09-13-2022, 12:49 PM | #10803 |
Rep 499
09-14-2022, 11:56 AM | #10804 | ||
Rep 173
x-m4n145.50 |
09-15-2022, 10:20 AM | #10805 | |
Rep 94
09-15-2022, 10:59 AM | #10806 |
Rep 8
Hi guys
I have a BMW F20 and I have recently purchased Carplay box from aliexpress for the NBT unit (mine is CIC but with NBT cables), there is a problem with the screen can somebody help me plus the Carplay won't connect there is only Bluetooth symbol on the left side, only Airplay works... |
09-15-2022, 01:02 PM | #10807 | |
Rep 499
09-15-2022, 02:36 PM | #10809 |
Rep 199
Does anyone have the pin layout for the quad lock?
I installed an mmi unit for an f30 with pro nav nbt (had pro nav so box had to be located elsewhere) and all was working well. But soon as tried to refit the headunit with quad lock there is not much space so spent a bit of time trying to wiggle it around. Finally got it all in,the headunit would not work. Changed over the quad lock and it’s working again so must’ve damaged a wire in the wiring loom of the mmi quad lock. Any suggestions on which wires to check over and fix it? |
09-15-2022, 06:32 PM | #10810 |
Rep 1,217
When it works it seems to only work on mcu files.
But you should be able to force flash the ispbooot.bin file by pulling the power plug from the mmi, inserting the usb drive containing the ispbooot.bin file, then holding the idrive back buttons while simultaneously plugging the power back in. After about 20 - 30 secs, while continuing to hold the back button, you should then see the update screen. |
yulian56.00 |
09-16-2022, 01:21 AM | #10811 | |
Rep 2
09-16-2022, 01:49 AM | #10812 | |
Rep 94
I just want to try everything before unscrewing dasboard. Last edited by yulian; 09-16-2022 at 06:08 AM.. |
09-16-2022, 04:19 AM | #10813 |
Rep 71
Hi, i installed a Andream in my F30, 2015 but 1 out of 3 times i have no sound at startup.
Reboot (3 sec. back button) solves this, but i wander if there is a software update. But i am not sure witch update i need. https://ibb.co/3zHF8tv https://ibb.co/0sTW4mk |
09-16-2022, 01:41 PM | #10814 |
Rep 14
Can’t seem to understand which update is for my model.
I got a 2015 f56 mini cooper with model bmw_nbt2_1_g hw version 21.6.7.116 and cust version b2r162 Should i update to roadtop b2 latest version? Does someone knows by any chance? Last edited by justenx; 09-16-2022 at 01:49 PM.. |
09-17-2022, 01:47 AM | #10815 | |
Rep 14
Or maybe we can start a discussion here for everyone to see. Just started unpacking & reversing the binary. There’s some interesting stuff in the squashfs filesystems. Did you try to port scan the system? Unfortunately I don’t have a laptop available. |
09-17-2022, 08:01 AM | #10816 |
Rep 22
If it accepts 8032 as the PIN, then yes, that is the RoadTop B2. Whether or not you feel the need to update it is your call.
09-18-2022, 11:46 AM | #10817 |
Rep 93
Has anyone had problems with their Carplay not working correctly after updating to iOS 16? I can't navigate the menu when entering the Spotify or Google Maps app (probably more apps as well). The knob works when not in an app, so in the main menu with the app icons etc.
09-18-2022, 04:00 PM | #10818 | |
Rep 15
09-19-2022, 04:05 AM | #10819 |
Rep 93
I updated to the newest MCU and did a reboot of my phone, seemed to have worked. I still get the missing sound issue sometimes, where I have to reboot the box before AUX seems to work.
09-19-2022, 06:23 AM | #10820 |
Rep 24
Did you get an answer to this? I'm not sure whether this is required to prevent noise or if it is not necessary at all on NBT EVO.
09-19-2022, 06:31 AM | #10821 |
Rep 11
Guys,
Is it possible to plug a firestick directly into the hdmi port and power via USB? Would this work over the hdmi selection within the mmi box or are extra converters needed. Has anyone installed a firestick through the mmi box? |
09-19-2022, 07:30 AM | #10822 |
Rep 340
I'm sure someone will correct me, but I was under the impression that a Firestick needs to be actively connected to your home wireless network to function correctly, but I could be wrong. Also I was also under the impression that the cars USB socket would be unable to output the power necessary to make the Firestick operate, but the MMI's connection might. But that's only if you can overcome the problem of your home network being out of range when you drive..if there is even a setting that uses it.
09-19-2022, 08:53 AM | #10823 | |
Rep 71
A reboot fixes this. Iphone 13 pro, IOS 15 and IOS 16 Anyone a solution ??? |
09-19-2022, 01:34 PM | #10824 |
Rep 8
Hey, guys
Sorry for interrupting again I really need help to solve my problem, so again my screen is on half everything is connected carefully step by step, tried everything nothing works.(see video) https://we.tl/t-tDjdhcWv1B? KJ-NAVI CAR Store aliexpress(do not buy from this seller!!!!!) told me that I need to update the software, he send me a link to download the file I have tried but it says burn failed, contact the factory... Also, the wifi and bluetooth are connected and the carplay is not working, the only thing that is working is AirPlay. (sorry for my bad English) Last edited by staklopanevi; 09-19-2022 at 01:46 PM.. |
andream, android, android auto, apple, carplay, mmi, retrofit |
