05-16-2019, 01:33 AM | #221 |
Rep 21
ATE is a good option, they are also the CM of BMW for the brake fluid.
320i N20 8AT | Öhlins DFV Suspension | RAYS 19" ZE40 w/ PS4s | BM3 Stage2 91 | MP Brake Kit | WT Competition FMIC EVO 1 | HJS Euro 6 200Cells Catalytic DP | ARQRAY Performance Exhaust | GFB DV+ Blow off Valve
Waltabeast72.00 |
05-17-2019, 01:18 PM | #222 |
Rep 26
My apologies if my question has been answered, but which M Performance rear rotors are meant for a 320i xDrive without OEM M Sport brakes? Is it 34206797598 or 34206797600?
I've contacted numerous dealerships (both German and American) and they all say I need the 34206797600, per VIN. However, a few retailers claim I want the 34206797598 because my car came with the base brakes. Then there are others that say I need the 34206797600 due to the xDrive's larger hubs. Any help is appreciated. |
05-17-2019, 10:28 PM | #223 | |
Not stock
475
Rep 614
I am using Motul 660
2015 BSM 328i Sport Line - BSM
2015 BSM X1 M Sport - BSM 1992 525i 1987 325e |
Waltabeast72.00 |
05-18-2019, 08:18 AM | #224 |
Rep 26
05-22-2019, 03:58 PM | #226 |
Rep 112
Looking to get this done myself. Just priced the kit with Sun Motor Cars.
list is 2460.00 sale price would be 1740.00 rear rotors 34206797600- list 266.00 ea , sale 175.00 ea (Im an xdrive) Told me 834.00 in labor + tax. Gonna have to start saving my pennys! |
02-01-2020, 05:40 PM | #227 | |
Rep 741
2016 435i xDrive F36 M Sport - ER CP | ER Catless DP | VRSF 5" FMIC | bm3 stage 2 93 oct | black double slotted grill | AWE axle back exhaust w/102mm diamond black tips | 437m wheels
02-06-2020, 11:12 AM | #228 |
Not stock
475
Rep 614
Compared to what dealers charge for an ordinary rotor/pad change I don't think that $834 is outlandish. I wouldn't pay it, and didn't, but considering what the labor is its not horrible knowing they'll have to bleed, replace calipers, rotors, pads mount the new calipers, maybe muck with dust shields, and code the car.
02-06-2020, 01:37 PM | #229 | ||
Rep 5,410
Onizukachan1139.00 B58 parts491.50 |
02-06-2020, 01:45 PM | #230 | |
Rep 5,410
My independent BMW mechanic who used to work at a dealership and is factory certified charged me $100/corner so $400 in total for the labor. Find local Indy mechanics on BimmerShops website. |
02-06-2020, 07:47 PM | #231 | |
Not stock
475
Rep 614
Yep - from 07/2014 all F30 have the larger rear parking brake hub size no matter if its 318, 320, 328, 330, 335, etc.
johnung4552.50 Onizukachan1139.00 |
02-07-2020, 01:14 AM | #232 | ||
Rep 5,410
02-07-2020, 08:23 PM | #233 |
Rep 806
I got the yellow kit a few weeks ago. To be honest I'm not too thrilled on the color, there's a bit of a weird green in it. It's like that Austin yellow the f80 comes in.
I'm about ready to install them. I decided to go with ebc redstuff pads over the ones that came in the kit. If anyone wants a new set of the pads, for sale, msg me. I don't think I need these dust shields either. I also got the stoptech lines. I'm just going to stick with the pentosyn dot 4 lv. Do I really need the computer to bleed, can't I just tap the calipers and the abs pump thing with a rubber mallet? I feel like that's in the same category as using a torque wrench for everything. There were a few posts about the rear caliper bolts being difficult to get at. Any issues back there, I would think an impact can fit? |
02-09-2020, 10:41 AM | #234 | |
Rep 5,410
Brakes and tires directly effect safety for me, my family and everyone on the road around me. I never ever take shortcuts or skimp on brakes or tires. It's just not worth the risk. Hope this helps! |
02-09-2020, 08:18 PM | #235 | |
Not stock
475
Rep 614
And yes - I used a pressure bleeder w/o issue at all. I use these: Clamp off the lines or act quick and no risk of air getting up into the modules. That's when you need the computer assist bleed.
johnung4552.50 |
02-16-2020, 04:05 PM | #236 |
Rep 806
Well this wasn't too bad at all, much easier than the coilover install. It just takes time.
The stock brakes were nearing the end of their useful life. These are brand _new brakes so just that on its own is very nice to begin with. The pedal is a tad off at the top, I will bleed again next weekend, possibly this time involving ista. The feel and stopping power is much better. The redstuff pads so far are dead silent and have a good bite (once I get through the bit of pedal sponge). They're way too much for the snow tires. The rotors look great, the gold color isn't bad, but there's salt all over everything .. i'll look in the spring. I should consider 19s. I built the new calipers/pads/lines on the bench. Siphoned the old fluid. Drove out the old pads and pushed the pistons in. Reinserted old pads so the calipers don't blow apart. Loosened all the bolts just left one caliper bolt in loose. Now installed pedal depressor. Broke the line open, no drip. Remove caliper and line, swap disc and clean hub, install caliper and line. A 16mm 12 point socket helps for the rear caliper bolts. There is not much room to swing the breaker bar, one tooth of the 12pt is about it. Once everything is tight, pressure check, add fluid and pressure bleed. I did 3 passes around the car and I had the rubber mallet tapping the calipers and abs thing. Bleed clutch. The key to bleeding the clutch is to go under sideways, legs under right side. Very visible that way. And the 11mm stubby reversible ratcheting wrench. Use esys to add spbr to ho-wort folder and write vo to vcm, recode DSC module. Test drive then bed in, I did about 8 hard 60-20 almost stops with a little cooling time. |
09-02-2020, 06:05 PM | #237 |
Rep 1,125
Drives: 2015 BMW 435i Xdrive MSport
I'm getting these brakes installed next Friday, it's gonna be really close on 18s, I almost feel the wheel weights will hit LOL, have you had any issues.
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
09-03-2020, 07:41 AM | #238 |
Rep 2,981
Drives: 2013 BMW F30 EBII
These were 18's...it is very close, but never had any issues. And they look so good!
Drives: 2011 Porsche 958, 1965 Chevy C10, 1988 Porsche 944 Sold:2010 e90 Montego Blue, 2013 F30 EBII, 2013 Tangerine Scream Ford Focus ST, 2006 Mini R50,2004 VW Touareg, 2012 Camaro Convertible, 2008 Porsche 911 Convertible, 2007 Corvette, 2004 BMW e64 convertible, 2000 Dodge Dakota, 1999 Ford F150, 1999 Porsche Boxster, 1999 Ferrari Modena, 1992 BMW e36, 1990 Nissan 240sx, 1979 Celica, 1974 Mustang II
My Build Thread |
09-03-2020, 08:02 AM | #239 |
Rep 1,125
That's what most people have told me. It's close but not close enough to hit anything. Would you happen to have close-ups so I can see how close. I can't find anything else on the web. Thanks!
09-03-2020, 02:47 PM | #240 |
Rep 2,981
I don't unfortunately...I sold the car about 4-5 months ago, so I can't take one for you. Sorry.
My Build Thread |
Boostedphil698452.50 |
09-03-2020, 03:53 PM | #242 |
Rep 1,125
You can get the kit from getbmwparts.com pretty cheap. I think the list price is $1,895.00, and then get rear rotors from somewhere else.
