EXXEL Distributions
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Engine / Drivetrain / Exhaust / Bolt-ons / Tuning
      09-08-2011, 09:43 AM   #1
southlight
Moderator / European Editor
southlight's Avatar
1540
Drives: X3M
Post BMW Patents Turbo V6 Engine. F80 M3 Application?
BIMMERPOST NEWS
100
COMMENTS
UPDATE: We've added higher-quality schematics, including the shown variants.
Rumors of BMW considering V6 engines have been floating around for quite some while now. One possible future application often mentioned when talking about such an engine is the upcoming F80 M3 (F82 M4).
As we reported earlier, BMW was studying no less than four potential engine choices for the next M3.
To add to the speculation, we've just discovered that BMW has filed a patent for a unique twin-turbo V6 engine last year. Have a look at this schematic BMW submitted to the German patent office to describe the patent filing:
As BMW describes in their patent application, this image shows "the principle of this turbocharger layout invention (#1) in a 6-cylinder internal combustion engine in V configuration (#2) with a first cylinder bank (#2a) -- pictured as 3 circles and labeled with Z -- and a second cylinder bank (#2b) -- also pictured as 3 circles labeled with Z."
Remarkable is the particular invention. According to these schematics, the exhaust gases of all 6 cylinders are routed into one turbocharger (#4) which BMW says may also be a twinscroll turbo (see images below, figures 3 and 5). After leaving the first turbocharger, the exhaust gases can be routed either into the exhaust system or into another turbocharger (#5). So this alludes to a sequential turbo layout. The patent application also mentions that this allows different sizes for both turbos.
*IF* this new engine was actually produced and used in the next M3, we would assume that BMW goes for a smaller twin-scroll as the first turbo, with a larger second turbocharger. All that being said, this patent filing doesn't necessarily mean they actually will use a V6 anytime soon, or at all. Patented inventions often get dismissed before making it to series production. At the very least however, this shows that BMW has (or is) actually considering V6 engines and how to make the related turbocharging as efficient and responsive as possible.
We'll try to update the subject as we get new information on possible F80 M3 engines.
Follow our F80 M3 coverage in the meantime: http://www.bimmerpost.com/m3/f30m3/
BMW Bi-turbo V6 Patent Filing
Source: German patent office
      09-08-2011, 11:31 AM   #2
Jblack4083
Drives: E46 ///M3 JB/CB
Wow O_O
      09-08-2011, 11:35 AM   #3
eisenb11
Drives: 2012 E92 M3 SSII
What's new here, though? The concept of sequential turbos isn't new. Something must be special for them to patent it, but I'm not sure if I understand what it is. Anyone care to explain?
      09-08-2011, 11:38 AM   #4
Jake C
Drives: 2009 335i 2010 335d
Innovation at work.
- J
In Memory of LeRoi Moore 1961-2008.
      09-08-2011, 11:42 AM   #5
Dackelone
European Editor
Dackelone's Avatar
Drives: N54 e82
Humm... and where is the magical 3rd electric turbo gonna go?
      09-08-2011, 11:51 AM   #6
AW128i
AW128i's Avatar
Drives: E82 N51
Hmm, turbocharged V6s have been done before (Saab, Audi, etc.) so what's new here? Perhaps sequentially-charged V6s are a new thing? I think the Toyota Supra was the last production car to feature a sequential turbocharger system, but that was an I6, not a V6. Speaking of which, I don't have any issues with BMW replacing the N.A. I6 engines with turbocharged 4-cylinders, but to replace I6s and V8s with V6 engines...why BMW, why??
      09-08-2011, 11:51 AM   #7
Diver
Diver's Avatar
Drives: Black '12 135i - Sold
Sometimes patent applications disguise the product. In this case the real invention is probably the sequential turbo and bypass system. This could find itself on a V8 or I6 as well.
Often patent applications for camera lenses will indicate a different focal length that intended in order to throw off the rumor mill. The design can be easily scaled to the intended size.
I wold not jump to any conclusion yet that this is the next M3 motor.
      09-08-2011, 11:52 AM   #8
Elsabor67
aiming for 450.....
Elsabor67's Avatar
Drives: Totaled :-(
2009 135i  [10.00]
i wonder if they will be top mounted like the M5/X5-X6 M?
Quote from Ezeedee regarding car mods:
"you're only done when you sell the car "
      09-08-2011, 11:55 AM   #9
southlight
southlight's Avatar
1540
Drives: X3M
Good point. The patent document mentions the possibility to apply this to a V8, it doesn't mention an I6 however.
Best regards,
south
Those forums...WHY NOT?
JOIN THE 6MT CLUB GROUP
      09-08-2011, 12:16 PM   #10
GOLFFRR
GOLFFRR's Avatar
10817
Drives: GOLFFRR cart
ok BMW do your thing
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST!
Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101
vipfinance@bmwofcamarillo.com for warranties!
      09-08-2011, 12:18 PM   #11
Dubso
Drives: 11' 135i, 04' S60R, 03 MR-2 S
Kinda translation. feel free to correct anything I messed up
(57)summary: turbo alignment (1) for the combustion engine (2) with several cylinders (Z),that are exhaustsided(?) with at least one of the first or a second cylinder group (2a,2b) added toghether are, where the first cylinder group (2a) a first and a second cylinder group (2b) a second exhaust pipe (3a,3b) added in exhaust flow direction with a first turbine housing (4a) a first exhaust turbocharger (4) exhaust flow connected with a second turbine housing (5a) a second exhaust turbo (5) over a first stop(delay)organ(valve?) (6) exhaust flow connected, whereas the first and second exhaust(?) (3a,3b) in exhaust flow direction of the second exhaust turbo (5) in a connected exhaust portion (7) goes into, the second turbine housing (5a) goes into. Because of this inventiveness, the response is greater and engine usage is broadend.
      09-08-2011, 12:20 PM   #12
Dubso
woah, just read my own post, and it doesnt make sence at all..lol
but its also written very weird in german.
Guess I gotta go back to school
      09-08-2011, 12:23 PM   #13
runnerx
runnerx's Avatar
Drives: 06 M roadster; 06 330i 6spd
Sad to see M with turbo and V6 but that is something they'll have to do. There is a limitation on I6 design; long block causes cooling issues on the last two cylinders. I believe that is why turbo I6 overheats or limps easy. A V6 is better for turbo application since shorter block allow more efficient cooling on the cylinders.
2009 BMW X5 4.8i
2006 BMW ///M Roadster 6spd manual
2006 BMW 330i 6spd manual - gone
https://lh5.googleusercontent.com/--bIgrh8ES_s/TxSUCvOmDUI/AAAAAAAAPh0/OOjwrRZtta0/s912/z4mcomparo.jpg
      09-08-2011, 12:40 PM   #14
CT
GODXSPD
CT's Avatar
Drives: SSII E90M
Looks to me that they're describing a system in which all cylinders of each bank feed a single turbo. This turbo then feeds either A) output or B) a second turbo, depending on a (probably) ECU-actuated valve. So, hypothetically, you have a small turbo quickly spooling at the low-end. Then, at near-max spool, feeding a larger turbo. So rather than always feeding one turbo into the other, you bypass one for low-end torque and avoid lag.
Ref leaders 6, 7, 8, 9 - bypass the secondary turbo and 19, 20 - input from primary turbo into secondary turbo.
But that's just a bored engineer's lunch-break guess, don't sue me
e90m / ssii / foxred / wedssport sa-55m 19x9.5 et24 + 265/35r19 square / 15mm rear spacer / no chrome
      09-08-2011, 12:52 PM   #15
Touring
Touring's Avatar
Norway
178
Drives: i3,E21,M2,E23, Skoda Kodiaq
Reading the German document it refers to two cylinder-groups, not two cylinder rows. So this turbo layout could be describing a inline six ?
      09-08-2011, 12:54 PM   #16
CT
GODXSPD
CT's Avatar
Drives: SSII E90M
Originally Posted by Touring View Post
Reading the German document it refers to two cylinder-groups, not two cylinder rows. So this turbo-two layout could be describing a inline six ?
I think it can safely be applied to either configuration (even a flat / boxer style). Like Diver mentioned above - patent applications are purposefully vague or misleading to protect IP.
      09-08-2011, 12:58 PM   #17
rmani
Buys too many toys...
rmani's Avatar
Drives: 2000 Ferrari 360
i'd rather see a single turbo straight 6 engine. i know twin turbos have less lag, but the single turbo can really wallop you with power.
2014 BMW 740Li/2000 Ferrari 360/2004 Yamaha R1
2003 X5 4.6is (Sold)
1995 M3 (Sold)
      09-08-2011, 01:27 PM   #18
e46e92love
e46e92love's Avatar
Drives: e92 ///M3; X3 (wife's)
Best regards,
south
Like a 4.0L high-revving V8?
Cheers,
e46e92
"...it's not about the money and not about the brand of the car, it's about handling,performance and passion......And that, no other car has all together like an M3........when you talk about the most complete car the M is invincible." --Tony Kanaan.
      09-08-2011, 01:35 PM   #19
southlight
southlight's Avatar
1540
Drives: X3M
You're low-balling, that was spot-on!
The picture description (not shown in the image) explicitly refers to the diagram as a V6.
Hah, I wish!
Best regards,
south
      09-08-2011, 01:54 PM   #20
Doug007
Drives: Spacegrau 2009 335i 6MT
This looks a lot like the X5/6M engine with the turbochargers in the Vee of the engine.
I wouldn't be surprised if they end up with basically a 6 cyl version of that engine with computer controlled sequential turbos.
BMW has been really anal about minimizing turbo lag to maintain the responsiveness of the M engines. Sounds like they are doing some interesting work to that end!
2009 Spacegrau 335i
      09-08-2011, 02:22 PM   #21
chrisbmwcy
chrisbmwcy's Avatar
Cyprus
30
Drives: M4 F82 2016 DCT Austin Yellow
This must definitely be the next M3 (M4) Engine. The 3 turbo setup is to give as less turbolag as possible hence to have the required response at the track throughout the whole rev range.
Wake up people the new trend is to be smaller, more efficient and with more power. Just imagine how easy its going to be to tune the turbos of this engine and how much horsepower there will be there to unleash. The new Z4 is a 4 cylinder turbo and its faster than the previous 6 cylinder. Imagine what this beast engine will do. Just Imagine!
Current:
530d Msport G30 2017 Bluestone Metallic
Past: F36 430d Gran Coupe M-Sport Alpine White - DMS Remap, E92 320d Crismson Red M-Sport, R56 Mini Cooper S. Mazda RX8 Type-S Japan Import, E46 320ci LCI Convertible M-Sport Silver Grey
      09-08-2011, 02:32 PM   #22
bimmerJP
bimmerJP's Avatar
Drives: 2008 e90 335i
Location: Texas, the United States of America, Planet Earth, Universe
I just hope they wont replace the fabulous I6 with the V6. Even if it is 60 degree V6, it is still not as good as I6.
biturbo v6, bmw bi-turbo v6, bmw bitrubo v6, bmw f30 m3, bmw f80, bmw f80 forum, bmw f80 forums, bmw f80 m3, bmw f80 m3 sedan, bmw f82, bmw f82 forum, bmw f82 forums, bmw f82 m3, bmw f82 m3 coupe, bmw f82 m3 forum, bmw f82 m4, bmw f82 m4 coupe, bmw f83, bmw f83 convertible, bmw f83 m3, bmw f83 m3 convertible, bmw f83 m4, bmw f83 m4 convertible, bmw m4, bmw m4 coupe, bmw m4 coupe forum, bmw m4 forum, bmw m4 forums, bmw turbo v6, bmw turbo v6 engine, bmw turbo v6 motor, f30 m3, f30 m3 forum, f80, f80 forum, f80 forums, f80 m3, f80 m3 forum, f80 m3 forums, f80 m3 sedan, f82, f82 coupe, f82 forum, f82 forums, f82 m3
f80post
