BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Removed phone cradle
      10-27-2014, 10:19 AM   #1
TMR
TMR's Avatar
Drives: M3
I am never going to use it and would rather have the extra space for change. I ordered the rubber from a 320i but it hasn't come in. Here are a few pics.
2015 M3 BPM Tuned, Eibach, Magnaflow and more www.tmrmzine.com/m3/f80
SOLD E92 Slēk Carbon Fiber Widebody M3 www.tmrmzine.com/m3/slek/
SOLD E92 335i Stage 3+ with all the toys www.tmrmzine.com/335/
SOLD E39 M5 Modded, What a great car! www.tmrmzine.com/m5/
      10-27-2014, 10:20 AM   #2
TMR
TMR's Avatar
Drives: M3
Another pic
      08-13-2015, 03:49 PM   #3
JWBoulder
BMWs since 1975
JWBoulder's Avatar
Drives: 2014 335xi MT M-Sport
How did you do it??
How did you get the base mounting plate out??? I've been looking for a way to do this and can't find any instructions for an F30.
I'd really appreciate a few words to accompany your pictures.
Thanks.
      08-13-2015, 04:34 PM   #4
Fronzdan
Drives: '24 M240 xDrive
Yes, please. How do you get that out? I want to use connection to the snap-in and build an additional USB port, but I don't need the big snap-in dock in there taking up all that space.
Plus what is that dual port USB thing you have there? You're not using that thing as a hub, are you? I would kill to be able to do that.
      08-13-2015, 09:56 PM   #5
Harlequin
Harlequin's Avatar
Australia
362
Drives: F32 Coupé
Change rattling around in the car... This would make me drive into a wall in frustration. Can not handle shit moving around in the car... Especially if it makes a noise...
Other than that, nice job!
      08-14-2015, 06:32 PM   #6
rlmesq
Drives: 2018 440i M Sport
I have visions of a concealed Qi wireless charger where the worthless cradle goes....
      08-15-2015, 09:50 AM   #7
Anchored
Drives: E39
That would be a great spot for it. could tap the power from the cradle harness too!
      08-17-2015, 11:51 AM   #8
codeyf
Drives: 2021 X3M Comp
+1 for instructions needed!
      08-19-2015, 01:09 AM   #9
Roadtrip Ren
Drives: 2019 440i Vert
+1 on steps to remove.
      08-19-2015, 02:39 PM   #10
Fronzdan
I keep seeing these phone cradle removal threads updating. I come in thinking someone finally answers the question on how to get it out. But nuthin....and now I've just done the same to everyone else.
      08-20-2015, 11:57 AM   #11
Brandan303
Drives: M3
Would also like detailed instructions on your process of removing the cradle. Please =)
      08-22-2015, 02:28 AM   #12
TMR
TMR's Avatar
Drives: M3
Fine, my friends 335 has a cradle. He asked me to take it out for him. I will take pics. Give me a week.
      08-27-2015, 02:22 PM   #13
codeyf
      08-28-2015, 12:42 PM   #14
RalphyBMW
Drives: F31 330d xDrive MSport
FYI, you can get a USB cable & socket to mount in the glove compartment (OE position, replaces a blanking plate) and uses the port on the back of the headunit vacated by the cradle.
I use this, gives the same functionality as the cradle, other than antenna boost.
2016 F80 M3
      08-29-2015, 03:38 PM   #15
henryeeex
Drives: 2013 335i
subbed!
      08-30-2015, 08:20 AM   #16
Fronzdan
Do you have the pin out of the cradle's plug for wiring the USB? This is exactly what I'm going to do.
      08-30-2015, 03:41 PM   #17
RalphyBMW
You just need this;
http://pages.ebay.com/link/?nav=item...obalID=EBAY-GB
2016 F80 M3
      08-30-2015, 08:30 PM   #18
Fronzdan
I take it that plugs in where the snap in cradle does??
      08-31-2015, 07:56 AM   #19
RalphyBMW
Yep, plugs into the port on the rear of the head unit, vacated by the cradle.
Mine didn't have the cradle so the port was vacant.
Check out the image on this page;
http://f30.bimmerpost.com/forums/att...1&d=1390256302
http://f30.bimmerpost.com/forums/sho...d.php?t=939410
USB socket goes here;
http://f30.bimmerpost.com/forums/att...1&d=1390903432
2016 F80 M3
      08-31-2015, 10:36 AM   #20
Fronzdan
Oh I see. So I think my options are:
1) Buy the cable/USB port, route the cable to the head unit. Mount the new USB port in the center armrest somewhere. I already contacted the seller and he said I'd need the longer version which he also has.
2) Buy the cable/USB port, route the cable between the head unit and the glove box. Mount the USB port in the glove box. This seems like it might be easier. As it is, getting to the back of the head unit has me a little nervous.
Is there maybe a third option? Looking at the pic that TMR posted above showing the cradle removed...it looks like the cable harness isn't nearly long enough to go all the way back to the head unit. Are there connections somewhere under the armrest where those plug in? I'm wondering if I could tap in there. And it's not clear, but are the cables actually hardwired into the cradle? Or are there connectors there too? MAybe I could plug into that end? (I'd just like to avoid getting at the head unit if possible. It seems hard.)
Edited to add...
Just watched a video of NBT removal. Ok, the only part I'm not sure of is the removal of the trim/center vents. That just pulls out using panel removal tools?
      08-31-2015, 12:27 PM   #21
RalphyBMW
Vents just tug out, but be careful about the thin section at the passenger side.
Cover the shifter, etc with a cloth to avoid scratches.
2016 F80 M3
      09-01-2015, 12:29 PM   #22
TMR
TMR's Avatar
Drives: M3
I just went out to the parking lot at work and removed it in 5 minutes.
Pry it up from the front and pull on it until it snaps out. The pull off the rear of the center console and you will see 2 cables blue and black connectors. Unplug those and it pulls out.
