12-22-2020, 06:06 PM | #5721 |
EstateyMatey
351
Rep 58
Yes, I should have been more specific - holding home, holding back, pressing back or home (any combination of buttons) doesn't take you back to CarPlay. I assume this is probably due to the fact the MMI unit thinks its already displaying CarPlay whilst cutting to the PDC radar feed.
2015 Estoril Blue 320d F31 Touring | IG: @f31bert
12-22-2020, 06:51 PM | #5722 | |
Rep 42
12-22-2020, 09:56 PM | #5723 |
Rep 98
Which one should I order if I have a 2013 328i n26 but I have the CIC system (i think) & 8.8" (im pretty sure) display.
My head unit I think this menu means I have the CIC version
2013 F30 N26. FBO Stage 2.
12-22-2020, 11:45 PM | #5724 |
Rep 20
Hello all,
I recently installed an Andream B MMI box on my 2016 f30 with NBT evo ID4. I'm using android auto, and my phone is on android 10. Lot's of quirks with this box. Andream customer support has been useless. Can anyone offer any help for the issues i'm having? Audio quality is sub par. it's not the worst, but being used to my HK, it's a noticeable downgrade in sound quality. Phone call volume is almost silent. Turning the volume up or down does not control the call volume. How do I turn call volume up? The screen in google maps has "shadows" around the letters and icons. not necessarily pixilated, but shadows that come and go as if it's a resolution issue. Is there any way to fix this? Every time I start my car, it boots to iDrive. not AA. I can't find a setting to fix this, is there one? Finally, and most annoying bug... Google maps won't automatically switch to night mode. My phone switches back and forth just fine, but not google maps in AA. I've enable the developer settings in AA and tried to let the car switch, then tried to let the phone switch to no avail, it stays in day mode at all times. The only way I can get it into night mode is to change it manually to night mode every time. Is there a fix for this? Will the MMI obey dark mode on my phone if I toggle it there? I've asked Andream to return this, as i'm very dissatisfied with the bugs. I can't believe they would release a product this full of bugs. Andream Customer support has stopped answering me. Last edited by kaylee.s; 12-22-2020 at 11:54 PM.. |
12-23-2020, 12:23 AM | #5725 | |
Rep 1,217
But the audio quality will likely be the same across the board. It's more than good enough for me but I'm not very discerning when it comes to that. Regarding phone call volume, I believe that all of these units now have a setting to use the oem bluetooth connection instead of the mmi bluetooth. Make sure that setting is checked and that should resolve that issue. The automatic night mode switching is a problem with all of the units using AA except for Bimmertech. Bimmertech switches to night mode when the headlights turn on. You may want to consider selling the Andream unit and purchasing a Carlinkit unit instead. It's compatible with the custom software on page 1 which is based on the Bimmertech software. It works much better with AA. |
12-23-2020, 01:54 AM | #5726 | |
Rep 31
The best way to confirm which unit you need it to check the port behind the display, I bet it's a 6 pin (NBT). If it's 4 pin (which is extremely unlikely) then you will need CIC. Hope someone else can provide a definitive answer. Alternatively you can ask the seller and they can confirm.
BMW F20 - Dec 2013 - N13 - NBT | Road Top CarPlay/MMI | iPhone 11 Pro | Aftermarket Rear Camera with OEM PDC | London, UK
edm0nd23.00 |
12-23-2020, 04:09 AM | #5727 | ||
Rep 79
Dont know if this helps but if you enter your vin here it shows u what HU you have. https://bmwcodem.com/pages/check-vin Grts |
edm0nd23.00 |
12-23-2020, 04:50 AM | #5728 | |
Rep 24
I have no problems with sound quality, sound quality is the same or better as through the normal bluetooth connection. Phone calls were awful until I set it to use car's bluetooth - there is an option in settings. You need to have the connection to car's bluetooth set up (I also disabled media through bluetooth in original radio, let only phone calls profile connect). I do not have problem with calls being too quiet since then either. The quality is great. Shadows - yes there is a problem when you are on white screens. As for google maps I set them permanently to dark mode (inside the google maps settings, it was a one time setting) and use them this way. I was unable to change day/night on Waze. Bottom line, when using friends iPhone and Carplay I discovered zero problems. Even phone calls were reportedly of higher quality... |
Cruez3.00 |
12-23-2020, 07:59 AM | #5729 | |
Rep 383
This is the only real difference in the boxes, so it’s the surefire way to tell. It doesn’t actually matter if your head unit runs the CIC or NBT software. Just ensuring the wire connections are the correct plugs/outputs. Last edited by SuperLomi; 12-23-2020 at 08:05 AM.. |
edm0nd23.00 |
12-23-2020, 10:19 AM | #5730 | |
Rep 20
12-23-2020, 03:15 PM | #5731 |
Rep 129
Automation rules in iOS are no longer working since 14.3
I described issue here: https://discussions.apple.com/thread/252212356 In overally - you cant automate execution of application, for example if you want to run automatically waze, spotify etc while connecting to Carplay. |
12-23-2020, 10:08 PM | #5732 |
Rep 48
You need the NBT, I have the same head unit, car and year. It'll say CIC-High when you open it up, but these have the same 6 pin connectors the NBD uses
12-23-2020, 10:40 PM | #5733 |
Rep 313
Drives: 2014 bmw640gc 2015Mercedes e40
I definitely would if you could..I'm running a carlinkit with the update firmware, [much thanks to muniz for helping me out ] running Android auto and I love it.. aside from learning the small quirks here and there it's pretty much best 200 I've spent on my f06 and runs pretty much flawless
12-24-2020, 01:47 AM | #5734 | |
Rep 17
I saw you posted it also in reddit. Keep us updated especially if you find a possible work around. For the time being I will stay on 14.2 ! Strange to not see more reactions as this is/was a useful feature ! |
12-24-2020, 10:57 PM | #5735 | |
Rep 36
12-24-2020, 11:00 PM | #5736 | |
Rep 36
12-25-2020, 01:56 AM | #5737 | |
Rep 59
Let me know if you are interested in this idea. |
12-25-2020, 09:23 AM | #5738 | |
Rep 36
12-25-2020, 04:41 PM | #5739 |
Rep 129
Pls bump it, mark, like if you can. Surely alone i will not get devs attention
12-25-2020, 05:08 PM | #5740 |
Rep 3
Hi everyone,
After I have read all the posts (nearly) I have decided to buy one for me. So if I understand correctly, there are two versions. One old A version and the new B version. I need it for AA, and it seems that the old version is better for this? I have the CIC system. Are there also two versions? Thanks! |
12-25-2020, 06:29 PM | #5741 |
Rep 15
Hi everyone.
I have got Andream CIC unit from June and everything is doing well. But from last few days I have noticed that I-drive screen started to flickering when I start car in the cold morning or night, but it was blinking only in original idrive mode, no in carplay mode. After few miles it stops to flickering and everything is backing to normal state. Do you have any idea what is the problem? |
12-25-2020, 06:30 PM | #5742 | |
Rep 15
Okmr0.00 |
andream, android, android auto, apple, carplay, mmi, retrofit |
