| 03-11-2026, 12:38 PM | #16149 | |
///M
702
Rep 2,228
Drives: '18 F80 M3 ZCP, '14 F30 328i
I did the sport seat retro a while back and honestly wish I had done it sooner now. I did the exterior swap about a year and some change ago, that’s been a labor of love, too. Same with the trim—a total vanity play. Maybe it adds 10 bhp at night with my rear euro fogs on.
F80 ///M3 '18 S55 / 6MT / ZCP / eventuri CF CAI V2 / CSF TMIC / Mosselman oil tstat / CSF engine oil cooler / CSF Auxiliary Coolers
F30 328i '14 N20 / 6MT / M-sport conversion / dinan sport kit / hex trim / HK sound / B14 coilovers / oem roof rack / active autowerke exhaust / eventuri CF CAI Successful Retrofits: 3AG, 4MR, 248, 417, 481, 508, 544, 688, 710, 760 |
rlesko473.50 |
| 03-12-2026, 12:23 PM | #16150 | |
///M
702
Rep 2,228
Aldor27117.00 |
| 03-12-2026, 07:15 PM | #16151 |
![]() ![]() ![]() ![]() 474
Rep 897
Drives: F30 335i
Actually that issue resolved itself, I'm not sure why or how. The first time I turned the car on after installing the seats the car thought someone was in the passenger seat. I drove the car home and decided to deal with it another day. Lo and behold, it works flawlessly now.
Performance Mods: Eibach Sway Bars, KONI SA Dampers, M Perf Rear Brakes, MSTv2 Turbo Inlet, Akrapovic Evolution Exhaust, Fabspeed Catted Downpipe, MHD/xHP Stage 2, M Sport Auxiliary Radiator
Retrofit: Reversing Camera (3AG), Rear PDC (507), Front PDC (508), NBT Evo (from CIC), Active Cruise Control (5DF) |
| 03-12-2026, 08:28 PM | #16152 | |
///M
702
Rep 2,228
| 03-14-2026, 02:27 PM | #16153 | |
///M
702
Rep 2,228
![]() About 80% done on 760. Have the over window trim to finish on that but all other trim is installed. Will do 3BE soon, too. Just didn't want to mess with the mirror glass today.
F30 328i '14 N20 / 6MT / M-sport conversion / dinan sport kit / hex trim / HK sound / B14 coilovers / oem roof rack / active autowerke exhaust / eventuri CF CAI Successful Retrofits: 3AG, 4MR, 248, 417, 481, 508, 544, 688, 710, 760 Last edited by wishbone; 03-14-2026 at 02:34 PM.. |
rlesko473.50 billybonka440i12.00 toxik4072.00 thatgarrett1263.50 _ObiJon816.00 ctdriver320i149.00 co_440i345.00 |
| 03-14-2026, 03:15 PM | #16154 |
Rep 12
New brakes, washed it, and replaced the pcv diaphragm.
| 03-14-2026, 03:28 PM | #16155 |
Rep 2,575
new gas cap, in style of a porsche sport gas cap. full replacement not just an overlay cap
billybonka440i12.00 wishbone702.00 _ObiJon816.00 rcaso26345.50 sqwinny909.00 plsdnt267.00 Trusststaging21.00 |
| 03-15-2026, 09:59 AM | #16156 |
60
Rep 43
Drives: 2018 330iX Touring
Upgraded to M performance brakes:
Yellow Brembo calipers Hawk pads Brembo 2-piece blank rotors Stoptech braided lines New large front shields Brake fluid flush Installation process was very straightforward. I mean it’s just brakes. Programming with BimmerUtility was easy. Bleed procedure was also easy. Accidentally bought a bleeder that uses a compressor rather than a had pump. Luckily I have a compressor. The rear caliper bolts are a biiiiitch. If you’re just using a jack and jack stands I recommend you get it as high as the jack stands will allow. It will give you more room for a breaker bar. Lastly the pins are pretty annoying to get in. Not much room to knock them in. Thoughts: Super happy with the look! Seeeexy. The brakes feel really great. Good bite without being jerky. I’ve only bed-in the pads and gone on a beer run. The dust from the Hawk pads is a bit more than expected. Did a lot of research and thought the dust was supposed to be minimal. I’ll reserve too much judgement until I get a few thousand miles behind the pads. |
toxik4072.00 Skyhigh2270.00 rexcm33.00 _ObiJon816.00 thatgarrett1263.50 disintegrator66511.00 rlesko473.50 co_440i345.00 E36 wire harness752.00 Jvac563.50 learntocode73.50 moppity256.00 |
| 03-15-2026, 06:30 PM | #16157 |
Rep 897
Drives: F30 335i
Nice! 417 looks great. How did you find parts? I am in the process of doing 760 as well. I have shadowline mirrors that I'm going to install with my 5AG retrofit. Still searching for the window trim locally.
billybonka440i12.00 |
| 03-16-2026, 10:13 AM | #16158 | |
///M
702
Rep 2,228
I sourced my 760 locally. Picknpull and fb marketplace. I did buy the b pillar new because it’s so easily seen even though my picked and purchased b pillars would have been fine.
| 03-16-2026, 10:57 AM | #16159 | |
![]() ![]() 200
Rep 328
Drives: 2017 BMW 440i Gran Coupe
Looking at those pads for my F36 with 370/345mm brakes as they’re a good balance between performance and low dust from what I have read and my brother’s own experience on his previous 2014 F36.
BMW 440i Gran Coupe F36 LCI Individual Ferrari Red - MPPSK - ZF8 - M-Sport - HUD - Icon Headlights - Digital Dash - Sunroof - Driving Assistant - Comfort Access |
| 03-16-2026, 11:58 AM | #16160 | |
60
Rep 43
https://www.bimmerpost.com/forums/sh...php?p=32636934 I thought they would be low dust as well. I would say more in the “moderate” range. Again, the observations I’ve gathered are just from bed-in and one short drive. I’d like to clean off the wheels and go for a longer drive, which I plan to do this week. So if you don’t need to know right away, I can post again on Friday or Saturday with an update. |
| 03-16-2026, 12:14 PM | #16161 |
Rep 1,526
So this is in progress little by little. It fits pretty nicely. The overall plan is working. Need to finish my retune of the car on 93ish octane first. Then will install and check for MAF fuel and air reading trims calculated.
Had to cut up the metal mounting “bracket” thing from CTS turbo as I like the ISM cover and my catch can is right in the way of where this officially mounts
MY13: IM500 n20 g25-660 Hybrid Turbo.
e80 tune + Port Injection by Navardi Tuned. 100% forged and hero build N20 Build Thread: https://f30.bimmerpost.com/forums/sh....php?t=1742413 IG + YT: Sqwin_n20 |
| 03-16-2026, 03:13 PM | #16162 |
![]() 62
Rep 168
After I reinstalled the original charge pipe & intake pipe, today I took it to Swift Performance to return it to stock (exhaust & suspension).
Really great guys over there, definitely recommend.
'16 BMW 440i GC AT | '17 LCI BMW M240i AT | '94 Mazda MX5 | '04 BMW M3 E46 6MT | '07 Seat Lean FR 2.0 | '01 Seat Ibiza Sport 1.6 | '94 Nissan Sunny LX 1.4 |
Bob Loblah157.50 |
| 03-18-2026, 10:00 PM | #16163 |
60
Rep 43
Did a 100mi ride through some windy Colorado roads. I would say the brake dust is on the lower end of moderate and light in color. For performance pads I’m not mad at it. Like I mentioned before good feel to the brake force. Felt like I had a good range of pedal for various brake force without it feeling spongy. Since the pads are pretty easy to change, I may cinsider buying and throwing on akebonos at some point just to compare. I was torn between the two and went with the Hawks because they were really talked up here on Bimmerpost. Bottom line: they weren’t cheap so next time I’m buying pads, I’ll probably shop around and try something else, but generally not unhappy.
| 03-20-2026, 11:57 PM | #16164 | |
Rep 1,273
Here is what I wrote in my onenote page for my F36 about Hawk HPS 5.0 several years ago. "Sucked and squealed a ton at 10,000 Miles. Back of pad shim coating worn through on front inboard pads." I will never buy another set of hawk pads. I replaced the Hawks with Brembo pads several years ago and never looked back. I hope your experience is better. I only reply to counter the pads being further talked up on the forums when they're utter shit. Worst pad I've ever had on any of my BMWs and I, in the past, have gone through a lot of pads just playing around.
| 03-21-2026, 08:32 AM | #16165 | |
![]() ![]() ![]() ![]() 564
Rep 954
335i rwd auto, 2015 with m performance LSD and Dinan stage 2. Cts charge pipe, mad 5" stepped intercooler.
c31tuck59.50 |
| 03-21-2026, 06:07 PM | #16166 | ||
60
Rep 43
| 03-21-2026, 06:52 PM | #16167 | |
Rep 1,526
Similar performance but no noise no dust for me is ebc reds. Order from FCP and if you don’t like them they will let you return them for your akebonos people scream about as well.
c31tuck59.50 |
| 03-21-2026, 07:32 PM | #16168 | |
///M
702
Rep 2,228
Just watching some college bball... almost done the 760... waiting for some epoxy to cure on one of the permanent clips so i can install the final above window trim in gloss black, person who removed from the donor car snapped one and didn't tell me.. it's fine ![]()
_ObiJon816.00 thatgarrett1263.50 |
| 03-22-2026, 10:54 AM | #16169 |
///M
702
Rep 2,228
sorry for double post... finished up the gloss black trim (option 760) today. Looks pretty. I would rate this difficulty as a 4/10 if you did everything except the glass divider. Honestly the hardest parts are ensuring you don't bend anything. It's basically some elbow grease and a torx20 (if you don't do the glass divider). With the glass divider i'd say it's slightly more difficult only with the removal of the door card and pulling back the vapor barrier.
![]() Unrelated, I swapped all my thule lock cores to get the same keys for the rack and box. ![]()
F30 328i '14 N20 / 6MT / M-sport conversion / dinan sport kit / hex trim / HK sound / B14 coilovers / oem roof rack / active autowerke exhaust / eventuri CF CAI Successful Retrofits: 3AG, 4MR, 248, 417, 481, 508, 544, 688, 710, 760 Last edited by wishbone; 03-22-2026 at 11:33 AM.. |
| 03-22-2026, 08:51 PM | #16170 |
![]() 894
Rep 239
Drives: BMW 330i Sport Wagon
Summer tires and wheels are back!
Something so basic shouldn't have been such a challenge. Last shop visit obviously involved an impact because one stud came out instead of the lug nut (it's such a headache to fix), shattered a socket on another, a piston stuck on the floor jack, so put a scissor jack into service - 'cause this should be quick and easy - destroyed the threads, crushed a wheel chock. . . Beauty demands a price, I suppose. And relevant to some comments above about Hawk 5.0 pads - I've always liked them, but this last pair introduced a squeal I couldn't eliminate. . . until I re-lubed the pins and retaining clips. Voila. FWIW and YMMV.
W///AgonHo FB - @WagonHo | IG - @wagon_ho
2019 F31 330i SportWagon | M-Sport | Black Sapphire Metallic over Black Dakota 2016 F31 328i SportWagon | Sport Line | Alpine White over Beige Sensatec (sold - 2019) 2004 B5.5 Volkswagen Passat GLS Wagon | Northern Green | 5-Speed Manual (sold - 2016) BMW CCA | National Capital Chapter since 2019 - SCCA | Washington DC Region since 2021 |
| Bookmarks |
