BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Custom Tune Recommendations on Bootmod3
      10-18-2021, 06:35 PM   #1
Bmweth24
Drives: BMW F32
Need some recommendation getting tuned for 93 need more power than ots map and smoother delivery. Not really looking into upgrading fuel pumps or running meth.
2014 m sport 435i rwd fbo upgraded turbo
VRSF Chargepipe, vrsf race fmic, and hi flow downpipe
BMS aluminum elite intake
Stage 2H 93 bootmod3
ngk 97506 Cold spark plugs 0.020
PR Ignition Kit
Vargas stage 1 upgraded turbo
93500 miles
xHP stage 3 transmission tune
MST Inlet
FTP Outlet
      10-18-2021, 11:42 PM   #2
thejeremyman9
thejeremyman9's Avatar
4364
Drives: 2015 BMW 335i
There is very little to be gained over the OTS map. A custom tune will maybe add 1-2 psi and even if it does your timing will probably suffer.
johnung4528.00
      10-19-2021, 06:41 PM   #3
Bmweth24
Drives: BMW F32
I've seen a cary jordan custom tune for m235i and their 0-60 on dragy was 3.36 and 1/4 11.29 on stock turbo and stock fueling with e30 mix.
      10-19-2021, 06:44 PM   #4
thejeremyman9
4364
You just said in your OP that you wanted a 93 tune.... you can't compare a pump gas tune to a ethanol mix tune.
I would love to see what you are referring to, please share the link, because that is incredibly fast for a stock turbo/fuel system car... I think like world record fast, although i don't follow that kind of thing.
Anyways, there is very little to be gained from a custom tune even on E30. This was just discussed in this thread: https://f30.bimmerpost.com/forums/sh....php?t=1853855
      10-19-2021, 06:51 PM   #5
Bmweth24
Drives: BMW F32
      10-19-2021, 08:45 PM   #6
thejeremyman9
4364
Nice too bad he doesnt have any datalogs that i can see. Cary Jordan is probably the most aggressive tune if that's what you want.
      10-19-2021, 11:04 PM   #7
davidr3
Drives: 335i
an e30 tune is your final shot at more power, after that it's fueling and turbo upgrade.
      10-20-2021, 11:26 AM   #8
sqwinny
Drives: 2013 6MT 328i M Sport
Get a HPFP + LPFP and max out that turbo. Otherwise a custom tune will do nothing for you.
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block
Build Thread: https://f30.bimmerpost.com/forums/sh....php?t=1742413
IG + YT: Sqwin_n20
      10-20-2021, 11:55 AM   #9
thejeremyman9
4364
You only need the HPFP unless you are going above about E70 on stock turbo, or running PI. Stock HPFP is got for all but full E85 essentially, with stock turbo. Some people have even reporting E85 tunes with FX-180 HPFP on stock turbo/LPFP, but others say they were LPFP limited around E70 with ~20-21 psi.
johnung4528.00
      10-20-2021, 01:18 PM   #10
thejeremyman9
4364
Are you sure that guy has stock HPFP? I just checked one of the databases and it seems to show him (under a slightly different name but exact same ET and MPH) as having a FX-150. https://docs.google.com/spreadsheets...MCWwH/pubhtml#
Something doesn't seem to add up?
      10-20-2021, 03:00 PM   #11
Bmweth24
Drives: BMW F32
He upgraded the HPFP but not in the post I sent.
      10-20-2021, 04:07 PM   #12
thejeremyman9
4364
So the 11.29 run was not on stock fueling, but the 11.59 was. That clarifies that discrepancy.
Anyways in the other thread i linked you can watch the guys video and see the discussion was to why the OTS map basically already maxes out the stock fuel system on E30. If your fuel quality is excellent they might be able to throw a little more timing at it to try and make more power but what typically happens is a custom tune will either raise boost over the OTS map and HPFP will crash, or they will put aggressive timing and you will end up with knock or corrections. Lots of people have went down this road before.
      10-20-2021, 05:13 PM   #13
435gc
435gc's Avatar
174
Drives: 2015 435i Gran Coupe xdrive
My stock hpfp was crashing at e25 anything above 19.5 psi
Put in wmi and could run 23psi, 26 with e20 on stock turbo.
      10-20-2021, 09:45 PM   #14
thejeremyman9
4364
26 psi on stock turbo? At what RPM lol? That had to fall off quickly.
      10-20-2021, 10:23 PM   #15
Adresnuri
Drives: 2017 440ix Grand Coupe
Look into MLYFE on instagram, they should be able to guide you in the right direction with tuning
      10-21-2021, 04:22 PM   #16
435gc
435gc's Avatar
174
Lol for sure.
It was between 3 and 5krpm.
I remember not being to hold more than about 14psi above 6k.
Certainly don't want to suggest to anyone attempt the same if turbo longevity is of any concern. I did it just a few runs the day before I had ps2 installed just to see what it was capable of.
      10-22-2021, 11:11 AM   #17
Kashmir56
Drives: BMW 335i
Cary Jordan does great work
