01-08-2020, 03:22 PM | #45 | |
Rep 142
Sorry, I should have qualified my gas mileage statement before. If I drive somewhat normally on E30, with just city I get 21-22mpg. But I am usually hammering it, so it’s a bit worse. Highway, I’ve seen 30-31. What tune/map are you on? |
01-08-2020, 05:49 PM | #46 | |
Rep 7,634
I take a picture of my iDrive fuel economy/mileage/etc screen every single time i get gas and reset between fillups. Mileage is within 0.1-0.2 MPG of calculating manually. I average around 18 if i am doing 100% traffic/city driving with pulls whenever i get the chance. I will average about 22-24 if i have any significant amount of highway miles on the tank. However, i rarely am driving on the highway without traffic (welcome to SoCal) and if i am, i am probably doing 100+ pulls because its the middle of the night. |
01-08-2020, 10:01 PM | #47 | |
Rep 2,379
(A Dane in China) Last edited by harkes; 01-08-2020 at 10:08 PM.. |
01-09-2020, 12:01 AM | #48 | |
Rep 5,413
I'm trying to understand how safe and error free the new version is before flashing it on my car which is running very well right now on the previous version. Thanks! |
01-09-2020, 07:06 AM | #49 | |
1306
Rep 3,554
01-09-2020, 07:40 AM | #50 | |
Rep 1,499
Yeah the over boosting is a concern and I've reached out to PTF and sent them logs to review for both stage 2 93 octane and E30 maps. The logging parameters were my fault. I forgot to turn on cylinders 2-6. The RPM signal was also my fault, I had accidentally set that to max out at 5700 RPM. Both issues have been corrected so the next logs should have all the parameters needed. The E30 logs do show timing on all cylinders. The throttle closures I'm seeing on the E30 map are probably caused by the HPFP crashing, possibly due to too much ethanol, but I've run similar mixes on the v6.4 maps with no issue. I think the added boost + too much ethanol is a bad combo for my HPFP. Lastly, I noticed STFT is higher then I would expect with WMI. On the v6.4 map, my STFT would drop down to around 0.86 to compensate for the added fuel when spraying but on this map it at or around 1. I'll reply back when I get some input from PTF. On a side note, for daily driving this map is awesome but there are defeintly some bugs to work out at WOT with high load.
01-09-2020, 07:44 AM | #51 |
Rep 1,499
01-09-2020, 10:32 AM | #52 |
Rep 191,519
01-09-2020, 11:35 AM | #53 | |
Rep 7,634
01-09-2020, 03:50 PM | #54 |
Rep 1,499
Correct. Numbers under 1 the DME is reducing fuel, greater then 1 it's adding fuel and 1 is nominal.
01-09-2020, 04:10 PM | #55 |
Rep 289
ACN91 V7 STAGE 2
http://www.bootmod3.net/log?id=5e16bd4ec090c6601b7d1ea6 http://www.bootmod3.net/log?id=5e16bd4ec090c6601b7d1ea5 http://www.bootmod3.net/log?id=5e16bd4dc090c6601b7d1ea4 also having a bit of issues on acn stag2 v7.0. sent logs to PTF! Will flash back to 6.4 again! |
01-09-2020, 07:35 PM | #56 | |
Rep 2,379
(A Dane in China) |
01-09-2020, 08:08 PM | #57 |
1306
Rep 3,554
http://www.bootmod3.net/log?id=5e1105b0ae729b7e8357b6f4
The rest all look the same.. i have a 6th gear from like 2500 to 5300 pull but ran into some traffic and couldn't finish the pull so its mostly useless. But the other multi gear pulls all look similiar. All e30ish runs |
01-10-2020, 10:29 AM | #58 | |
Rep 1,499
Your log shows HPFP crashing in each gear and your boost (pre-throttle) is significantly under target. Your timing looks great though.
Here is a log from a revised map Halim sent me last night. I've sent it to him and waiting on a map revision. Still seeing some over boosting and HPFP crash. The lastest log does show throttle closure when the HPFP crashes and WG duty cycle drops to dump boost. Hoping to have a new map to flash before lunch so I can log during my lunch break. http://www.bootmod3.net/log?id=5e18709fae729b674d927ab6 Quote:
n55david1306.00 romemedrano119.50 |
01-10-2020, 11:37 AM | #59 | |
1306
Rep 3,554
I didnt even notice the crash down low, I was just glancing at it and it looked fine up top where I usually see crashes. Whats weird is I have a 6th gear log where its overboosting and then shutting throttle multiple times. Guess its help ticket time lol.
2017 m240i xDrive 10.67@132.32mph w/bm3
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc Last edited by n55david; 01-10-2020 at 12:22 PM.. |
01-10-2020, 12:43 PM | #60 | |
Rep 289
01-13-2020, 10:28 AM | #61 |
Rep 865
I'm very intrigued with BM3 do they have a rep on the forum that I can private message? I have some questions for them.
2023 i4 eDrive40
2022 Acura MDX |
01-13-2020, 10:35 AM | #62 | |
Gettin It Figured Out
1823
Rep 2,669
Go to their website, email them directly .
01-13-2020, 10:36 AM | #63 |
1306
Rep 3,554
Yeah but youre better off contacting them directly as they dont really monitor the sites.. they dont have that kind of time or man power.
01-13-2020, 11:07 AM | #64 |
Rep 170
Ditto. I did that and they replied fairly quickly.
2015 335xi Black/BLK, FBO BM3 Stage 2, AA FMIC, CTS Turbo CP, FabSpeed Sport Cat DP, MPPK airbox w/high-flow filter, 18" AG M310's black
01-13-2020, 10:24 PM | #66 |
Rep 928
This 7.0 version is only for factory hpfp right?
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s. |
