01-29-2021, 04:23 PM | #23 | |
Rep 327
However, OEM LEDs with dedicated design from the get go (vs a retrofit) are quite good at illuminating. |
01-30-2021, 02:10 PM | #24 | |
Rep 4,891
Even in the new G20, same deal: https://g20.bimmerpost.com/forums/sh....php?t=1692789 So my recommendation to the OP stands: Try them before you waste your money. It would be an expensive OEM upgrade that will most likely leave you underwhelmed and disappointed. Other brands (like my Audi SQ5) hit the mark with LED headlights, but BMW is a swing and miss. |
01-30-2021, 02:48 PM | #25 | |
Rep 327
There's certainly no harm in what you're recommending but I've read those kinds comments before and couldn't help but feel they were hyperbolic (at least from within the BMW family). So I personally would think any proper Xenon/LED setup would be an upgrade from halogens he has. It's all relative though. I've now had decent experience with Nissan/Infiniti/Toyota/Lexus/VW/Audi halogens/reflector HIDs/bi-xenon HIDs and I think the BMW LEDs I have are just as good if not better. My father's VW OEM adaptive bi-xenons (35W, 4500k) are not great and I def would say unequivocally that my LEDs are brighter, more even, and have a sharper cutoff. I personally havent had access to the latest gen of LED/Laser lights either though. I sat in a friend's Ford Fusion (Mondeo in other markets) with OEM LEDs and within minutes into the ride, I was wondering why the LEDs were so dim at illuminating the road in front. So I understand that they are not all created equally. Last edited by jnj2455; 01-30-2021 at 03:50 PM.. |
01-30-2021, 07:55 PM | #26 | |
Rep 884
The only way you can make this work is via a projector housing that doesn't using a reflector assembly; such as the Depo you are contemplating. |
floridaorange10235.50 |
01-31-2021, 10:31 AM | #28 | ||
Rep 1,066
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block Build Thread: https://f30.bimmerpost.com/forums/sh....php?t=1742413 IG + YT: Sqwin_n20 |
02-02-2021, 02:08 PM | #29 | |||
Rep 884
02-03-2021, 09:21 PM | #30 |
Rep 1,758
OP I strongly recommend a good quality new halogen bulb (they actually diminish over time, in my Z3's I change them every two years because they are not high mileage cars). After that I suggest you re-aim the headlights. Sounds like they aren't adjusted properly. Best of luck!
2016 428ix, r, 2018 430iC, 2018 330it
02-06-2021, 03:48 PM | #31 | |
Rep 376
I almost sent my headlights into them for a clear lens swap, something different from your needs but also requires opening the headlight. I ultimately found a shop (BayOptiks) closer to me and just drove to them. In either case, just wanted to throw this option out there. Can't hurt to ask. Good luck!
2014 BMW 328i, 6-speed Prem / Nav / Drivers Assist / Heated Seats / Lighting |
