750 MSPORT Weekend Car: E90 M3
06-08-2015, 05:21 PM | #48 |
Rep 994
06-11-2015, 04:35 AM | #50 |
Rep 66
Thanks for the great review Jimmy.
Just placed the order yesterday after reading your review, and the shipment should arrive tmw. Looking forwards to installing it this weekend I will put this wireless USB connector in the amp to eliminate the wiring to the notebook. Last edited by Serpent720; 06-11-2015 at 04:49 AM.. |
06-11-2015, 08:19 AM | #51 | |
Rep 3,834
06-11-2015, 08:30 AM | #52 |
tends to get irritable
202
Rep 798
If it can work, then you will also need a micro to mini USB adapter.
AC Schnitzer/Eibach/M Performance/RaceChip/Compustar/Drone/BimmerTech/FireTV/Helix/Dynaudio/Micro-Precision/Jehnert/Audiomobile |
06-11-2015, 09:22 AM | #53 |
Rep 33
Hello,
My kit has arrived and I'm preparing to install this weekend. I noted that you mentioned "no need to disconnect battery". Everytime I mess with 12V on my cars I've disconnected the negative terminal. I noted the manual that came with the kit also suggests doing so. I'm curious if you know whether there is any voltage at the amp harness when the car is off. If no voltage and/or if it's fuse protected than I suppose there is little that can go wrong. I was just curious if you had been guided to do the replacement without removing the battery lead? Thanks! Drew |
06-11-2015, 09:38 AM | #54 | |
Rep 3,834
To be safe, just turn the car off. Oh, turn down the door gong sound in your car's setting.
06-11-2015, 10:48 AM | #55 | |
Rep 13,013
TransferJet requires a distance of about an inch or less between devices for pairing. That means that you will need to keep your laptop in the trunk and virtually on top of the PP82DSP. And TransferJet is designed to transfer files and not necessarily real-time transfer of data from the laptop to the PP82DSP back and forth -like when you are tuning. And tuning is best made from your driver seat and not from the trunk. Thus the included 15' USB cable.
Let us know how this works for you... Quote:
06-11-2015, 11:32 AM | #56 | |
Rep 1,201
Even if the amp's 12V is not switched, I wouldn't worry about plugging it in directly as the $800 amp has to have a hot swap controller to soft-start the 12V input.
2022 X7 M50i Phytonic Blue
2019 M5 MBB (wife's DD) |
06-11-2015, 12:32 PM | #57 | |
Rep 13,013
No need to disconnect battery, the PP82DSP supports hot swap. The disconnection of the battery is suggested in the PP82DSP manual as means of safety if you are wiring this unit yourself to the battery directly. This 100% PnP BimmerTech PP82DSP kit is already wired for you and it does not require any direct battery connection.
Technically the OEM amp 12V power line is not switched. It is a controlled line based mainly on the status and timing of the opening and closing of the doors and trunk. The ignition controls the permanency of the 12V as a secondary trigger. The 12V will go to sleep (less than 1V) after 20 minutes or so after all doors/trunk are closed and ignition is off. All this means that the 12V line will be constant only after opening a door/trunk if more than 20 minutes has passed after the car has been sitting, locked and off. The PP82DSP actually turns on by signal sensing. Which also means that, although "constant" 12V are present, the unit itself is not on until it senses voltage at its inputs. There is voltage in the inputs any time the iDrive unit is on. And the iDrive turns on by opening a door/trunk, and turns off (0V at the outputs) after 5.8 minutes after closing all doors/trunk in the F30. Quote:
06-11-2015, 01:13 PM | #58 |
Info-Maniac
Rep 55
I may have missed it, but I read through this entire thread. I have a 05/2012 F30 Sport (COMBOX in trunk). How will the installation differ? Seems like it would be easier? I imagine it is still compatible.
MW 328i Sport/Premium, Cold Weather & Tech Pkgs/Sport Auto. Trans/Variable Sport Steering/Xenons/Park Distance Control/M Performance Black Kidney Grills & Gloss Black Whiskers/Black Gloss roof Wrap/Dinan Exhaust/aFe Intake/JB4 w/ Bluetooth
06-11-2015, 01:40 PM | #59 |
Rep 13,013
Your OEM sound system must be HiFi to install this PnP kit. The Combox has nothing to do with the sound system in your car.
06-11-2015, 02:36 PM | #60 |
Info-Maniac
Rep 55
It is HiFi. I just was hoping to not have to pull the dash apart. I guess I'll pass for now. This is an upgrade I REALLY want to add to my car, but I'm not comfortable with the installation. Le
06-11-2015, 02:39 PM | #61 |
202
Rep 798
There is absolutely no need to pull the dash apart, everything is done in the trunk. Very simple.
06-11-2015, 02:54 PM | #62 | |
Gettin It Figured Out
1823
Rep 2,669
06-11-2015, 02:58 PM | #63 |
Info-Maniac
Rep 55
Copy that. I guess I misunderstood about the USB cable. I also thought I saw cup holders in one of the pics, but I was wrong. Now I wish I had purchased it while it was $100 off!
06-11-2015, 03:33 PM | #64 |
Rep 13,013
I don't understand... this "pull the dash apart" has been mentioned twice already. Is the photo of the laptop in the passenger seat confusing?
06-11-2015, 11:34 PM | #65 | |
Rep 33
Thanks to both of you for your responses - I'll try it without disconnecting the battery.
Cheers! Quote:
06-13-2015, 07:16 AM | #66 |
Rep 66
Just got mine installed today, after setting up my own EQ settings, and I can hear the great improvement of the sound coming out from all speakers.
I really love the solid bass and crispy sound. Good job BimmerTech! BTW, forget about the USB TransferJet, it does not work. |
audiotec fischer, bimmertech premium sound system, bmw amp upgrade, bmw hifi |
