05-21-2020, 01:40 PM | #2091 | |
Rep 843
Use v2.1.0.3.gpe.b and MCU 20.5.9.10 |
OFS740.00 |
05-21-2020, 02:34 PM | #2092 | |
Rep 102
Andream MMI Box - Wireless CarPlay & Android Auto
Was this beta update shared and tried by others? |
05-21-2020, 03:33 PM | #2094 | ||
Rep 11
05-21-2020, 04:00 PM | #2095 | |
Rep 256
Plus they look out of place relative to the normal BMW CID styling |
05-22-2020, 01:58 AM | #2096 |
Rep 93
My car has the base stereo setup, and I was hoping to add an amp. However the amp also connects with a quadlock, so I'm wondering how that would work, now that I also have an Andream box connected? Does anyone know if this is even possible?
05-22-2020, 03:06 AM | #2097 |
Rep 289
05-22-2020, 04:12 AM | #2098 |
Rep 2,152
what thread are you on about? not seen anything that points to those issues?
i also wont be connecting my phone to the android unit ill just download spotify from the playstore direct on unit. phone will connect to BMW idrive
Current: BMW M4 F83 - Mods : Pedal Covers, LCI Stereo facia Retrofit and Carbon Rear corner covers
Old: F32 435d M Sport - Mods : HR Sport Springs, 20" Veemann V-FS23 in Gun Metal, M Performance Body Kit, Pedal Covers, Eurspec CF Mirror Caps, More-BHP remap 364 BHP 741 NM, M4 Under Chassis Brace, 15mm Rear ARB, 8.8" Screen Retrofit and LCI Stereo facia Retrofit |
05-22-2020, 04:18 AM | #2099 | |
Rep 289
All of these screens, any vendor or brand, have the same issues and same bugs such as the typo's i pointed out. Not saying they are bad, apparently they look great (quality wise). |
05-22-2020, 11:16 AM | #2100 |
Rep 4
Oh dear - have I bricked my unit.
I got a little over enthusiastic in trying the firmware upgrade on my unit without thinking through the implications.
My MMI box is hardware type BMW_CIC and I have fitted it in a 2010 Z4 E89 - it was working fine but with a few bugs which I wanted to upgrade to get rid of. Now I can force flash it but don't have the right software. I'm just wondering if anyone has any advice or software for my version or can point me where I might find some. Any help appreciated |
05-22-2020, 04:43 PM | #2101 |
Rep 56
**ENGLISH INSTALL AND USER GUIDE V1.0**
Hello Guys, Since I have been getting a lot of questions and have done lots of troubleshooting with customers I have come up with a guide of sorts. The info provided by suppliers is far from comprehensive and is bits and pieces. This is by no means an official guide, and I am more than happy to edit it and take on board suggestions. https://mega.nz/file/cApwjCqZ#4GfgBm...UcSOPN-9_B9wPw |
05-22-2020, 07:41 PM | #2102 |
Rep 59
My car has no microphone, I was told by andream that the unit comes with a microphone on the power cable. Is this true?
Anyone else had this problem, or do I have to start looking for an external mic? |
05-22-2020, 10:17 PM | #2103 |
Freude am Fahren.
841
Rep 1,289
Drives: F15 X5 xDrive35i
There’s no “power cable”. It takes power from a NBT. Get a mic.
05-23-2020, 02:02 AM | #2104 | |
Rep 1,245
Section F could do with a tweak. It reads to suggest that the microphone loom is required in all installations which isn't the case. It also references that a test will be completed in section G however section G is the WiFi antenna connection. I'd suggest reordering to explain when the mic loom would be used, the test to check whether it's required and then installation instructions. |
x-m4n145.50 |
05-23-2020, 06:56 PM | #2106 |
Rep 7
So i just wanted to let you guys know Andream is selling a box now for 2017-2018 BMW Evo, basically compatible with I drive 5 and idrive 6. I hooked it up yesturday works great , just missing equalizer at this point. Maybe they will come with an update.
05-23-2020, 07:12 PM | #2107 |
Rep 67
Surly if you had office 5 or 6 you would just get real car play? Or am I missing something
05-23-2020, 07:13 PM | #2108 |
Rep 1,217
Are you using Carplay or Android Auto? Wondering if the Android Auto screen resolution is any better than on ID4.
05-23-2020, 07:15 PM | #2109 |
Rep 67
My Andream unit didn't come with a microphone but don't all f3x cars have a microphone for the hands free?
05-23-2020, 08:10 PM | #2110 | ||
Rep 59
handandy I think we have similar systems, do you have a photo of the cables you received? Did your car have a mic? |
05-23-2020, 08:32 PM | #2111 |
Rep 16
Trying to troubleshoot a few issues with the wakaa device.
1. Reverse Line Detect is not listed in the settings and I do not have the option for dynamic guidance lines. Is this not compatible with the wakaa device or software version? CUST Version 9.2.2.yl.b and MCU Versions 20.4.2.14. 2. When holding down the steering wheel voice command button to activate Siri it also activates the BMW voice commands which takes priority. Is it possible to disable the BMW voice commands? 2012 CIC system with 6 pin LVDS. |
05-24-2020, 02:43 AM | #2112 | |
Rep 8
Andream have sent me the latest software for CIC which should help: V2.1.0.4.gpe.c.zip https://mega.nz/file/3olGkAxL#sbZfgi3vzGbsurLqUgXG_5EPZqAXYIbqhtaCqcQ-xI8 & MCU 20.4.22.12 https://mega.nz/file/fp9xQK5R#Tgwt6mvuNUQxUb4QKXJl2CG_Vql_cwY5ql8hhU29F Ko I have installed both successfully on mine. From what I can tell it is very similar to the latest NBT software people have received. My CIC unit did also come with an external microphone and connection for it in the wiring harness. However I didn’t use it as I have an OEM microphone which works. |
andream, android, android auto, apple, carplay, mmi, retrofit |
