BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > N26 Forged internals Engine build
      10-15-2020, 04:36 PM   #23
Kel918
Drives: 2013 bmw 328ix
I really need help with this answer. Is there a diffrence between a rwd and awd N20/26 engine block ???
      10-21-2020, 12:22 PM   #24
Kel918
Just dropped off my block,rods, and pistons to the machine shop. Going to go with melling liners, King bearings, Arp studs etc..
      10-21-2020, 12:48 PM   #25
snipagang
Drives: 2017 320i xdrive
Originally Posted by Kel918 View Post
The reason why I have to rebuild the engine with stronger forged connecting rods and pistons is because the engine will basically self destruct from what I've read with anything around 325-350 whp. I'm going for around 5-600 whp with my set up.
How are you hitting that 5-600whp mark? Is it just a turbocharger and fueling that will make this hit that mark? Are you worried about turbo lag?
      10-21-2020, 01:15 PM   #26
Kel918
I plan on adding a centrifugal supercharger to add 300-350+ whp. For fueling I'm going to use port injection with fuel pressure regulator , high flow fuel pump, and a return line.
      10-21-2020, 01:25 PM   #27
snipagang
I plan on adding a centrifugal supercharger to add 300-350+ whp. For fueling going to go with port injection with fuel pressure regulator , high flow fuel pump, and a return line.
Sorry, these questions might sound stupid but are you going to be running ethanol mixture with that fueling upgrade? Whats the point of the fueling upgrade? I am trying to figure out whether or not you need upgrades to run ethanol mixture with stg1 and cp upgrade only.
      10-21-2020, 01:28 PM   #28
Kel918
it's cool with questions we all learn. The reason for fueling upgrades is because the stock fuel system won't support the horsepower I'm aiming for. I live in north NJ and I can't find anywhere close to get e85, so my plan is only to use 93.
      10-21-2020, 01:33 PM   #29
snipagang
I am also in NJ and yeah its all 93 around here... but you can just mix it yourself, although I guess that comes with some challenges.
      10-27-2020, 08:53 PM   #30
navardi
215
Drives: Built N20 BMW 220i
Feel free to DM me for specific questions, i believe you already commented on my built motor post. Good to see another N20 build!
      10-29-2020, 07:38 PM   #31
Kel918
Thanks !!! will do, have a lot of questions to ask
      10-29-2020, 08:12 PM   #32
Avaley
Avaley's Avatar
732
Drives: f32 430ix & 982 GT4 PDK
can't wait to see what this car can do!
      10-30-2020, 03:38 PM   #33
Kel918
Thanks !!
rcaso26331.00
      11-21-2020, 02:59 PM   #34
Kel918
got my engine block done, next step is to get the support rings done.
sqwinny477.00
VipinLJ1941.50
      11-22-2020, 08:43 AM   #35
sqwinny
Drives: 2013 6MT 328i M Sport
I'm curious to see what they do for the cylinder supports. Otherwise I'm going the same setup. Cp pistons, maxpeeding rods, king bearings, balanced crank, melling sleeves, etc. Currently looking for a crank (shouldn't be hard to find) and waiting for things to mailed to me. (Bolts, gaskets, new pumps, etc).
For some reason I thought you'd have cylinder support system install the iron sleeves and their support system first before installing and balancing everything ? Perhaps I have it wrong
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block
Build Thread: https://f30.bimmerpost.com/forums/sh....php?t=1742413
IG + YT: Sqwin_n20
      11-22-2020, 11:55 AM   #36
Onlybimmers
Onlybimmers's Avatar
Drives: f30, e92
This is awesome, wish I could do this. I would build all my engines bulletproof. I'll be following
      11-22-2020, 12:14 PM   #37
Kel918
Originally Posted by sqwinny View Post
I'm curious to see what they do for the cylinder supports. Otherwise I'm going the same setup. Co pistons, maxpeeding rods, ring bearings, balanced crank, meeting sleeves, etc. Currently looking for a crank (shouldn't be hard to find) and waiting for things to mailed to me. (Bolts, gaskets, new pumps, etc).
I was going to have cylindersupportsystems do it but it was way more cost effective this way. The melling liners were like $136 and the king bearings were $275. It took a while because they ordered melling 1/8th liners but they were too big and would've ruined the block so we had to go with 3.330 in. the melling part number is csl1136.
Edit: just found the melling liners for $21.16 + shipping each on Summit Racing
VipinLJ1941.50
      11-22-2020, 03:35 PM   #38
sqwinny
I was going to have cylindersupportsystems do it but it was way more cost effective this way. The melling liners were like $136 and the king bearings were $275. It took a while because they ordered melling 1/8th liners but they were too big and would've ruined t h.g e block so we had to go with 3.330 in. the melling part number is csl1136.
Thank you for this ! Going to compare my pistons sheet to yours and if they are the same I'll get these shipped ASAP.
Found them on Amazon, rock auto, summit racing, eBay, oreilly and others
IG + YT: Sqwin_n20
      11-23-2020, 04:01 AM   #39
navardi
215
Looking good, Do you have any photos of the sleeves? or how they were installed? do you know if they're parallel or flanged sleeves? I would also recommend having the block resurfaced, looks like there is a slight dent on the deck surface. If you're using the factory MLS gasket you need to make sure Surface of the block is smoother than 60Ra (And for this reason it's why I heavily suggest the Cut Ring HG).
Keen to see how the build turns out.
      11-23-2020, 08:28 AM   #40
sqwinny
They are parallel sleeves:
IG + YT: Sqwin_n20
      11-23-2020, 07:53 PM   #41
Kel918
Thanks for the advice !!, I'll get the block checked. Would I still need the cylinder support rings if I don't plan to go past 20 to 22 psi max. On the centrifugal supercharger It would be 15 psi max.
      11-23-2020, 08:01 PM   #42
Kel918
your welcome ! and you were right about that I shouldve had cylindersupportsystems do the rings first. I called them today to just do the support rings. They said I would have to send the bare block to them so they could add the support rings, and then I would have to get the bores line honed again.
      11-23-2020, 08:05 PM   #43
Kel918
Thanks, I'm trying to find the most cost effective but durable parts for the build. So far the pistons have been the most expensive parts.
      11-23-2020, 10:51 PM   #44
sqwinny
If you want a semi budget "build," maxpeedingrods for the n20/n26 are 275 shipped on eBay or 300 directly from them for their Black Friday sale... .
Drop motor, disassemble, install rods with bearings, get everything balanced, put back together and reinstall motor. Should be good for at least 450whp. Of course supporting mods and upgrades fuel (pump + hpfp or CPI/port injection.)
IG + YT: Sqwin_n20
