10-18-2021, 06:35 PM | #1 |
Rep 80
Custom Tune Recommendations on Bootmod3
Need some recommendation getting tuned for 93 need more power than ots map and smoother delivery. Not really looking into upgrading fuel pumps or running meth.
2014 m sport 435i rwd fbo upgraded turbo VRSF Chargepipe, vrsf race fmic, and hi flow downpipe BMS aluminum elite intake Stage 2H 93 bootmod3 ngk 97506 Cold spark plugs 0.020 PR Ignition Kit Vargas stage 1 upgraded turbo 93500 miles xHP stage 3 transmission tune MST Inlet FTP Outlet |
10-19-2021, 06:41 PM | #3 |
Rep 80
I've seen a cary jordan custom tune for m235i and their 0-60 on dragy was 3.36 and 1/4 11.29 on stock turbo and stock fueling with e30 mix.
10-19-2021, 06:44 PM | #4 | |
Rep 7,607
I would love to see what you are referring to, please share the link, because that is incredibly fast for a stock turbo/fuel system car... I think like world record fast, although i don't follow that kind of thing. Anyways, there is very little to be gained from a custom tune even on E30. This was just discussed in this thread: https://f30.bimmerpost.com/forums/sh....php?t=1853855 |
10-19-2021, 06:51 PM | #5 | |
Rep 80
10-20-2021, 11:26 AM | #8 |
Rep 1,065
Get a HPFP + LPFP and max out that turbo. Otherwise a custom tune will do nothing for you.
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block Build Thread: https://f30.bimmerpost.com/forums/sh....php?t=1742413 IG + YT: Sqwin_n20 |
10-20-2021, 11:55 AM | #9 |
Rep 7,607
You only need the HPFP unless you are going above about E70 on stock turbo, or running PI. Stock HPFP is got for all but full E85 essentially, with stock turbo. Some people have even reporting E85 tunes with FX-180 HPFP on stock turbo/LPFP, but others say they were LPFP limited around E70 with ~20-21 psi.
johnung4528.00 |
10-20-2021, 01:18 PM | #10 |
Rep 7,607
Are you sure that guy has stock HPFP? I just checked one of the databases and it seems to show him (under a slightly different name but exact same ET and MPH) as having a FX-150. https://docs.google.com/spreadsheets...MCWwH/pubhtml#
Something doesn't seem to add up? |
10-20-2021, 03:00 PM | #11 | |
Rep 80
10-20-2021, 04:07 PM | #12 | |
Rep 7,607
Here's what you said:
Anyways in the other thread i linked you can watch the guys video and see the discussion was to why the OTS map basically already maxes out the stock fuel system on E30. If your fuel quality is excellent they might be able to throw a little more timing at it to try and make more power but what typically happens is a custom tune will either raise boost over the OTS map and HPFP will crash, or they will put aggressive timing and you will end up with knock or corrections. Lots of people have went down this road before. |
10-20-2021, 09:45 PM | #14 |
Rep 7,607
10-21-2021, 04:22 PM | #16 | |
Rep 461
It was between 3 and 5krpm. I remember not being to hold more than about 14psi above 6k. Certainly don't want to suggest to anyone attempt the same if turbo longevity is of any concern. I did it just a few runs the day before I had ps2 installed just to see what it was capable of. Last edited by 435gc; 10-21-2021 at 04:32 PM.. |
