05-31-2017, 09:38 PM | #419 | ||
Rep 1,425
05-31-2017, 10:21 PM | #421 | |
Gettin It Figured Out
1823
Rep 2,669
Have you/did you notice any drop in your AI (Avg Ign)? .
06-01-2017, 01:54 AM | #422 |
Rep 488
Any ETA on when we will start seeing tuners on the list?
2013 ActiveHybrid 3 (335ih) • N55 PWG • Meisterschaft GT catback • Wagner tuning catless DP and Stage 2 Evo Comp Intercooler • ER chargepipes • CTS intake • io2V3 O2 simulator • Pure Stage 2 turbo with high-flow inlet and DV upgrade • Fuel-It Stage 2 LPFP • JB4 ISO firmware • Fuel-It DIY PI Kit • bootmod3 •
06-01-2017, 08:28 AM | #423 | |||
Rep 1,862
Drives: powered by bootmod3
"Avg ign" is a JB4 feature where it monitors timing and compares to an assumed timing curve which is preset for the stock flash timing map which doesn't apply with a BEF on the car as the timing maps are changed. It'd be nice if Terry added a screen to change those "expected" timing settings to make that useful again. Very soon |
FSociety3816.50 |
06-01-2017, 10:21 AM | #424 |
Modder of everything I own
147
Rep 491
I am a noob with the BM3 backend flash. Currently my 2013 335xi F30 N55 has a catless dp, jb4 (currently using map 7), charge pipe (of course lol), CAI and Active Autowerke FMIC . In addition I am running 93 octane with 50% ethanol. The actual ethanol percent is actually unknown since at the pump they are allowed anywhere from 50% to 84% ethanol content (e85 my ass!). I do get a boost in the ethanol content because the station has 10% ethanol in the 93 octane. Eventually I would like to upgrade my turbo from stock but not in the near future.
I have read a lot about it and will continue to. What can I expect to gain from the BM3 flash and a custom map? I haven't dyno'd yet. Thank you!
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
06-02-2017, 12:42 AM | #425 |
Rep 111
Drives: 18' X5M
so i had SSR installed bootmod3 about a month or 2 ago.. so how do i go about getting the burble.. my f30 is pwg.
06-02-2017, 02:58 AM | #426 |
Rep 2,379
06-02-2017, 06:42 AM | #427 |
Rep 2,651
Send a support ticket to PTF and state you want the PWG burble applied to whatever map you're running. They remake a OTS map for you and add it, then send it to you.
FSociety3816.50 |
06-02-2017, 07:29 AM | #428 | |
Rep 1,425
06-04-2017, 02:23 AM | #429 |
Rep 1,693
Excellent. That's a fair bit of headroom and you're going pretty darn fast by the time you end up in 6th. Yep I saw that 6th gear has a lower limit than the others on another 8HP ROM, just like 5th on the 6HP.
06-04-2017, 12:23 PM | #430 | ||
Rep 305
Anyone know what logs we are suppose to run for new file builds, the parameters that need to be running? I was told default, but my defaults don't have what is being requested from PTF. |
06-04-2017, 12:56 PM | #432 |
Rep 305
Well I just have the OTS file for 91 oct stage 2, never requested anything special and it has burbles and gunshots. I don't believe pwg cars need any special file to have that. They just need open exhaust to get it, but I could be mistaken.
06-04-2017, 01:26 PM | #433 | |
Rep 1,425
I was recently browsing the PTF site looking to order a custom tune and I saw burbles being an option that is in beta. It reads, "N55 PWG (BETA Agg)." |
06-04-2017, 02:07 PM | #434 |
Rep 305
Interesting, I wish I could get mine to tone down, it's really excessive.
06-04-2017, 07:58 PM | #435 | ||
IG @bmwF9xG80
3817
Rep 7,595
https://services.bootmod3.net/log?id...0-0d8ea6f40858 When you logging any given map, 30-100mph in sport+ or dsc off is what you should be logging or wherever you want the certain tweak/improvement specifically. Quote:
https://bootmod3.atlassian.net/servicedesk/customer/
60-130 6.5s X4M
60-130 5.04s G80 M3 Stock Turbo 60-130 4.82s | 9.4@148mph 1/4 Hybrids IG: @bmwF9XG80 |
06-05-2017, 03:04 AM | #436 | |
Rep 2,379
Pic1: Here you can see the DME_BT drop trying to limit torque but as JB4 is in control of the boost that doesn't do shit... Pic2: Shifting into 6th at high enough rpm will not create enough torque so there you should be good
(A Dane in China) |
06-05-2017, 06:18 PM | #437 | |
Rep 305
06-06-2017, 09:22 AM | #438 | |
Rep 1,252
Docrace 6266
06-06-2017, 09:33 AM | #439 | ||
Rep 1,425
06-06-2017, 12:24 PM | #440 |
Rep 1,862
UPDATE:
0.9.15 version of the iOS and Android apps are out along with an update on the web. If using the web please make sure you clear the browser cache to get all the latest changes. |
