BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > 2013 335i N55 Dyno 400whp, 473wtrq STOCK TURBO. With JB4 different map comparisons!!
      10-19-2016, 06:40 PM   #23
AJAnello78
Drives: '13 335IX M Sport
what modifications have you done to the car in total?
sorry for the newb question. just got my F30 a few months ago and looking to spice it up a little bit. btw where in NJ do you live?
      10-20-2016, 07:30 AM   #24
F30_SixSpeed
F30_SixSpeed's Avatar
1195
Drives: 335i M Sport
Im in Bergen County.
Read first post... has the details. Full bolt ons, JB4 with bluetooth, e40 ethanol mixture
335i M Sport 6MT || PS2 Turbo, FBO, XDI-35 HPFP, BM3, KW, MP BBK, OEM+
INSTAGRAM || BUILD THREAD
FSociety3957.00
      10-20-2016, 11:57 AM   #25
soundwave9
Drives: 2013 F30 335
So that would be downpipe, chargepipe, intake, exhaust? No meth kit? Mind listing the manufactures? Just curious. Very impressive numbers btw! Interesting that you lose quit a bit of torque on map 5.
      10-20-2016, 10:00 PM   #26
F30_SixSpeed
1195
Map 5 isn't bad up top, but it could be a little inconsistent down low and mid rpm range in my personal experience... as confirmed by my dyno.
Heres what I'm running currently:
  • AFE Open Air Intake with Dryflow Filter
  • JB4 with Bluetooth Module
  • Evolution Racewerks Charge Pipes (anodized black)
  • Wagner Tuning Catted Downpipe
  • AWE Tuning Exhaust with Performance Mid-pipe
      10-20-2016, 10:43 PM   #27
zcspec
zcspec's Avatar
222
Drives: 911/Cayenne E-Hybrid/X2
You're giving me a nice road map to follow!
      10-21-2016, 10:04 AM   #28
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
WOW, this is all JB4 tuning?
I feel like my throttle sticks a little in map 2, how do you deal with the throttle response? It might also be my BEF>
SOLD: 2012 335i Mineral Gray
      10-22-2016, 10:57 AM   #29
F30_SixSpeed
1195
I haven't experience that.
      06-04-2017, 12:10 AM   #30
clor
Drives: M3
Thanks for your post as a guide!
      12-25-2017, 11:08 AM   #31
ceedawg
ceedawg's Avatar
477
Drives: 2k15 335i xdrive MSport 6spd
Hi guys,
I was able to secure some dyno time this weekend and I threw my 2013 335i M Sport on for some testing. Overall, I was extremely pleased on how my car ran and it even out performed some of the figures I had in my head. I was able to hit that 400whp club on stock turbo
I will get to the good stuff first. Car is equipped with a 6 speed MT, full bolt ons (minus FMIC), running ~e40 mix and JB4.
Best pull was 400whp, 473wtrq. I baselined on this SAME dyno bone stock with 273whp, 298wtrq. These are gains of 127whp and 175wtrq.
Here is the video of the pull:
Here is the log from the best pull. Running map 7
I did another dyno run directly after (still on map 7)...numbers were slightly lower due to heat soak.
Baseline Run FBO vs. Map 7.
STOCK DYNO SHEET
After this I decided to do some independent dyno testing with my JB4.
*Please note the below runs contained e40 (aside from stock baseline number which had 93 pump gas.) If you are running straight pump gas, expect the numbers to be lower.
Here are the results:
Bone stock: 273whp, 298wtrq
FBO Stock Boost: 311whp, 322wtrq
Map 1: 354whp, 384wtrq
Map 2: 356whp, 424wtrq
Map 5: 376whp, 396wtrq
Map 7: 400whp, 473wtrq
Wow and no FMIC IMPRESSIVE!!
      12-25-2017, 11:34 AM   #32
zinner
zinner's Avatar
Drives: `17 X5 35d/`15 335i/`18 M550IX
OP F30_SixSpeed how is the car doing these days?
      12-25-2017, 12:41 PM   #33
CobraMarty
CobraMarty's Avatar
645
Drives: 2007 328xi e90 + e92
Nice results.
So what's next?
MILVs?
Mike.2058.00
      12-28-2017, 05:13 PM   #34
F30_SixSpeed
1195
Originally Posted by CobraMarty View Post
Nice results.
So what's next?
MILVs?
Running great! I've since converted to BM3 (since June 2017) and have a FMIC now. Power comes on smoother and every day driving is more consistent then the JB4. Lost a little mid range power as I hit less boost around 3-4k rpm, but top end car pulls strong. I'm just making a little less power midrange with BM3 compared to JB4, but I prefer the BM3 to JB4 because of the consistency but they are both nice tunes.
MILVs? No plans to tap into the engine (keeping that stock) but I think I'll be going bigger turbo this spring... leaning towards Pure Stage 2 right now.
      12-28-2017, 10:37 PM   #35
terryd5150
Head Fry Cook at McBurgertown
Drives: 2015 435i M-Sport 6MT
Are you still on the stock clutch?
      12-29-2017, 09:02 AM   #36
F30_SixSpeed
1195
Yessir
      12-31-2017, 12:11 AM   #37
ceedawg
ceedawg's Avatar
477
Go for that stage 2 bro please I'm so anxious to see what she will do.
      08-16-2018, 11:55 PM   #38
2013_e92_FBO
Drives: 2013 e92 335i AT FBO
Sorry for bringing up an old post but the car I just bought is at a similar stage as yours was when you originally posted. When you ran the dyno did you just put in the e40 mix and flip to map 7 or did you have to make any adjustments the jb4 doesn’t do? I have FBO but just want to make sure I’m not missing any steps before going to map 7. Thanks
      08-17-2018, 09:31 AM   #39
F30_SixSpeed
1195
Most settings were default, but with a few tweaks. When running higher ethanol mixes (e30-40) I would log a few times to make sure everything looks good... as fueling settings may need to be tweaked. I set FOL to 90 (which is the highest setting IIRC) but everything else was set to default.
      08-17-2018, 05:22 PM   #40
ceedawg
ceedawg's Avatar
477
How has the car been running San?
2k15 335i Msport xdrive 6spd
,FBO BM3 Stg 2
2k15 M3 6spd
,FBO BM3 Stg 2H2 tune with Hybrid turbs
      08-17-2018, 10:39 PM   #41
F30_SixSpeed
1195
Running really good! Just want more boost now lol
      08-17-2018, 11:02 PM   #42
ceedawg
ceedawg's Avatar
477
KOOL
Your Boy Rob sent me a VTT link of a Big Single Garret Turbo and manifold that is coming out the end of this year so I am anxious about that.
Did you make any progress on the fueling EX: Fuel pump?
,FBO BM3 Stg 2
2k15 M3 6spd
      08-26-2018, 01:27 PM   #43
FSociety
IG @bmwF9xG80
FSociety's Avatar
3957
2022 BMW X3 M40i  [0.00]
2020 BMW X7 M50i  [0.00]
2023 BMW G80 M3  [10.00]
2020 BMW X4MC  [10.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [10.00]
Has been running more than ceedawg we haven't seen him since Captree lol
Current: 23'G80 + 22'X3M40i
Previous X7 M50, X4M, F90 M5, F80 M3
IG: @bmwF9xG80
      08-27-2018, 07:54 AM   #44
ceedawg
ceedawg's Avatar
477
You guys have slow cars compared to my crew!
When my car gets done you will see why I don't waste time running a plain ole everybody has FBO 335i on the public highways like you guys. Been there done that!
Every single car I have ever owned Datsun,Nissan,Toyota,Mitsu,BMW,Mercedes Benz has been highly modded. Same will eventually happen with this 335i. And when it's done maybe you will finally get it!
That's how my crew rolls! Ask Kew, we know the same people since we have been doing this since you were in grade school!!!
I give props to Sandro though for going with the Pure turbs. That's different
Even if I had a FBO M3(male version manual tranny) it would be a waste of time for me until I put the Pure Turbos on to be speeding around the Public highways with the same mods as everyone else. Key is not to be a follower but be different!
If it aint making 500 plus whp or running mid to low 11's @ 125 plus mph, high 10s @ 130 mph plus then to me its slow!
Troll away bro!
Again Props to Sandro.
,FBO BM3 Stg 2
2k15 M3 6spd
