04-19-2018, 01:50 PM | #1189 | ||
Rep 180
04-19-2018, 04:46 PM | #1190 | |
Rep 191,521
We can offer you the map with a free cable and all you need to is connect it to your OBD and load the file we send you
deezeedee33532.00 |
04-19-2018, 04:49 PM | #1191 | ||
Rep 180
04-19-2018, 04:51 PM | #1192 | |
Rep 191,521
I will be more than happy to help
04-19-2018, 04:53 PM | #1193 |
Rep 180
Alright cool sounds good I appreciate it
mike@x-ph.com24527.50 |
04-19-2018, 05:43 PM | #1194 |
Rep 136
How do we see what progress has been made for PWG ‘13 BMWs? Saw a post a in March saying burbles were still being worked on... can anyone with a 6 spd, PWG f30 chime in
04-19-2018, 06:02 PM | #1195 | |
Gettin It Figured Out
1823
Rep 2,669
Most updates are posted to their Facebook Page .
04-19-2018, 06:28 PM | #1196 |
Rep 529
Oh good lord don't pop up on the Facebook group asking bout no damn burbles! lol
2013 F30 335i xDrive M-Sport 6MT (FBO/BM3 custom tune by HCP, 91 oct, 550i clutch, xDelete)
04-19-2018, 06:33 PM | #1197 | |
1823
Rep 2,669
LOL!! .
04-19-2018, 08:35 PM | #1198 |
Rep 1,693
04-19-2018, 10:37 PM | #1199 | |
Rep 2,651
Literally Halim was releasing updates for power and boost control and shit and all people paid attention to was burble. |
04-20-2018, 06:59 AM | #1200 | ||
Rep 180
deezeedee33532.00 |
04-20-2018, 07:04 AM | #1201 |
Rep 1,499
I honestly think the AGG burbles are a bit ridiculous. The burbles on the Stage 2 tune are perfect in my opinion but to each their own.
BTW...doesn't it seem to you that the AGG burbles would be really bad on the engine. Just curious.
04-20-2018, 10:49 AM | #1202 |
Rep 180
I don't know if it's bad I have heard that somewhere. But yeah I like the stage 2 burbles. I haven't heard the aggressive yet but I probably would like it.
04-20-2018, 11:11 AM | #1203 |
Rep 971
Drives: 2016 F36 435x MSport
It technically shouldn't damage the engine. Burbles are caused by fuel overrun, i.e. injectors still in duty phase when you let off the throttle. Timing is retarded a bit, fuel doesn't fully combust in the cylinder, but instead moreso on the way out.
The damage would really be downstream depending on exactly how much overrun there is. I.e., cat's and lambda sensors, maybe even some packing within silencers/mufflers if you have enough overrun and enough EGTs to create some flames. pew pew.
2010 Mazda RX8 - Sold (11/17)
2016 BMW 435xi GC - Current |
04-20-2018, 11:34 AM | #1204 | |
Rep 180
04-20-2018, 11:54 AM | #1205 | |
Rep 1,499
Don't you think it would be at least suspect having combustion in the turbo?
04-20-2018, 12:06 PM | #1206 | |
Rep 971
totally off topic since we arent looking to do turbo rebuilds every month lol, but most race classes actually leverage overrun to keep the turbo spooling between shifts and off trottle apex lead-ins
04-20-2018, 12:14 PM | #1207 | |
Rep 1,499
ah....interesting!!
After some research into how ALS works I came across this post on Piston Heads regarding ALS in the rally world and it's application to road cars. "it's totally possible, but yes, not really recommended because: 1) any catalyst will be quickly destroyed, by either the raw unburnt fuel contaminating the catalyst, or more likely the raw unburnt fuel exotherming and simply melting the substrate. On the WRC the "cat" is a 100cell metal matrix device, and it is positioned at the tailpipe, (something like 3m from the engine!) and it is just there for "show" it loses all its catalytic capabilities after a single shakedown test!! 2) turbo durability: wrc turbos use a high-temperature stainless steel alloy that maintains it's mechanical strength at up to 1150 degC, a std road turbo will be scrap at about 1000degC. Turbine inlet gas temps of 1300dgC are not unusual during als operation (short period of operation means bulk turbine material temp is lower) Also the turbo bearing system needs to be VERY robust as turbine shaft speed and crucial axial thrust loads are massively transient. To withstand this a wrc turbo is pretty specialist, typically a TR30R garret wrc turbo is approx £9k ! 3) lack of engine braking during operation: depending on the throttle system and spark retard used during als operation, there can be a significant loss of engine braking, not a problem in a race/rally environment, but possibly an issue on the road 4) Exhaust system: any "packed" exhaust will literally have the stuffing blown out of it after a short period! 5) noise: as mentioned the police and your neighbors will not really appreciate the als as much as you! 6) it's quite easy to set fire to your rear bumper or even the cars underfloor plastic and underseal if the system is used and the car not allowed to cool before stopping! Of course the "agressiveness" of the als system is tunable (by the amount of bypass air, extra fuelling and spark retard) so a more "road friendly" calibration can be used to maximise turbo shaft rpm without actually breaking too much! Also, using a "pre-turbo" combustor (a-la scooby wrc) allows you to run an effective but much more durable als system, although thermal management is still a massive challenge at low speeds" Quote:
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI). SPI Films Blog/DIY Vids Last edited by JaredG_F30; 04-20-2018 at 12:41 PM.. |
04-21-2018, 06:12 AM | #1208 |
Rep 210
I’m in Tampa as well. Was running stage 1 until by CP blew, waiting for my aa cp to go fbo and stage 2. Ever go to the Tampa Bimmer meets?
michaelsoft1.00 |
04-21-2018, 06:30 AM | #1209 | |
Rep 180
