10-10-2020, 08:16 AM | #1585 | |
Rep 41
See: #1558 No splitter, just plug the included aux cable into the black cable instead of that black one & into the armrest jack, than in the bmw car aux settings increasing the sound volume to ... , I set it to 40 as max. Again, I just try to help mate! Success |
10-10-2020, 08:25 AM | #1586 | |
Rep 353
Android HU on SD625 6/64 can do the job. It has its separate speaker for navi directions while you're listening your oem radio. In case you're listening audio from Android the navi speaks from all of your oem speakers. That separate speaker can be mounted vertically under the dash behind the HU. I can recommend this shop with good pricing and service: https://ali.onl/1GQp |
10-10-2020, 08:31 AM | #1587 | |
Rep 353
10-10-2020, 08:55 AM | #1588 | |
Rep 41
Nothings is strange there, you must to do that too.. in my case too! Repeat: just plug the included aux cable into the black cable instead of that black one & into the armrest jack, than in the bmw car aux settings increasing the sound of it.. as you like. Ps; ask your mate the seller of Android 10 which you have recommended to that guy to buy from him if i'm right or wrong? I'm 99,99% Right! Success Last edited by Mad1Max; 10-10-2020 at 09:04 AM.. |
10-10-2020, 08:57 AM | #1589 | |
Rep 12
I had a similar HU (Win CE) on my older Skoda and the navi directions were only audible on the front speakers. The HU automatically dimmed the radio volume (front left and right), navi played its message, the radio returned to its original volume, all these while the rear speakers remained at the same volume, playing only the radio. In case of BMW Android HU, during the audio navi directions, the audio signal from other sources (lets say USB stick in the Android HU) is completely muted to all speakers? Or is a mixed signal (navi high and music low)? Also, is it possible to run two navi programs at the same time (Waze and Amigo in my case) and both of them to speak audio messages? Regards |
10-10-2020, 09:46 AM | #1590 | |
Rep 519
I'm not getting any signal from the Idrive side either, just a blank screen that says "no signal". I've made sure the main plug is plugged into the new screen all the way a few times as well. Still nothing
2017 340i M Sport Alpine White / Coral
Dorch Stg2, CTS catless, xHP, Custom E50 Tuned by Shoup |
10-10-2020, 10:16 AM | #1591 | |
Rep 41
Would you like to try the following and only then come back with your comment? Take the 2 optical cables from the original bmw harness and plug it into the new android 10 harness, very important!! the green cable must be above the black one in the harness hole!, pull out the black cable that is already connected into the Android10 cables and plug the supplied aux cable in and the other head of it (aux) plug it in your armrest then do a reset via the reset hole behind the android housing (1 click) , wait for it to restart, now go to the aux of the bmw settings menu > external divece > aux front, it must be checked there (a green check mark) and then increase the volume to ... as you like it. let "us" even know if it helps now? Success |
10-10-2020, 10:32 AM | #1592 | ||||
Rep 519
yes, I moved the green and black optical cable to the new harness. I only received a splitter aux in my kit from 4x4shop.ca. which is what I'm confused about. I see the "aux out" jack on the new harness. so I need to go buy an aux extension cord I guess to run into the armrest. I also don't have signal on my Idrive side yet, just a blank screen with "no signal". so trying to figure that out still as well
10-10-2020, 10:52 AM | #1593 | |
Rep 353
You have F30 2017 model and it might be NBT Evo and your Android for NBT (not Evo). Usually Evo 2018+ but who knows 2017 also possible. Double check this. Your android sound is a secondary issue, normally Android HU for NBT doesn't require aux extension cable to the armrest, it sounds right away, just your male/female aux plug in the android harness should be connected. |
10-10-2020, 10:53 AM | #1594 | |
Rep 41
You didn't mention that earlier - to us - before! See this pic's.. (Only 1 aux cable with the same head: AUX Cable 3.5 mm to 3.5 mm Black.. as example) No splitter "we" got! Success |
10-10-2020, 11:02 AM | #1595 | ||
Rep 519
10-10-2020, 11:06 AM | #1596 | ||
Rep 519
10-10-2020, 11:14 AM | #1597 | |
Rep 41
Indeed, try that as first and I really hope for you that you don't need to send it back as "our" fora mate thought it was a wrong android car head unit? that's weird hassle indeed. Success |
10-10-2020, 11:38 AM | #1598 | |
Rep 8
Hello friend, sorry for the inconvenience. I have seen that you know a lot about this. And I have a problem. If you could solve it I would be willing to pay you thanks. A little over 1 year ago I put a 10.25 ”Chinese screen on my bmw e84 with android 8.1 Everything was working fine, but a couple of days ago it was stuck and I had to turn off the car to restart it and yesterday it did it again. This morning I got in touch with the aliexpress vendor to comment on everything and he told me to update the MCU and he sent me a file, mcuupdate.bin ... So I put it in a Pen and it updated perfect, it reached 100% and when it turned off .. it has not turned on again .... I tell the seller, he sends me another file: px6_format.zip saying that with that it restarts and everything remains the same. Does nothing. The only thing that adds two folders to the usb, android and logs .. (signal that is still alive) The seller doesn't answer me anymore ... Does anyone have any idea how to fix it? Pd: I pay whoever comes up with the solution. Thank you!! Last edited by fumero89; 10-10-2020 at 11:52 AM.. |
10-10-2020, 12:13 PM | #1599 | |
Rep 353
Do I get you right, your harness is different from this and you have only female Audio Out plug? |
10-10-2020, 12:17 PM | #1600 | ||
Rep 519
which company android unit is that?
10-10-2020, 12:27 PM | #1601 |
Rep 22
I have the unit since two weeks and i have issues connecting my iphone to the unit’s bluetooth. It connects after so many attempts. Is there any solution to this please?
10-10-2020, 12:31 PM | #1602 | |
Rep 353
Normally you can change settings in the navi apps to have audio muted during navi messages or mixed with them. On my experience mixed is more convenient not to interrupt your audio content during navi voice directions. Yes, you can run two navi apps at the same time and have voice messages from them. Sometimes I use one navi on the screen, another navi app in background (for speed cameras info), both speak voice messages. |
10-10-2020, 12:40 PM | #1603 | |
Rep 353
All Android HUs I saw during 3 years dealing with them had this aux connectors female-male (Audio Out - Audio In) in the harness. |
10-10-2020, 01:12 PM | #1604 | |
Rep 41
I know it was a bit confusing (for us) because yours is not like most here, (in my case of no sound coming from this android10 I had to use the aux cable to fix the problem and it did.. i'm not the only one with such a no sound problem!, my original bmw hu is or was (?) : Business ... is business no hard feeling as they said) .. try now the following before to buy an aux cable to be sure: put back your original hu in, go to aux settings and from there put the aux sound out of it to the max volume. and then play with the sound settings until you buy the cable.. maybe it helps? this is what I can think about it so far. Success |
10-10-2020, 01:17 PM | #1605 | |
Rep 41
And if you use a Sam foon instead of your iphone with it is it ok than? If yes, you know than the solution.. right? Ps: bt connect code is, 1234 .. try it, or 0000 too. Success |
10-10-2020, 01:18 PM | #1606 | ||||||
Rep 519
