BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > 10.25" Android 9.0 HU discussion
Studio RSR
      04-27-2023, 12:10 PM   #4225
txakojavi
Drives: bmw e90
I keep trying to put an NBT EVO animation bot and trying to put new logos but it has been impossible. I have tried in a thousand ways but nothing
Does anyone know in which folder or where I can put them in the system?
thank you
Another question is there any way to root without PC?
      04-27-2023, 12:12 PM   #4226
txakojavi
Drives: bmw e90
thank you
      04-27-2023, 12:13 PM   #4227
txakojavi
Drives: bmw e90
Sorry I edited the question twic
      04-27-2023, 06:09 PM   #4228
RedErik
RedErik's Avatar
Scotland
1024
Drives: E63 645Ci
2004 E63 645Ci  [0.00]
thank you
What unit do you have?
      04-28-2023, 02:52 AM   #4229
RedErik
RedErik's Avatar
Scotland
1024
Drives: E63 645Ci
Originally Posted by apoticon View Post
Hi everyone. I've scrouged this post and google far and wide, and haven't managed to find a possible upgrade path for my HU.
I have a PX6 unit with 4gb/32rom running on Android 9 on my E92 (I know this is F30 but I couldn't find anything about this on the e90post). I would like to upgrade to a newer version since my audio sometimes gets delayed and I do quite hate the UI the headunit currently has. Are there any software versions available ? Is there an upgrade path or a tutorial that I can take.
I've also posted a picture of the system info that might be able to answer some questions. It is a GS headunit, CIC.
Thank you!
Unfortunately this has been discontinued about 3-4 years ago and is no longer supported.
      04-28-2023, 10:45 AM   #4230
txakojavi
Drives: bmw e90
MCUVer:415187dLZH-CCC-GTL-191127-B18
APPVer:ksw_p_userdeburg_OS_V3-98
gracias
      05-25-2023, 02:27 AM   #4231
XbimE84
Drives: E84 Sdrive 2.0D
Originally Posted by Mjam View Post
Did you import the factory_config as well? Verify that you have this inside that file (you can add this if not):
<CANBusProtocol>
<Protocol id = "1">[1]CCC / EVO_1.0DIN_OldCAN</Protocol>
<Protocol id = "2">[2]CIC / EVO_1.0DIN_NewCAN</Protocol>
<Protocol id = "3">[3]NBT / EVO_1.5DIN_OldCAN</Protocol>
<Protocol id = "4">[4]NBT-EVO / EVO_1.5DIN_NewCAN</Protocol>
</CANBusProtocol>
What MCU are you on?
Where can you import this 'factory_config' file?
      05-25-2023, 05:29 AM   #4232
XbimE84
Can I have ID8 on android 9?
      05-25-2023, 08:19 AM   #4233
RedErik
RedErik's Avatar
Scotland
1024
Drives: E63 645Ci
No, you cannot.
      05-25-2023, 10:05 PM   #4234
daisy0316
Drives: f30
Originally Posted by Joxerdaly View Post
Hi I'm hoping someone may be able to help me, I have tried the search function here but haven't been able to find the information. Has anyone here got details of the aux audio connection on their 9.0 unit? If I open an app such as Audiotool and play a test tone (left side audio only) then only my right side speakers play audio, but if I play a right side only test tone; then both left and right side speakers play but at a reduced level.
Has anyone tried this before and do they get the same results? Thanks
Hi, Try another new power cable, maybe it will be helpful.
      10-14-2023, 03:42 PM   #4235
aven1971
Drives: bmw f10 525dxdrive, e53 x5
hi, I bought a cheap multimedia screen, I think they made changes to the software, can we change it for e53 or is it possible to update it? a10,a11, etc. please help.
MCUVer: 012042bJLY-CCC-HW8-190628(B1280_170325)
FrameworkVer : 9PQ2A.190305.002.eng.work2.20200423.170224
AndroidVer: 9
APPVer:2020071401T_1280x480_970
Nandflash:47,80G/64,00G
RAM: 4G
EVR5147B
PX6 4+64G android9.0
The firmware on it is very unstable, CCC does not communicate, idrive does not work, I think they confused it before me, can a new and more stable firmware be installed?
      12-11-2023, 02:33 AM   #4236
krasiganev
Drives: Audi A6 C6
Hi guys,
Is there any way to use RealDash app without OBD adapter/decoder? Since the multimedia is connected to CAN gateway, there should be a way Realdash app to use its signal.
Android 11, SD662
      12-27-2023, 03:20 AM   #4237
RedErik
RedErik's Avatar
Scotland
1024
Drives: E63 645Ci
Originally Posted by krasiganev View Post
Hi guys,
Android 11, SD662
No, there is no way. Android doesn't communicate with CAN bus at all. The MCU does and then it sends serial data to Android, which is pick up by a few system apps and acted upon or translated. But the MCU doesn't send everything, it's only programmed to understand very limited number of CAN packets. But that's irrelevant as it's not sending raw CAN data anyways.
      01-02-2024, 05:16 PM   #4238
izomorfix
Drives: BMW X3 E83
Hi guys,
I have a very weird problem with my HU. For some time now, whenever someone is calling me on the phone connected with bluetooth to the HU, the sound seems to be coming from the HU itself, not the car speakers (not even sure the HU has speakers on its own), and the sound level is very weak, I can barely hear what the other person is saying. It used to work fine until recently, and I'm not sure if I messed something up from the factory settings page, but unlikely. So the microphone works fine, the sound is there, but it's not going through as before. Not sure if anyone experienced something like this, but I wanted to try my luck here. Attaching the HU details below.
      01-14-2024, 03:45 AM   #4239
Bare2k2
Drives: bmw e-f
upgrade Ksw-Q-Userdebug from 1.8.2 to 4.2.9
Hello, I wanted to upgrade my native Android 10 from 1.8.2 to 4.2.9, I did all the steps correctly, but when the installation is 50% it skips to recovery mode, what could that mean?
Thanks
      01-15-2024, 03:23 AM   #4240
RedErik
RedErik's Avatar
Scotland
1024
Drives: E63 645Ci
Thanks
So you have an A10 unit, got yourself some update files from the A10 thread and you're posting your question in A9 thread...
You need to do these updates in increments, you can't jump from 1.8.2 to 4.2.9 straight away.
      03-15-2024, 05:25 AM   #4241
conandrum
Drives: BMW X6 E71
Originally Posted by izomorfix View Post
Hi guys,
1. The main plug on the harness must be fully inserted. However, because the board flexes when pushing these plugs in, you must be careful not to break anything. I found that by putting something hard underneath the blue GPS socket, this stops the board from flexing and allows the main plug to be inserted all the way. This is the first point of failure for HU audio. ie. the HU may have power but poor audio.
2. After rebooting, many have noticed that the audio is very low. After reboot sometimes pausing and playing a couple of times will restore audio volume. Or, touching the volume controls (OEM NAV/Android Volume) in settings>audio will also restore it. This is why KSWToolkit has a setting to restore audio levels after booting.
3. Use a USB DAC, to output clear and amplified audio through USB into an audio jack. Even then, most people (except Shamanix) get their phone calls & DTV/AUX audio refusing to go through the DAC, thus following the Android harness wiring. One could use a 'volume booster app' (20% boost does not degrade audio quality noticeably). I also tried a mini mixer & amplifier in previous pages, but I was not overly impressed with the quality of the product. Although it did an OK job its jack inputs were sensitive to jack movement and was prone to noise/interference in the car (good on the bench).
      03-15-2024, 08:16 AM   #4242
Crossbow1325
Drives: E81
Hello, i have got this version down...i have 2 questions.
1. Where from download updated software?
2. I dont see on my device lost of FM radiostation, is any solution for get that list?
MCUVer: 023042bGS-CIC-HW7-190704[B1280-170325] FrameworkVer: 9 PQ2A.190305.002 eng.work2.20190819.181847
AndroidVer: 9
APPVer: 2019082001T_1280x480_970 Nandflash: 19.04G/22.52G
RAM: 4G
UUID: 010E6A88-3BFD-00B6-0000-000100001A88
      03-28-2024, 05:27 PM   #4243
Wainsie
Drives: BMW 7 series
Originally Posted by daschacka View Post
I created a alternative dashboard apk.
This is only working for Snapdragon devices.
No Rockchip support (yet?)
Thx to Rudy for the provided ID7 Theme.
And thx to kri & nicholaschum for help in development.
If you want to try it out get the apk here:
Download
Install it to your device and grant the app READ_LOGS permission by entering this adb shell command:
Code:
adb shell pm grant com.android.kswxdashboard android.permission.READ_LOGS
This is great, but the drivers door shows the wrong side, is there a way around this please
      03-29-2024, 05:52 AM   #4244
RedErik
RedErik's Avatar
Scotland
1024
Drives: E63 645Ci
https://f30.bimmerpost.com/forums/sh....php?t=1719625
