02-01-2020, 03:28 PM | #155 | |
Gettin It Figured Out
1820
Rep 2,669
Well said . .
Supr3me551.00 |
02-02-2020, 02:16 AM | #156 |
Built Motor F30 340i
403
Rep 257
Logs of Dorch Stage 1 HPFP running E40 on Pure800 turbo. Seems to be holding up better than expected, rail pressure is dipping a little bit but only down to 2500PSI which isn't enough to cause issues. I'll keep everyone updated as tuning progresses.
Logs: https://datazap.me/u/richmichael97/w...33-34-35-36-37
kern4174449.50 |
02-03-2020, 06:35 AM | #157 | |
Cheapskate
4450
Rep 4,993
I've also seen someone target lower pressures (Can't remember if it was you or not). Maybe see if it'll hold 2600 through the rev range. |
02-03-2020, 08:06 AM | #158 |
Rep 2,601
Drives: G81 M3 Touring, GR Supra GTS
My Wedge tune seems to target 2600psi rail pressure.
This is just the base map with no revisions, so not complete. https://datazap.me/u/nugs/log-158039...&data=15-16-18 Pure Stage 2 (old version not the 800) high flow catted DP XDI35 |
kern4174449.50 |
02-03-2020, 08:36 AM | #159 | |
Cheapskate
4450
Rep 4,993
02-03-2020, 09:35 AM | #160 | |
Rep 5,392
02-03-2020, 03:04 PM | #161 |
Rep 3,189
No, if you are on the stock turbo and pump fuel an upgraded HPFP will do nothing.
02-03-2020, 06:20 PM | #163 | |
403
Rep 257
kern4174449.50 |
02-04-2020, 06:47 AM | #164 |
Cheapskate
4450
Rep 4,993
*Without a custom tune
02-04-2020, 08:14 AM | #165 |
Rep 106
Order second hand pump and costume tune by Pureboost.
I let you guys know results later...3,4,5,6 days before I get the pump. I´ll be back ! Last edited by theone1973; 02-06-2020 at 06:54 AM.. |
02-04-2020, 08:28 AM | #166 |
Rep 286
Currently running an MP stage 2.5 tune and full exhaust. Question is: if I wanted to run a Pure stage 1 what’s the max power I could make before I would need an upgraded HPFP? If I installed the Supra HPFP what kind of power is possible? Would I need anything else for this setup other than the turbo and pump? Everything will be run on pump 93, FYI. Thanks.
02-04-2020, 09:39 AM | #167 |
Rep 3,189
02-04-2020, 10:34 AM | #168 |
Cheapskate
4450
Rep 4,993
You can definitely increase boost past the limits of the OEM fuel pump. I have yet to see anyone max out the turbo on pump gas. 18psi is nothing imo.
02-04-2020, 11:00 AM | #169 |
Rep 3,189
That was my point. The person I quoted was specifically asking if there was any benefit to an upgraded hpfp when only running pump fuel on a stock turbo. I doubt you could even come close to maxing out the stock turbo on pump fuel.
02-05-2020, 04:39 PM | #170 |
Rep 684
Drives: Your mom crazy
Garage List 2020 BMW X3M CURRENT [0.00]
2016 BMW 340i BEAST [0.00] 2011 BMW 335i RIP [0.00] 2003 BMW 330i SOLD [0.00] |
Has anyone else who has upgraded their hpfp noticed a longer than usual crank time on cold starts since replacing the pump? Maybe 50% longer crank before it catches. Most noticeable first thing in the morning. This is on the Supra pump.
02-05-2020, 05:41 PM | #171 |
Rep 274
Are you using E85? I noticed this occasionally happens since I started using it.
02-05-2020, 06:09 PM | #172 |
Rep 1,454
Common problem with the N54 boys that run full E85 up here in CO in the winter. They needed tuning adjustments to help solve that issue. Yours doesn't sound as bad so might just need less E or move to a regular OTS map.
02-05-2020, 06:41 PM | #173 | |
Rep 684
Yep, you guys are right. After I installed the pump I moved to an E50 custom tune from Wedge. It's not a big deal, just curious. I'm assuming it has no real negative impact, maybe a little bit more wear on the starter? |
02-05-2020, 08:38 PM | #174 | ||
Rep 274
Side note. How was your experience with Wedge? Considering using them. |
02-05-2020, 08:49 PM | #175 | |
Rep 684
Right now I think they feel like the tune is complete but I've asked a few more questions about what else is possible. I was running the MHD OTS E30 map prior to this E50 Wedge map and I can't say I'm blown away by additional power. Below is what I sent, been waiting a couple days for a response. "Feels strong and smooth. No complaints. My only observation is that the power feels a little bit "deep" in the gas pedal, gotta dig deep to get at it. I'm guessing that's probably just a characteristic of this turbo-induction system vs say, a big displacement V8 or a supercharged system. Not sure if tuning could change that. Virtual Dyno says 450-460 AWD HP based on our latest logs and the data for this vehicle. Based on everything I've seen, stock turbo should be good for a few more HP. Do you think octane or fuel volume is our limiting factor at this point? I'm likely going to do a turbo upgrade this year. Nothing too crazy, probably a Pure 800. Trying to decide whether to do the turbo first and see how it does on the Supra pump, or ditch the Supra pump for a Dorch stage 2 hpfp right away. If you had more fuel volume to work with, do you think the stock turbo has more snort in it?" I can share additional comments once we mutually agree to close the ticket.
2020 X3M
MG Flasher; Wedge Performance E50 tune MSS Urban; Rohana RFX11 |
JD11937129.50 |
02-05-2020, 11:11 PM | #176 |
403
Rep 257
Latest Update: 02/06/2020 @ 12:09AM
- Updated Dorch Engineering HPFP Section (Revised description, personal thoughts, and logs) - Updated Spool Performance HPFP Section
