11-10-2013, 09:44 AM | #113 |
477
Rep 4,591
I'd be concerned about how well $800 coilovers would hold up to be perfectly honest.
11-10-2013, 12:13 PM | #114 |
Law Enforcer
26687
Rep 22,641
Drives: '22 Chalk Gray Porsche C2S
A photo was already posted (..page 3, post #52). If you want to see what the drop will be like, look for photos of any F30 on H&R Sports. The B8 shocks won't change the visual profile of the car.
11-17-2013, 12:46 AM | #115 | |
Rep 478
Vs the Bilsteins, owe it to yourself and your car to not get the BC. Not saying they're are bad but Bilstein is a better quality brand. If anything I would go with the Bilstein coilovers I linked for a little over 1k. I'm sure you can get it bargained down at a reputable local shop. Last edited by rxander; 11-17-2013 at 12:53 AM.. |
11-18-2013, 09:26 AM | #116 |
Diligentia Vis Celeritas
561
Rep 1,476
Drives: 335i
This thread is getting me thinking more and more about suspension options...
I have DHP, so the suspension in the Sport setting is not bad, but I'd definitely like something a little firmer to control body roll. I've been patiently waiting for the Dinan Shockware option (basically EDC tuning and stiffer springs), but I'm losing patience as I'm getting the feeling that Dinan isn't as close to releasing this as they've initially indicated... Plus, I'm wondering whether adjustable dampers are really what I'm looking for. Based on the premise that spring rates should be matched to a specific damper curve, how could any one particular spring work well with different damper firmness settings? (@Sedan_Clan, since you've owned a few cars with coilovers as well as M3s with EDCs, what are you thoughts on this?) At this point, in lieu of continuing to hold out for the Dinan Shockware kit, I'm considering Bilstein shocks / H&R springs, or the M Performance Suspension kit Or possibly just splitting the difference for the time being and trying M Performance springs on my current EDC Sport dampers. @shivaswrath, you upgraded to MPS, correct? Was this coming from DHP dampers? What are your thoughts?
11-18-2013, 10:31 AM | #117 | |
Law Enforcer
26687
Rep 22,641
It's definitely possible. If you look at your traditional coilover kit with adjustable rebound/dampening, that spring is designed to work within the range of adjustability of that shock/strut. Custom choosing the spring rates (...an option when you're buying kits from Ground Control, etc.) allows you to fine tune the amount of chassis stiffness you want, but the adjustable shock/strut is still designed to work with the fixed spring rate. I will be able to offer my feedback on the Bilstein/H&R combo on Friday. |
11-18-2013, 11:27 AM | #118 | ||
561
Rep 1,476
Drives: 335i
I'm starting to seriously consider getting a set of M Performance springs to go with my DHP dampers as an interim measure... minimal expense, and with a little bump stop trimming, the travel should be equal to stock but at a firmer spring rate (which would hopefully be more attuned to the firmer "Sport" setting range of the EDC damper curve.)
11-18-2013, 11:50 AM | #119 | ||
Law Enforcer
26687
Rep 22,641
11-18-2013, 01:47 PM | #120 | |
561
Rep 1,476
Drives: 335i
The springs that Dinan sells to match up with their Shockware are also about 10-12mm lower (based on what they currently offer for the 550s), so they're probably very similar to the MPS springs if I do eventually get their Shockware tune... or, I could always go the full MPS route and get the matching dampers.
11-19-2013, 06:48 PM | #121 | |
Rep 1,138
sent from bimmerpost Android app
11-19-2013, 07:05 PM | #122 |
Law Enforcer
26687
Rep 22,641
11-28-2013, 03:57 PM | #124 | ||
Rep 703
Drives: 2014 328d
2014 328d SportLine
11-29-2013, 10:13 AM | #125 | |
561
Rep 1,476
Drives: 335i
11-29-2013, 10:34 AM | #126 |
Rep 703
Drives: 2014 328d
Yeah, my memory got that mixed up.
2014 328d SportLine
11-30-2013, 10:57 AM | #127 |
Rep 13
I think this is my first time posting on this site but because my name got dropped I guess I gotta jump in. All I know about the whole Dinan thing is what the rep told me on the phone. I think his name is Scott. He said they were about 60 days from releasing a suspension tune and that they really liked the springs that come in the DHP cars. Thats pretty much all he said...
11-30-2013, 03:44 PM | #128 |
Rep 703
Drives: 2014 328d
Presumably the release date for stage 1 is only about 60 days away, so time will tell!
2014 328d SportLine
02-08-2014, 12:37 PM | #129 |
Rep 373
Drives: 320d M-Sport, X1, 525d
A bit off topic, but will the H&R Sports be compatible with the *B6* shocks? Will the car sit higher if I use the B6 with H&R Sports?
02-13-2014, 12:37 PM | #132 | |
Rep 933
'14 Estoril Blue II F30 - 335i - ZMM - ZPP - ZTP - ZPS -
2TP Traded 9-1-13 '13 Estoril Blue II F30 - 328i - ZMM - ZPP -ZDY - ZTB - 403 - 465 - 494 - 4DX- LC (Black) - 6NL |
