09-25-2020, 04:05 PM | #1453 |
Rep 18
So I tried to update chrome through the play store and it wouldn't update, clicking update did nothing. I uninstalled and tried reinstalling but it won't reinstall now either. Any ideas how to get it back? Can I push the app with ADB? If so what's the target location or better yet if someone knows the full command?
EDIT: Never mind, it came back after a reboot. Still can't be updated via the play store though, is this normal? Last edited by steslatt; 09-25-2020 at 05:11 PM.. |
09-25-2020, 06:14 PM | #1454 | |
Rep 143
I can leave it checked or unchecked, and I'm still able to connect the Xbox controller. I don't know if this is unique to only some headunits such as mine. |
09-26-2020, 12:53 AM | #1456 |
Rep 209
Can you share experience? Which one did you buy?
BMW G30 530e M Sport (2019)
ID7 - 12Kwh Battery Remapped to 388hp/644.9N.m KN Filter |
09-26-2020, 01:17 AM | #1457 | |
Rep 11
https://dl.wish.com/u9uCN It has a double cameras. Front and back. The both cams recording simultaneously. ADAS function is ok. Quality of front cam is not so high as i wished. The ADAS app could be better. It does what it meant to be. OEM Style Dashcam DVR for Android HU https://f30.bimmerpost.com/forums/sh....php?t=1613863 |
09-26-2020, 07:58 AM | #1458 |
Bobafett
43
Rep 46
I have two questions after reading this entire thread. Does anyone even have the issue where my time keeps setting to the 24-hour format? I've changed the setting in both the GUI for 12 hour and also in the Android settings. I keep on clicking the 24-hour mode off but after a few moments, the Android setting one changes itself back to 24 hours. Is there a way to keep it on 12 hour time? My second question is here's my MCU version:
023052dGS-NBT-GTH-200617-B18 Is there an updated file for this, I tried the one posted for Ericokta cuz he had the same MCU string I have but it didn't change the MCU path, it appears to be the same. Do I already have the latest MCU? I checked the ones in the mega folder but I was confused as to which one I should use and if it was an update or a downgrade from what I already have. I guess I should mention I already updated to Android 10 version 2.1.0. I have the Avin 64 GB/4GB SD 625 with the 1920x720p display I believe? Lol. I also tried a factory reset. Neither Avin or the vendor (AutoTec Pro Systems) have responded to my inquiries to them. Last edited by Popo; 09-27-2020 at 07:52 AM.. |
LittleSamurai4.50 |
09-26-2020, 10:25 AM | #1459 |
Rep 3
Hello Kri and the great members of this forum. I'm new here and have no technical background. This forum is really helpful. Thank you for your continuous efforts.
My test about "BT" result is as follows: Headunit MCU Version: 023055dGS-NBT-GTH-DC-200702A Android Version installed: Android 10 2.1.0 (not rooted) System Memory config.: 4GB / 64GB Device tried to connect: Vgate iCar Pro (OBD2, BT4.0) Bluetooth Connection successful: Yes! Comment: -in Japanese language not work, have to change to English mode to find "Files received via bluetooth" (Thanks to fredy3330) -Android 10 2.0.0 not work. can search the device, but disconnect in a few seconds. -After Updated to Andoroid 10 2.1.0 from this forum, it works. I bought my HU from EBILAEN, Aliexpress. The seller said no way to connect OBD via bluetooth. Now I can enjoy TORQUE app on the HU. Again, Thank you so much! |
Kri1083.50 |
09-26-2020, 12:56 PM | #1460 | |
Rep 13
09-26-2020, 07:30 PM | #1461 | |
Rep 62
I have a problem with the Call volume, it seems to be similar issue with Media volume. Low volume at start up. Only restore to correct volume if you go into setting and move the Call volume slider. Would you able to correct the Call volume as well. I am using an Android phone. Thank in advance. |
09-27-2020, 02:02 AM | #1462 |
Rep 11
Headunit MCU Version: 023052dGS-GHT-191127-B18
Android Version installed: Android 10 2.1.0 System Memory config.: 4GB / 64GB Device tried to connect: CARLY OBD Adapter 2019 Bluetooth Connection successful: yes Comment: |
09-27-2020, 07:10 AM | #1463 | |
Rep 159
Can you check if the older version does fix the Call Volume at startup too? The version is available here: https://f30.bimmerpost.com/forums/sh...postcount=1300 |
09-27-2020, 04:06 PM | #1464 | |
Rep 62
Thank you for getting back, I uninstall version 1.1 and install version 1. But it does not seem to work. Thanks |
09-28-2020, 04:13 AM | #1465 |
Rep 551
Version MCU de l'unité centrale: 615054dALS-NBT-GTH-191129-B18
Version Android installée: Android 9 (3.8.7) Configuration de la mémoire systčme: 4 Go / 64 Go appareil a tenté de se connecter: Vlink BT ******ion Bluetooth réussie: non Commentaire: Test with ANDROID 9 and the BT always goes back to the OFF position impossible to connect a device (except phone of course) In addition, no application is called KSW_BT in our android version So I'm going to update to android 10 just for this game-changing feature for BMWs that don't have temperature gauges |
Kri1083.50 |
09-28-2020, 06:02 AM | #1467 |
Rep 353
09-28-2020, 06:04 AM | #1468 |
Rep 8
Hi!
I have one of these units, with Last update. I have front and rear PDC, when i put the reverse gear the rear camera opens up alongside with a car with "radar" for the PDC. The problem is when i put first gear it shuts down and goes no Android menu, so the radar shuts down too and can only ear the PDC beeping. While when using the oem PDC radar it only closes when i get to a certain speed. It would be cool if the camera and radar do the same. It would be usefull when parking for example. Is there a turn around for this? Thanks |
09-28-2020, 06:34 AM | #1469 |
Rep 15
MCU flash error
09-28-2020, 06:41 AM | #1470 |
Rep 399
It depends on how you have connected the camera. Your description will be the case if the camera is powered by the reverse lights. The behavior you want is possible if the camera is powered by the red +12V Camera wire from the Android unit. If the camera interface then still doesn't stay open until a certain speed forward is reached, then your unit has a software bug.
09-28-2020, 07:35 AM | #1471 | |
Rep 8
09-28-2020, 09:47 AM | #1472 |
Rep 399
I had the same problem with Android 9, E87 and PDC front and back, it was finally resolved in update 3.8.0. Prior to this I had switched the PDC unit to the newest revision (got it cheap from the scrap yard) to resolve another issue in communication between PDC and Android. It seems the software in our Android units is made compatible with the latest hardware revisions.
09-28-2020, 09:49 AM | #1473 | |
Rep 114
Nothing solve the problem, before with Android 9, now with Android 10. I tried all MCU's for my model and still the problem. Also tried to power the camera with reverse lights, and then with yellow (+12v) from the Android screen (that is the right way) . You can "manually" make it to work ok if you touch the "PDC" button, then the camera and PDC works ok. This is why I think that the problem is with the MCU that don't send the correct signal to stay at pdc, only send signal to open the "PDC" apk from Android when you're in reverse, then when you put direct it gear disconnects in 3-4 secons. If the Chinesse enginer change this in the MCU then it will work ok. Also o don't know if is possible to do something with "tasker" apk or another apk, to avoid MCU signal and send the correct signal. Cheers. |
09-28-2020, 11:03 AM | #1474 | |
Rep 24
Have you tried to set the camera as "after market camera" instead of "360 camera". In my HU, I have noticed the screen will go back to main menu if the gear is shift off from reverse even the PDC button is on.
But in the "after market camera" setting, it appears the reverse mode is triggered by the reverse gear instead of reverse trigger line. The PDC screen will stay on either in the reverse gear or PDC button pressed. Quote:
