10-20-2018, 07:01 AM | #2355 | |
Rep 69
It is not possible to make a default app to my understanding. To be honest I am happy that music app starts on default. Because when I close music app and start spotify or internett radio, both works with next and back key on steeringwheel. This freeze issue has also happened to me once. I think its running to hot. Its just a guess from me. But I know from other units that PX3 will overheat very easy. I am going to install a fan later to see if it helps. <-- But I have only experienced it once. But I am only using it for Sycig, not Gmaps. I think Gmaps is using more Cpu power. Firmware updates. MCU updates. <.-- Only instal CIC MCU updates on your unit if your is CIC. NOT CCC and NOT NBT. THIS IS 7.1 ONLY. DO NOT USE FOR ANDROID 4.4.4 |
10-20-2018, 08:04 AM | #2356 | ||
Rep 32
10-20-2018, 08:11 AM | #2357 | |
Rep 32
10-20-2018, 11:29 AM | #2358 | |
Rep 13
The unit I have is the 10.25' as i have the F10. Of the crashing issue was due to the temp of the unit, should't the whole unit not work? The build in car menu is fine and so is the music if it's playing. I sometimes even get the commands even though the screen is 'broken' |
10-20-2018, 12:13 PM | #2359 | |
Rep 8
I'm glad ...... This is the greatness of the network |
10-20-2018, 12:36 PM | #2360 |
Danilo
Rep 43
NO SIGNAL
I have a unit 4.4.4 gen2 avin
and I still have the problem that often when yes start the drive gives me the error "no signal" I have to turn off the car or reset button I have the latest update but still many times myself from this problem can someone help me Thank you Danilo |
10-20-2018, 01:14 PM | #2361 | |
Rep 69
10-20-2018, 01:18 PM | #2362 | |
Rep 69
10-21-2018, 03:50 AM | #2363 | ||
Rep 32
10-21-2018, 05:29 AM | #2364 | |
Danilo
Rep 43
I did some tests and I think the problem is software and not hardware in fact, when I delete the cache from the MUSIC app the system starts again and again without problems and then after some kind of 4 or 5 switching on the problem occurs again and as if you could not shut down in time when you close the car because the 12v power supply is removed before the system turns off completely |
10-21-2018, 03:31 PM | #2365 | |
Rep 69
10-22-2018, 07:23 AM | #2366 | |
Danilo
Rep 43
anything . I tell you that not using the app music and using all of them other applications the "no signal" problem on 30 ignitions only once happened. When using music there are problems otherwise not |
10-22-2018, 12:05 PM | #2368 |
Rep 69
When I had the splitter installed my unit went in No signal mode everytime I hard reset my unit. Now without splitter I have not had any no signal screen since. Please test to only unplug GPS antenna for a while. Its a 5 min job.
10-22-2018, 12:07 PM | #2369 |
Rep 69
Format to Fat32 or NTFS. Copy PX3.img to root of USB stick. If it doesnt work on one usb port, try the other one. Min only worked to upgrade through 1 of 2 usb ports.
10-22-2018, 01:22 PM | #2370 |
Danilo
Rep 43
10-22-2018, 03:19 PM | #2371 | |
Rep 16
View post on imgur.com View post on imgur.com My car is BMW F21 View post on imgur.com Last edited by vieira_mar; 10-22-2018 at 03:40 PM.. |
10-22-2018, 03:32 PM | #2372 | |
Rep 13
What is the difference between tbe firmware version and mcu? Do i need to upgrade both? Is there any order to do it is mcu has to be on specific version before upgrading firmware? Thanks again |
10-22-2018, 08:10 PM | #2374 | |
Gettin It Figured Out
1820
Rep 2,669
Great find!! Thanks!! . . .
10-22-2018, 08:34 PM | #2375 |
Rep 19
Hi,
Can someone Help, my unit is BMW F10 Android 4.4. Over last few days my Unit Stuck in the BMW logo when boot up. It doesn't boot up at all. The BMW original I Drive is working Fine but not the Android. Can someone please help. |
10-23-2018, 01:44 AM | #2376 | |
Rep 69
I would not recommend to upgrade MCU If you are happy with how your unit is working. Newer is nopt always better. Its writen to upgrade FW first and then MCU afterwards in documents. I am not sure what is the correct order. You can go for what version you want. |
