BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Fuel-It... Opinions needed for stage 3 or port injection for engine cut@high rpms
      03-22-2018, 03:09 PM   #1
PabloK
PabloK's Avatar
Question
Sorry if this has been beaten to death.
N55 - EWG Pure stage 2 with strictly 93.
proper plugs and gap
Bootmod3 flash, many tune revisions - same issue (on new v5)
No desire for E85
running factory fuel pump that was recalled couple years back
Full throttle, car hits about 4-5,000 RPMs and will start cutting out/backfiring. I will literally get thrown forward in my seatbelt the backfire/engine cutting is so pronounced
I sent an older data log (stage2 -93 octane V1) to Steve at Fuel-it.
http://www.bootmod3.net/log?id=5a197cb2d10b435804b57440
His excellent response.
Your HPFP requested pressure is 2800psi but your rail pressures are dropping to 1200psi. Pretty common on the F-series N55 as the HPFP is pretty weak on those cars.
Adding port injection will resolve the HPFP limitations. If running just 93 you can stick with an Stage 2 LPFP as that will be sufficient. However on the F-series, we often recommend a Stage 3 LPFP because it retains the stock LPFP during normal driving conditions and then activates the secondary under highboost. That saves wear and tear on the EKP that controls the LPFP and prevents it from overheated due to additional current draw from the upgraded pump. That also eliminates possible iDrive errors for the additional current draw.
This stuff is pretty much over my head/new territory. Has anybody had similar issues and does this make sense? I've read many posts saying the fuel pump upgrade is not needed for 93 stage2 but i need another opinion.
Do i go with a stage 3 or Port injection?
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is
2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3
2017 Alpina B6
22 Ram Trx / 22 M5 CS
FSociety3812.50
      03-22-2018, 04:14 PM   #2
M-terkait
M-terkait's Avatar
Kuwait
209
Drives: F30 335i 3/13
I doubt you need it just for pure stage 2 on 93octane, I use PI with 93octane for my doc-race but when I had pure turbo I was already at the limit of octane anyway didn't need to use PI.
anyways i use stage 2 lpfp and PI. 450walbro should support up to 700hp on pump gas
Edit: Request tune update from PTF, if they could help even if you lose 10-20hp its not worth gaining 20hp and get PI + controller + Lpfp stage 2.
Docrace 6266
PabloK597.00
FSociety3812.50
      03-22-2018, 04:55 PM   #3
PabloK
PabloK's Avatar
So stage 3 might be overkill but I'm reading the stage 2 can sometimes cause I-drive errors.
Seems like the stage 3 is a more complete package without any potential issues down the road
Stage 2 can cause additional current draw on the EKP to run that pump.
That alone would push me to the stage 3...
2017 Alpina B6
      03-22-2018, 09:04 PM   #4
SeanWRT
SeanWRT's Avatar
3179
Drives: E90 M3 & F87 M2
Did you just send the wrong log link? HPFP is fine from that one. Post the log with falling HPFP please.
Needing additional fueling or not depends on how hard and what range of RPM you push it. On pump gas, octane limit comes at the same time as, if not a little earlier than fueling one, if it's tuned properly.
Lemania 2320
PabloK597.00
      03-24-2018, 10:05 AM   #5
zinner
zinner's Avatar
Drives: `17 X5 35d/`15 335i/`18 M550IX
Pablo you are at the end of the road on the N55 if you don't want to do E85. Just lower the boost target to around 16 and be happy :-D Assuming from your location it's really cold out, you can't hit the same boost targets in the colder air, just not enough fuel can be delivered.
PabloK597.00
      03-27-2018, 08:55 PM   #6
PabloK
PabloK's Avatar
I'll make a fresh map tomorrow
2017 Alpina B6
      03-28-2018, 12:55 AM   #7
PabloK
PabloK's Avatar
isn't this it?
Thats full throttle... and the drop in HPFP ACT. directly correlates to when I'm getting cutting out.
I'll do a new log tomorrow, I just flashed v6...
2017 Alpina B6
FSociety3812.50
      03-28-2018, 12:58 AM   #8
PabloK
PabloK's Avatar
I believe I'm around 16.5 Boost. New log coming tomorrow, supposed to be in the 50s
2017 Alpina B6
      03-28-2018, 01:08 AM   #9
PabloK
PabloK's Avatar
Could I theoretically just get stage 3 and be done with it? Why skimp I'm this deep in?
2017 Alpina B6
      03-28-2018, 07:17 AM   #10
JaredG_F30
JaredG_F30's Avatar
1106
Buy nice or buy twice!! Go for it.
SPI Films Blog/DIY Vids
Tchao333.50
kevinjt151.50
IK6SPEED4490.00
PabloK597.00
      03-28-2018, 07:30 AM   #11
SeanWRT
SeanWRT's Avatar
3179
It seems to be HPFP failing to keep rail pressure. But doesn't tell the whole story. Post the log link. It takes full data to know where and how. There're plenty of OTS users doing fine on stock fueling. Chances are you're an isolated case.
isn't this it?
Lemania 2320
FSociety3812.50
      03-28-2018, 08:44 AM   #12
zinner
zinner's Avatar
He already posted the link you just looked at the wrong part of the log.
PabloK597.00
      03-28-2018, 10:21 AM   #13
PabloK
PabloK's Avatar
Thanks for the help boys. It's much much appreciated.
I'll get a lot today!
2017 Alpina B6
      03-28-2018, 06:36 PM   #14
M-terkait
M-terkait's Avatar
Kuwait
209
I run stage 2 lpfp with PI on pump gas, walbro450 in this stage 2 can deliver alot for pump gas, and on ethanol thats enough, you can still upgrade to stage 3/4 later for the fraction of the price.
stage 3 runs sequential two-lpfp not sure how is it triggered, but stage 2 is much simpler and more than enough for your pure stage 2.
Docrace 6266
      03-28-2018, 09:58 PM   #15
IK6SPEED
Drives: BMW M3 / AH3
No desire for E85
So he is saying you need a $1k Stage 3 LPFP and a $1.5k port injection?
      03-29-2018, 12:54 AM   #16
PabloK
PabloK's Avatar
his message was confusing... I initially thought the same thing.
I'm going with the stage 3 to avoid idrive errors.
2017 Alpina B6
      03-29-2018, 12:58 AM   #17
PabloK
PabloK's Avatar
its triggered with some electrical switch, it's fully automatic.
I'm sure stage 2 is sufficient, but I don't want to fuck with i-drive errors. thats a deal breaker for stage 2
stage 3- overkill but better overall package with less potential issues down the road. I want the car to run properly, I'm not going to decrease boost if the issue can be fixed for $900.
2017 Alpina B6
      03-29-2018, 08:12 AM   #18
ronanz
Gettin It Figured Out
ronanz's Avatar
Drives: 435i FBO PS2 bm3 w/ options
I've never experienced iDrive errors...
My Build Thread can be found HERE
      03-29-2018, 12:03 PM   #19
SeanWRT
SeanWRT's Avatar
3179
OP, your map isn't aggressive at all. Need to fix boost control on gear shift. All in the tune. You don't need additional fueling.
Lemania 2320
PabloK597.00
      03-29-2018, 02:24 PM   #20
PabloK
PabloK's Avatar
Does BM3 do flash revisions on the ots maps?
Thanks for the help guys......
2017 Alpina B6
      03-29-2018, 02:25 PM   #21
PabloK
PabloK's Avatar
Maybe just some isolated cases? Just the info I got from fuel it. Thanks for the input.
2017 Alpina B6
      11-15-2018, 06:36 PM   #22
M248
Drives: 2014 435i M Sport
Hey man did you ever figure this out? I’m having the same issues with my F33 N55 using any variant of the it’s stage 2 MHD tune. My stft’s are super positive around +20%. I’ve also had the lpfp recall. I notice when my stft’s are positive and I enter high boost, my HPFP dips from requested and I get throttle and boost cut as a result. I get the same stuttering symptoms too, just not backfires and heavy lurches.
A forum member who also custom tunes was king enough to send me a stft fix map, but running e20 my stft’s are still very positive, and HPFP issues remain.
I ended up purchasing stage 3 lpfp for the same reasons you cited. I also ordered EOS PI with jb4. I’ll be upgrading to ps2 and want to run full e85 which is plentiful in Michigan, with minimum ethanol contents of 70%.
2014 Cabrio M-Sport 435i, MHD Stage 2+, Wagner HFC Downpipe, VRSF Race FMIC, CP & TIC, GFB DV+, EOS PI, AIC2-V, Fuel-IT Stage 3 525.
