08-16-2020, 05:32 AM | #23 | |
Rep 603
Upgrade with a good pad like EBC YellowStuff and you will be fine for street and track. https://ebcbrakes.com/product/yellow...nd-track-pads/ (Accept some cold brake noise on low speed in certain situations.) 370 and 340 rotors use the same pads. So they have the same brake surface size. The larger rotor allows to mount the caliper further from the axle center which gives a greater leverage. Or the other way around. With the same brake pressure applied from the driver to the caliper/pad to the rotor, the 370 rotor will have a greater brake power. (due to the larger leverage) Now, high power to the pad is only useful if you have a good brake friction. (high power applied to a low friction surface like an oiled brake surface wouldn't be helpful) That's where a high friction pad makes the difference of how effective the brake pressure can be transferred to the brake rotor. But high friction will generate high temperatures. For track use, also go with a brake fluid having a higher dry boiling point. (as already mentioned in another post.) Higher temperatures can also be a problem for pad and rotors. But with the 370 you are on the safer side. But once you've overheated the pad or the rotor, you will have to change them. So you want to avoid that. I also recommend to cool down the brakes after tracking or hard street driving before stopping the car. And, don't forget about the tires and tire pressure. The performance in dry and wet stopping power are immense.
335i F31 RWD in SB || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around || Various: LED bulbs: Fog-L. front | Turn Signal f&r | Brake L. | Reverse L. | Rear L. | Rear Fog L.
Skyhigh1976.50 |
08-17-2020, 03:15 PM | #24 |
Rep 1,934
Since the 340mm rotors already have less mass and thermal capacity than the 370mm counterpart, is it safe to say that floating or semifloating rotors would have even less? (All things similar in upgraded brake pads and fluid)
08-19-2020, 10:06 AM | #25 | |
Rep 320
08-20-2020, 05:52 AM | #26 | |
Rep 603
https://mtbphd.com/2019/08/18/3-reas...20temperatures. Ok, that's probably not a killer reason to go from 340 to 370 rotors. (But it is almost 10% gain in lever arm however) But if you look at the entry level 312mm front rotor for some of the F3x cars, the advantage for the 370 rotor would be about 20% lever arm gain.
08-21-2020, 06:33 PM | #27 | |
Rep 320
The 312mm rotor setup uses floating calipers...so going to a 370mm setup, it would be impossible to not have an impact. sorry, i'm still not convinced. |
08-22-2020, 05:14 AM | #28 | |
Rep 603
But I found another one: https://ebcbrakes.com/how-to-choose-...big-brake-kit/ Braking Torque = 2µFr Where µ = friction coefficient of pads, r = torque arm radius of pad on the rotor (which is taken as the midpoint on the rotors pad track), F = force applied by brake caliper (NOTE: the constant 2 comes from the fact that the caliper force F clamps the pads onto both sides of the brake rotor) From this equation it can be seen that: - Use of a higher friction brake pad = higher braking torque (EBC’s speciality) - Fitment of a brake caliper with larger clamping force (i.e. a caliper that uses larger pistons) = higher braking torque - A larger torque arm radius (i.e. fitting a larger brake rotor) = higher braking torque . . . The torque arm radius r is determined by the size of brake rotor fitted convinced?
08-26-2020, 09:24 AM | #29 | |
Rep 320
Again here, this article is just saying that a larger rotor increases brake torque. there is no demonstration or evidence to suggest it in the article. They do however mention that what does increase brake torque...the friction material of the pad and clamping force (ie. caliper piston size). They go into this in good detail. what they didn't do was provide details on how a larger rotor contributes to increasing brake torque. They also mention nothing about the extra rotational mass that comes with mounting a larger rotor and whether or not it negates the benefit with respect to brake torque. I wasn't sure if i was reading a fact sheet on brakes or an EBC marketing pamphlet...good read none the less. thanks for posting it! Last edited by brigade24; 08-26-2020 at 09:25 AM.. Reason: claritin clarity |
08-26-2020, 04:39 PM | #30 |
Rep 891
I have tracked on my 312mm single piston brakes for years with SS lines, pads and fluid. I have not been able to overdrive the brakes before I overdrive the tires and I haven't even touched the stock cooling solution. The only F30's that ever saw NA competition were on the single piston setup with PFC pads and cooling ducts.
Always always always exhaust those upgrades before adding more unsprung mass to the vehicle. Try a uni/monoball front control arm bushing to remove braking deflection and increase feel. I have had the EBC Reds and Yellows on my car, I would not suggest either of them. The yellows literally fell apart with track use. Their brochure that is being spoken about above is accurate, though. As the distance of a force applied from the center of a rotational mass increases torque is multiplied. Thank Newton for that one! Now is it worth the increase in unsprung weight? It can be. The kit bolts up to every F2/3 but there is a very wide range of weight and power on F2/3X. My 328 with aftermarket wheels is around 3300 pounds, many models are around 3800.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
08-27-2020, 03:50 PM | #31 | |
Rep 24
MacklinUSOB519.00 |
08-28-2020, 12:00 AM | #32 |
Rep 1,154
I am curious which tracks have you been running ? Road América would boil my nissans brakes pretty easily. Thus I upgraded this car that makes around the same power, but weighs 1100 pounds more.
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block Build Thread: https://f30.bimmerpost.com/forums/sh....php?t=1742413 IG + YT: Sqwin_n20 |
08-28-2020, 07:20 AM | #33 | |
Rep 603
But if you don't belive in physic formulas, I don't know how else to convince you then. You are right, that the weight of the rotor has it's down sides. In general the more rotating mass you have to stop, the more force you need. (The flywheel in a car on the other side uses it's rotating mass as an advantage. But in a brake rotor, you actually don't want that.) That's why you see many sports cars also with compound material or carbon rotor. They bring down the rotor weight (less unsprung mass, less rotating mass) AND have thermal advantages as well. (not only rotor, but the whole brake unsprung mass, like calipers and brake pad) But I'm with you, every change/setup will give some effects/results. Depending on what you would like to achieve, one or the other setup decision could be positive or negative with respect to what you want to achieve.
WrxToBeamerGuy516.00 |
10-14-2020, 12:07 PM | #35 |
Rep 891
Not a fan of slotted and dimpled rotors but I have run Zimmerman blanks on all of my BMWs and never had an issue.
10-14-2020, 01:09 PM | #36 | |
Moto Lover
197
Rep 604
Drives: '19 BMW S1000XR
So it's either R1 Concepts Carbon Geomet slotted or Zimmerman slotted with dimples. Stoptech is asking too much for something that I don't think will perform better than the rest. |
