12-19-2023, 03:26 PM | #1 |
Rep 312
N20 blown at 63k miles, but why?
My 2015 328i has blown up. Cylinder #4 showing no compression. The others are fine. Two different shops say "replace the engine" and I may do that but neither can tell me what, exactly "blew."
I have a Stage 1 Bootmod ECU tune. Aftermarket chargepipe and downpipe along with a larger intercooler. I've practiced good, regular maintenance including new plugs and coils just recently and have never had a problem until now. 2 borescope reports same "we don't SEE a burnt valve." I probably will repair this car as I still really like it but am puzzled as to why diagnostics are proving to be so hard to come by and would much rather fix something relatively minor than a wholesale engine swap, possibly inheriting some hidden problems in the replacement. It did happen at a BMW Club track day but I'm a rookie and was driving with a club instructor learning the lines. Noticed a big loss of power exiting a turn at about 3500rpm and mid-throttle. Thanks a million for your diagnostic ideas or personal experience with this engine. |
12-19-2023, 03:42 PM | #2 |
Rep 16,199
Zero compression could be a number of things, none of them good. The only way to find out for sure is to tear the engine down, and if that reveals something that's not worth trying to fix you've wasted the cost of tearing it down.
12-19-2023, 04:20 PM | #3 |
Rep 5,460
Drives: F30
More than likely a hole in your piston due to detonation (LSPI). Although not super common, its been reported on this very forum. Be sure to follow up if you do decide to open the engine!
12-19-2023, 05:22 PM | #4 | |
Rep 1,073
Remember when tracking and beating on the car, you are leaning on it to make more power. Otherwise I could just have been sheer bad luck. N20/n26 has a history of not being the most reliable due to castings in the block, the oil pump pickup being smaller than your thumb, age of the car/motor. These things are at 10 years these days if not over.
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block Build Thread: https://f30.bimmerpost.com/forums/sh....php?t=1742413 IG + YT: Sqwin_n20 |
12-19-2023, 10:26 PM | #7 | |
Rep 3,958
If gaining power was that easy with no detriment to reliability, BMW would have already done it from the factory. |
Billfitz8316.00 |
12-20-2023, 04:19 AM | #8 |
Rep 218
I think it was the sudden burst of torque that destroyed the piston position.
Most of the N20s I have seen were damaged at 3-4K RPM after full throttle. With the stock turbo, this rpm will reach maximum pressure, which may reach 25psi in an instant. If you plan on rebuilding the engine, I highly recommend replacing it with forged piston connecting rods, as well as a brand new block. I built a closed deck block and used it for 1 year with pressures up to 28psi and I am currently working on another wet cylinder liner |
12-20-2023, 05:23 AM | #9 |
Rep 20
What was your oil level before? Was it at max or between max and min?
I heard, that in N20/26/55 engines, extremely right turn (like on a track) can cause loss of oil pressure, due to centrifugal force. I don't know if this is true. |
12-26-2023, 02:21 AM | #10 |
Rep 312
That's the consensus and I'm ready to swap out the engine but it is frustrating to learn that while it might be something inexpensive (head gasket) learning for sure could make the ultimate repair cost much higher.
12-26-2023, 02:22 AM | #11 |
Rep 312
It showed right at full on the electronic gauge (N20s don't have a dipstick).
12-29-2023, 03:49 AM | #12 |
Rep 20
Drives: BMW 428i Gran Coupe
I have an n26 with 110k miles on it and after letting someone other than me drive it for a month I get it back and there is no compression in cylinder 2. Cylinders 1, 3, and 4 have normal compression. The engine had a custom tune, was full bolt on, had a stage 3 pure Turbo. I'm not sure exactly how hard this individual drove the car bc I wasn't there, but from what I've gathered she basically dogged it out. No respect at all for all the time and money I put into the car. I know the oil level was slightly low (a half quart low)...i.cant even say she was using 93 octane gas...considering the tune was for 93 OCT plus 50/50 water/methanol injection that would've been devastating. Check out.these pics of the second cylinder piston. I tore the engine down myself. Notice the chunk missing from the right side of the piston. What could cause this?
12-29-2023, 10:23 AM | #13 |
Rep 1,073
You answered your own question here. all these things can lead to other things. without a log or you driving the car could be anything.
“I know the oil level was slightly low (a half quart low)...i.cant even say she was using 93 octane gas...considering the tune was for 93 OCT plus 50/50 water/methanol injection that would've been devastating.”
12-29-2023, 11:42 PM | #14 |
Rep 20
I meant what would cause that chunk to get blown off the piston? Some type of abnormal detonation?
12-30-2023, 03:43 PM | #15 |
Rep 10,322
BXL4 This is one of those “pay to play” cautionary tales.
It simply happened to you instead of another BMW enthusiast. No fun of course but the risks are always higher when adding something that BMW engineers did not plan for. Engines can fail even under normal driving conditions. It’s rare but it happens. Manufacturing defects do occur and just when conditions are right (extra boost helps wear down the already compromised part) the failure happens. Hope the new or repaired engine will be installed soon and you will enjoy the car again. |
01-12-2024, 08:11 PM | #16 |
Rep 5,460
Drives: F30
MaverickCruise exactly!
01-12-2024, 08:13 PM | #17 |
Rep 5,460
Drives: F30
sqwinny the N20 was offered in NA Market up until (and including) MY2018... there are many out there with under 10 years on them.
01-13-2024, 11:35 PM | #18 |
Rep 1,073
Steven please reread the post by OP. 2015 car. If motor is original that means motor was assembled in 2014. OP made this post in December ‘23. 2014 -> 2023 is ~10 years. It’s not worth it to quote me in this thread on over technicalities of 2-5 months of a potential engines age of being built at the factory…
01-16-2024, 03:37 PM | #19 | |
Rep 4,139
My sisters totally lost compression cylinder 1 out of where Piston ring was broke. Piston 1 and 2 were replaced. Although it’s had some instances where it’s ran hot. Debri causing radiator failure, and one time ran out of fuel due to faulty pump. How does a girl driving around the city back and forth to work stock, fry a piston ring. Lots of folks with timing chain issues. |
01-18-2024, 10:57 AM | #20 | |
Rep 1,073
Piston rings can be due to too many occuring knocks, bad gas, low oil level as a turbo motor WILL burn an amount oil eventually. Those 10k miles oil changes were the dumbest thing BMW started. so crappy gas + low oil + limited fuel can cause issues from one occurrence or over time. If you run out of fuel because of a pump that happens from time to time. Fuel pumps are a forever components. Although n20 has it faults, it’s not exactly any different from other cars. If you have a German car you play by German rules. If you don’t you are in for a bad time.
G35POPPEDMYCHERRY4998.50 |
01-18-2024, 12:16 PM | #21 | |
Rep 4,139
curious how low fuel or running out of fuel can cause piston ring trauma. |
01-18-2024, 02:18 PM | #22 |
Rep 1,073
Typically the n20 and PWG n55 share many of the same components. When you have a customer who is driving and doesn’t check things every so often, these cars require maintenance on the schedule. You have to play by the German rules. If you say well I can stretch this out by 500 miles you are playing the not if but when game for lifespan of parts/fluids/etc. many people forget fuel injectors you can’t clean on Direct injection motors without removing them 100% and doing a supersonic clean or replace them every 50k miles or so.
Initially the n20 had plenty issues with the high compression motors. Some quality control, some manufacturing, some pure bad luck. With low oil pressure/fuel issues you can cause little and non feeling in the cabin knocking / but also at the same time LSPI is possible. Bmw didn’t learn their lesson and did the same thing with the first gen b46 which was in the mini and high compression versions of the b46 in the f chassis. Needless to say the low compression pistons don’t really have an issue for n20/n26/b46/b48. Sometimes it can be just sheer bad luck. In your other comment with the missing PCV hose, it’s clear your sister doesn’t work on cars or took it to get serviced recently and had an overall inspection done as the PCV hose was just hanging in the engine bay completely sheered off.
