09-29-2020, 09:15 AM | #309 | |
Rep 6
".fseventsd" and ".Spotlight-V100" but I am not sure if there were there before. 2. Thumb drive was formatted with FAT32. USB stick has 29,2GB |
09-29-2020, 09:50 AM | #310 | |
Rep 2,370
Drives: E63 645Ci
Did you use Mac to format it? Because it looks like you did. |
09-29-2020, 03:58 PM | #311 | |
Rep 6
By the way do you know if there is possibility to import few bootanimation to boot logo menu in factory settings? Then I could just change few my best boot logos from Android system. |
09-29-2020, 04:53 PM | #312 | |
Rep 2,370
Drives: E63 645Ci
As for boot animations, the menu in factory settings is for splash images - still images before animation. You could make few of these, zip them in mylogo.zip and upload to your unit. However this will not work for boot animations. There is no method do that at the moment. I could probably write an app that will handles swapping of boot animations but I'm really busy at the moment. |
09-29-2020, 09:29 PM | #313 |
Rep 592
Ok. I don’t know if you guys are taking donations for it or sharing it or both. But I need this in my PX6 unit. I shot both BlackDMX and RedErik a PM . Somebody please get back to me. You guys are doing awesome work and taking this to whole other level. If I have to buy a snapdragon unit if need be, so be it.
09-29-2020, 11:02 PM | #314 | |
Rep 2,370
Drives: E63 645Ci
Most of the stuff here is free. Both themes and boot animations work on PX6 units. However none of the apps does (keyboard and custom dashboard). For these you would need SD625 unit... however a fix might be coming in the near future. Frankly30 is trying to figure out how to enable full iDrive controller support systemwide so PX6 user could enjoy that and get the keyboard app. |
09-30-2020, 08:38 PM | #315 | |
Rep 592
10-01-2020, 01:28 AM | #316 | |
Rep 2,370
Drives: E63 645Ci
What I mean by that is everywhere you see a download button means the stuff is free. Where is only a note to contact the author it's mostly likely paid option. In general all is free except blackDMX works and my keyboard app. Hope this is now clear as mud |
10-01-2020, 01:35 AM | #317 | |
Rep 1,048
Kri |
10-01-2020, 02:57 AM | #318 |
Rep 2,370
Drives: E63 645Ci
10-02-2020, 05:07 PM | #319 | |
Rep 592
10-02-2020, 06:37 PM | #320 |
Rep 2,370
Drives: E63 645Ci
10-17-2020, 02:20 AM | #321 | |
Rep 17
How can i get the dashboard and id7 theme? |
10-17-2020, 02:49 AM | #322 |
Rep 1,048
10-17-2020, 02:51 PM | #323 |
Rep 17
10-21-2020, 06:00 AM | #324 |
Rep 2,370
Drives: E63 645Ci
Just a wee heads up. My next project is far from completion, but what I'm working on right now is a proper implementation for music player. It will have:
1. Proper sorting 2. Search (by song, artist, genre etc.) 3. Local playback (local storage, USB & SD) 4. Spotify integration 5. Playlists |
10-21-2020, 06:55 PM | #325 |
Rep 40
Nice, finally a good player for the HU could you implement the possibility, that if I choose one folder it automatically inserts the songs from the subfolders the list? As I found out not many players available in the playstore can do it and the ksw player also can’t do it.
10-22-2020, 01:44 AM | #326 | |
Rep 2,370
Drives: E63 645Ci
10-22-2020, 05:07 AM | #327 |
Rep 40
Yes that would be great. Because in the ksw player if I select a main folder it only loads the mp3s from that folder and not the ones from the folders in that main folder.
By the way, you did a great job with the keyboard, I love it. |
10-22-2020, 06:14 AM | #328 | |
Rep 2,370
Drives: E63 645Ci
Thanks, this is much appreciated |
10-25-2020, 03:26 AM | #329 |
Rep 143
Hello,
I'm sorry if this is the wrong forum (I'll post in the other one if it is). I purchased a 12.3" 720p unit from AVIN. I like the unit for my car, but after updating to 2.3.0, the boot image and/or animation became corrupted (at least I think that's when it happened). Sometimes it works ok, but most times it just displays vertical lines on the screen that mimic the image that's supposed to be displayed. If I hit the MENU button to get into the BMW UI, and then MENU again to get back to Android, the image corrects itself and the UI looks normal. If I don't do anything, after it's done with the boot animation, the Android UI remains corrupted in the same manner. I have tried changing the image via the OEM folder via splash and bootanimation files, but to no avail (as well as several recovery installations, and changing countless settings in the Kri version of factory_config). Here's a video of what is happening: https://drive.google.com/file/d/1SZu...ew?usp=sharing The video ends abruptly but what happens right after is as I said above, it goes back to the Android UI which at that point looks normal again. Any idea what could be happening here? I have been in contact with AVIN, and while they have been very responsive, I don't think they know what's going on. Thanks in advance! |
10-25-2020, 09:12 AM | #330 | |
Rep 2,370
Drives: E63 645Ci
Most likely this is an issue with one of these: 1. MCU 2. Incorrect screen settings 3. LVDS cable or LVDS board I would reflash the MCU with most up-to-date version for your unit, double check if the correct screen is selected in factory settings and check all wiring connections. |
EvntHrzn94.00 |
