06-10-2016, 04:41 PM | #45 |
Rep 191
Drives: 2013 BMW 335i M-Sport
mine broke at the TB today while driving to lunch. I'll have BMW come get the car tomorrow.
But I have a question. This charge pipe looks to be a solid piece of brittle plastic that directly connects to the TB. No silicone boot with t-bolts... no rubber, nothing. just direct connects, hard part to hard part. Down at the intercooler, is it a direct plastic to intercooler connections as well? Is the intercooler mounted to the chassis? What I actually think is happening (and I may be off my rocker) but the combination of the stop/start of the motor, plus the twist of the motor in everyday motoring, could be putting too much stress on the connection area (s), thus the cracking. Perhaps this explains why stock cars have this problem as well... I don't know.
2013 335i M-Sport 8spA
2011 M-B GLK350 2000 Dodge Ram 2500 QC 4x4 CTD |
06-10-2016, 10:17 PM | #46 | |
Dejan
1755
Rep 4,197
Drives: 2018 Audi S3
Could be the added boost or the theory you just posted. Either case the failures are real.
FBO-PS1 and stuff
06-15-2016, 09:45 PM | #47 |
Rep 166
This is painfully difficult for me to do because I hate being wrong, but I know when to eat crow and now is that time. You were all right, and I was wrong, I concede defeat, my charge pipe blew tonight. Luckily I was only a mile from home so I could easily limp it home.
Let me have it, I deserve it. Mike - You warned me and I did not listen, therefore you are the first person I am reaching out to for a replacement, you should have an e-mail in your inbox from me. |
06-15-2016, 09:47 PM | #48 | |
Gettin It Figured Out
1823
Rep 2,669
Need a hug? . .
06-16-2016, 07:17 AM | #49 |
Rep 166
06-16-2016, 07:19 AM | #50 |
Rep 166
So, more information on what failed..
My assumption was that the pipe failed due to OUTWARD pressure perpendicular to the throttle body, thus my logic for reinforcing the clip. However, that is not the case, the additional pressure pushes the charge pipe AWAY from the throttle body, putting significant stress on the very thin plastic edges of the charge pipe, there truly is NO WAY to reinforce that area, especially when running 18.5 psi on Map 7 |
06-16-2016, 08:35 AM | #51 |
Rep 116,037
06-16-2016, 08:36 AM | #52 | |
Rep 116,037
Mike |
06-16-2016, 09:15 AM | #53 |
Rep 166
I do! As with most others, it failed at the throttle body. I estimated that, at 3 inches in diameter (7 sq in of surface area), the outward pressure at 18 lbs of boost is approximately 126 lbs of force being held by the very thin pieces of plastic on the sides of the charge pipe, that is why it fails. In fact, it the blowout was so forceful that it separated the bracket on the pipe from the mounting bracket on the motor (sorry, didn't take a picture of that).
06-16-2016, 10:10 AM | #55 |
Rep 166
06-16-2016, 10:42 AM | #56 |
1-800-STOCKAF
157
Rep 386
During my times with a stock charge pipe, i was lucky to not have my stock charge pipe blow on me. When i had my stock charge pipe, i had jb4, catless downpipe, mpe exhaust, with bms intake. I ran map 2 then went to map 5 with e30 mix, did full throttle pulls from dig, burnouts to full throttle exit, pulls from 2nd, 3rd, brake boosting, etc without any issues. One day i found a charge pipe with anodized coat for good price so i took that, and installed it myself without a problem. Def. Recommend purchasing a chargepipe. When comparing the two, the er chargepipe helps my car run a little cooler compared to the stock one. Also it helps me drive hard without having myself worry about my stock charge pipe.
06-16-2016, 11:20 AM | #57 | |
Rep 2,651
I won't tell you "I told you so" (lol just did) but I hope you take our advice and the sponsored vendors on here, most of us are here to share our builds, stories and get advice and help on certain parts to improve our cars. But other than that, there's a reason why all cars who run high boost have a full metal system to make sure they get the most airflow and nothing will explode. |
06-16-2016, 11:50 AM | #58 | |
Rep 166
I appreciate the continued support, this forum has been a wealth of information for me from my previous E90 335i through now, I should heed the experience and advice from others rather than assuming I know better. |
06-16-2016, 12:03 PM | #59 | |
1823
Rep 2,669
06-16-2016, 12:36 PM | #60 | |
Rep 2,651
Other than that, Since you're running 18.5psi, did you upgrade your DV and get a TIC chargepipe? Might as well do both at the same time as the it'll help give you constant boost. |
07-16-2016, 04:23 PM | #61 |
Rep 464
Modified T-Clamp for lightly boosted
I have been running the MPPK for about 5 months and a couple of days ago I added the Dinantronics SPORT (set to Sport+)
I did not feel the need to upgrade the charge pipe for the MPPK and my charge pipe has been fine for the 5 months I have had the MPPK installed. I totally forgot about the charge pipe when I added the Dinantronics SPORT. As an interim measure, I installed a modified 4" T-clamp to reduce the point loads on the plastic charge pipe at the c-clip/lock clip. I will try this setup until the OEM charge pipe fails. Larry
2020 Black Sapphire M340iX
2014 Estoril Blue 435iX - sold |
07-16-2016, 07:31 PM | #62 | |
Rep 116,037
I personally would remove that clamp ASAP. Mike |
07-16-2016, 07:59 PM | #63 | |
Rep 2,651
Why can't people not be cheap and just buy the damn ER chargepipe? It's literally a cheap 3-400$ fix, yet people are cheaping out on their 50k car, like really guys? Do people not learn from other's mistakes? Read up at that guy who tried to reinforce the chargepipe and failed. |
07-16-2016, 08:18 PM | #64 |
Rep 464
Thank You Mike for your reply.
I did not realize the charge pipe required some play with the throttle body. I thought the design of the pipe (ie. corrugation) would accommodate for vibration and engine movement. I have removed the t-clamp. Thank again! Larry
06-27-2018, 02:46 PM | #65 | |
Rep 312
06-27-2018, 02:58 PM | #66 | |
Rep 1,288
