12-31-2023, 02:10 PM | #67 | ||
Rep 1,155
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block Build Thread: https://f30.bimmerpost.com/forums/sh....php?t=1742413 IG + YT: Sqwin_n20 |
12-31-2023, 10:08 PM | #69 |
Rep 2,686
Yup.
If you guys support a guy who's basically lying out of his ass and saying his product outperforms the competition and then says his R&D is miles ahead of the competition where his competitors have literally out sold his product for the last few years, idk what to say. He doesn't even make B58 turbos and he says his R&D is miles ahead lmao.
johnung4947.00 |
01-01-2024, 08:07 AM | #70 |
Rep 883
https://www.on3performance.com/shop/...-turbo-system/
What about this turbo kit? I saw someone elsewhere mention its capable of 700hp on an N55, but their page says about 500ish. And what do you do about a wastegate on an EWG car? |
01-01-2024, 08:40 AM | #71 | |
Rep 2,686
01-01-2024, 02:15 PM | #72 | |
Rep 1,155
As frankenturbo is based in Portland, OR, public record show the company filed for bankruptcy a handful of times if you really want to dig into those public records. This isn't new info, but for people who didn't know, the F30 n55 turbos are based on the Borg Warner efr series. Really and truly the stock turbo are a efr 6255 turbo. the smallest efr is a 6258 and on paper flows 43-44 lb/min. thus 430-450whp should be possible on e85 with the stock turbo and all supporting parts. Dyno have shown just under this as the bmw turbo is smaller. Most of these turbo upgrades used to be genuine Borg Warner turbine wheels and slowly overtime swapped over to the Chinese turbine wheels due to supply chain issues from Borg. Thus your "pure stage 2" is between a efr 6758 and 7163 turbo. thus on paper should make 530-570whp on e85. dyno results have shown these numbers. The newest "pure 750" is a efr 7163 spec'd turbine wheel with updated larger ar housing to allow for max flow + boost while not becoming a heat pump. On paper a efr 7163 is a 60 lb/min turbo thus 600-640whp should be possible in theory on e85. dyno results have shown these numbers. Would you trust a company that hits you with the razzle dazzle without any actual data other than being good with words + was good previously with the China game cover-up? Now they are being called out for their hypocrisy. Make a great quality product and show data or be pushed out of the game. take a gander at the YouTube video edit - fixed to say 6255 not 5255
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block Build Thread: https://f30.bimmerpost.com/forums/sh....php?t=1742413 IG + YT: Sqwin_n20 Last edited by sqwinny; 09-15-2024 at 08:46 AM.. |
01-11-2024, 05:47 PM | #73 |
@_sunbish
303
Rep 633
I don’t know why Audi and other data is brought up.
That is like saying, ALL BMW engines suffer from the same issues just simply because it’s an engine in a BMW. Let’s focus on facts and not on speculations or feelings. The quickest pure turbo n55 is Sixto on the n55 Facebook group. His F30 runs a 6.8 in the 1/8 mile, and the quickest n55+ car is a F10 and it runs the same 6.8 in the 1/8 mile with an additional ~300-400lbs of weight. I can you why, but even if I did more than half won’t understand it.
'14 435i RWD - BM3 stage 2+ E30/bolt ons/stock turbo/full drag pack -- [10.9@125].....60 to 130 - 8.5
'16 340i RWD - BM3 stage 2+ E50/bolt ons/stock turbo/full drag pack -- [10.2@131]......60 to 130 - 7.5 |
AmuroRay2851.50 |
01-18-2024, 01:20 AM | #74 |
Rep 2,686
Someone posted a 91 oct Pure750 dyno on the BMW N55 group.
Their M2 N55 made 470whp/500wtq on straight 91 only with Pure750. They said their E85 run is up next. |
01-18-2024, 07:33 AM | #75 |
Rep 4,977
For those of us who don't have FB, do you mind screen grabbing or posting it here?
01-18-2024, 08:54 AM | #76 |
Rep 2,686
Np
01-19-2024, 01:15 PM | #77 |
@_sunbish
303
Rep 633
Did they ever find the dyno sheet?
09-13-2024, 02:11 AM | #78 |
Rep 5
09-13-2024, 03:02 PM | #79 | |
Rep 925
Drives: 2015 BMW X1 35i M-sport
09-14-2024, 02:21 PM | #80 |
Rep 5,810
I had a conversation with Dorch about fueling upgrades for the Pure750. It’s completely different depending on whether you intend to use 93 Octane or full E85.
The N55 engine itself is octane limited (as opposed to turbo limited) to roughly 500whp when using 93 Octane. There are only so many molecules that can be crammed into those cylinders, so you can reach a point where it doesn’t matter how big the turbo is. The much smaller Pure500 can do 460whp using 93 Octane so its logical to assume that both the Pure600 and the Pure750 will reach the octane limited N55 maximum of roughly 500whp using 93 octane. The larger Pure750 will obviously perform higher than the Pure600 using ethanol mixes. Pure has the P750 maximum rated at +50whp more than the P600. To get that 500whp using 93 Octane does require a HPFP upgrade. A Dorch Stage 1.5 may suffice, but I’d recommend a Dorch 2.5 to have available upside, especially to test low ethanol mixes. The stock LPFP and stock fuel injectors should be fine. Two cars with a Pure750 using full E85 have dyno’d at 650whp and 670whp. (Please keep in mind that >600whp is supposed to risk breaking engine and drivetrain components.) The fueling requirements for Pure750 using full E85 are hefty: Dorch Stage2.5 + 38% Dorch Lift Kit Bosch M5 S63 Injectors (sold by Dorch for customer convenience) Using ethanol mixes the stock injectors max flow at roughly 520whp. Precision Raceworks Dual Pump LPFP upgrade with primary Walbro 535 and secondary Walbro 525 hanging off the bucket. Have PR custom straight through wire both pumps with 6 feet of wire slack and no Hobbs Switch. ET3 Design Stage4 EKP Upgrade. Wire both pumps to Stage4 EKP so they are directly controlled by the DME. This configuration reduces complexity and eliminates the BMW problems of overheating, scorching and melting at the EKP/LPFP BMW wiring connectors. The above fueling configuration is good for 750+whp using full E85. Assuming the Dorch Stage 2.5 will be purchased to use 93 octane, the Dorch Lift Kit and other fueling components to use full E85 would cost about $3,000 for parts plus labor. Hope this helps! |
09-14-2024, 03:39 PM | #81 | |
Rep 925
CalvinNismo60.50 |
09-14-2024, 04:14 PM | #82 | |
Rep 883
09-14-2024, 04:21 PM | #83 | |
Rep 5,810
09-14-2024, 04:26 PM | #84 |
Rep 5,810
My understanding is that forged internals or not, makes no difference. It’s a cylinder volume thing. I was told that the limit line could be moved by changing that volume by boring out the cylinders and changing the compression ratio, obviously changing the physical parameters of the octane limitation. Seems like a huge expense for not so much whp return. If I didn’t have E85 available, might be worth buying some E98 to add sometimes.
09-14-2024, 05:28 PM | #85 | |
Rep 925
johnung4947.00 |
09-15-2024, 04:30 AM | #86 | |
Rep 93
See Pure’s own website: https://www.pureturbos.com/product/b...-stage-2-plus/ |
johnung4947.00 |
09-15-2024, 09:00 AM | #87 | |
Rep 1,155
The b03 Borg Warner turbos on the f30 335i are .60 ar size for ar ratio + 6255 size thus would be on par minus maybe 1-4 lb/min flow but this is an estimation. data for your comparison: efr 6258 compressor map and specs: https://cdn.borgwarner.com/docs/defa...sn=595bb03c_17
09-15-2024, 09:02 AM | #88 | |
Rep 1,155
Side note for those reading for information, with only pump 93 octane you are octane limited. most tuners even in the 4 cylinder world will refuse to tune for more than 21-22 psi on pump 93 (98 Ron) due to pump fuels being very variable with its quality and you can only force so much combustion into each cylinder to generate power with safe limits. Ideally this is why most folks run methanol injection to use as a supplementary fuel + raise octane levels which allows for more boost + load = more power generated.
johnung4947.00 |
