01-26-2014, 01:31 PM | #221 | |
Rep 1,554
01-26-2014, 02:30 PM | #222 |
Rep 1,136
Is yours a sportline 335 or modern/luxury?
sent from bimmerpost Android app
01-26-2014, 03:13 PM | #224 | |
Diligentia Vis Celeritas
558
Rep 1,477
Drives: 335i
Most of the lowering springs I see guys going with for their F30s on these forums are either H&R (Sport or Super Sport) or Eibach - both of which are close to OEM sport springs in terms of spring rate. Hence the ride quality / bottoming out issues that I mentioned. The Dinan kit is different not just because of the 30% firmer spring rate (there may be other similar springs available somewhere, e.g. M Performance springs) but also because of the revised bump stops. That is why the ride is still OEM-like quality, and why they charge more than H&R does for just a set of springs.
01-26-2014, 03:16 PM | #225 | |
Rep 1,201
It feels like H&R and Eibach just didn't engineer their springs properly. I think it's strange that they have issues, but maybe BMW/s aren't their top priority for springs. I think they are more popular among japanese brands. |
01-26-2014, 03:30 PM | #226 | |
Rep 1,201
01-26-2014, 04:26 PM | #227 | |
558
Rep 1,477
Drives: 335i
01-26-2014, 07:18 PM | #228 |
Rep 993
Drives: F85
Somebody just order these for their xdrive and tell us if it works!! Any volunteers??
01-26-2014, 07:19 PM | #229 | |
Rep 238
01-26-2014, 08:51 PM | #231 | |
Rep 238
01-26-2014, 09:38 PM | #232 |
Rep 1,201
01-27-2014, 08:46 AM | #233 |
558
Rep 1,477
Drives: 335i
As soon as possible. The springs arrived Friday, so hopefully this week if I can get an appointment and block out some time at work.
01-27-2014, 09:33 AM | #234 | |
Rep 1,554
But that is the point I am making. T said he was bottoming out. Bottoming out is hitting the bottom of the shock not hitting the bump stops. As you posted to DVC, with bump stops in place, to bottom out is difficult. A person can hit the bump stop and that is ok because that is what they are for to prevent bottoming out. You should not be hitting them on a regular basis but occasionally is ok. Typically if you lower a car and you use the factory stops, you are suppose to shave them down a little bit. Any shop that lowers vehicles will know this. Even then you will still not "bottom out" unless you hit something as I pointed out, your least worry is your shock. That is my point. Maybe I am being too technical and the others are not technical enough. I have read countless posts here and others where people say the spring swap made the ride firmer and or bouncier. I have not read all posts, but I have not come across one that says it rides like stock. Eibach I would agree with your statement, but H&R does focus on the European market with BMW, Audi and VW. DVC, if you are constantly hitting the bump stops, then I can see why Dinan's "improved progressive" bump stops will help, BUT they will not improve ride quality in general because again at 3/4" drop you should not be riding on your bump stops or even hitting them on a regular basis SO they will not even be in play 99.9% of the time. I lowered cars as much as 3" on stock struts, shaved the bump stops in half and never hit them. The way dinan describes the bump stops on their product page I can understand why you think they are a selling feature. But coming from a product development background, their description is pure marketing. The chances are they are shorter than stock so it gives you more travel before hitting them, but your shop should do this regardless. For everyday driving they don't do squat. A bump stop is an emergency device to keep your shock from bottoming out, because if you bottom out your shock will blow out. Maybe not on the first time, but it will not last long. If you constantly hit your bump stops that as well over a short time will blow your shock. Especially a stock strut where you are decreasing the travel by 1-2" normally and compressing it to the point there is just 1.5-2" (typical bump stop height) of chamber left is too much pressure for the seals to happen on a regular basis. Think we this topic to death. Just trying to help. |
01-27-2014, 09:40 AM | #235 | ||
Rep 238
01-27-2014, 10:11 AM | #236 | |
Rep 1,554
You are hitting the bump stops. When you hit them, it jolts the car because it stops the travel immediately. If you were running the stock ones, like I mentioned, shops that lower vehicles typically will shave them down to give you more travel. Also as I mentioned in my first reply to you, living in NY is another world because the roads are so horrible there and I would not doubt you hitting them there on a lowered car. Should it be everyday? Not that I saw driving around but I could see some roads where that would have happened because I even cringed in a stock riding car. |
01-27-2014, 10:41 AM | #237 | |
Rep 807
My primary concern is achieving improved handling, while also maintaining a fairly comfortable ride + OEM/factory quality in daily conditions. I had a 2013 Jetta GLI, and went with VWR springs which were also "designed" to work with the stock shocks, and while the performance (cornering, body roll) did improve, the rear got significantly harsher for passengers, and the overall quality of the ride during normal driving conditions were markedly worse. The look was great as the stock wheel gap was extreme, the fronts were lowered by 1 1/8" and the rear by about 1.625". I also got stiffer rear shock pads for the rear to help even out reverse rake - which may have contributed to the harsher ride. Based on the reviews so far, the Dinan's appear much more suited to work with factory dampers: the addition of custom bump stops, minimal lowering (20mm - 3/4") and Dinan's reputation for quality engineering. Also as you mentioned, the rear springs rates did not appear to be too impacted vs. stock. I have a 335i M Sport, RWD, non-DHP, w/ the 18" 400M wheels/staggered. Appreciate any and all feedback. Thanks!! Last edited by mhanism; 01-27-2014 at 10:50 AM.. |
01-27-2014, 01:10 PM | #238 | |
Rep 1,201
01-27-2014, 01:26 PM | #239 | |
558
Rep 1,477
Drives: 335i
By "improve ride quality" I just meant that extending the range of travel (before hitting the bump stops is even an issue) keeps the ride civil... Not that the Dinan revised bump stops are doing something magical. I have no doubt that a quality installer who knows exactly how much to trim OEM bump stops could get a similar result. But I like the idea that Dinan did all this ahead of time, and is offering a kit with springs and bump stops engineered and tested to improve handling (while maintaining a civil ride) specifically for our cars... no trial and error or messing around needed - just install it and forget it.
01-27-2014, 01:52 PM | #240 | |
Rep 807
01-27-2014, 02:01 PM | #241 |
Rep 1,136
I'm in Fremont!
01-27-2014, 02:15 PM | #242 |
Rep 807
Right on VIP! So how's the daily ride and comfort been with the Dinan springs? Any issues with the forward rake? Visually or otherwise?
MY20 M2 Competition
MY16 M3 (Sold) MY17 X3 35i M Sport MY14 335i M Sport (Sold) |
