03-22-2018, 03:09 PM | #1 |
Rep 1,805
Sorry if this has been beaten to death.
N55 - EWG Pure stage 2 with strictly 93. proper plugs and gap Bootmod3 flash, many tune revisions - same issue (on new v5) No desire for E85 running factory fuel pump that was recalled couple years back Full throttle, car hits about 4-5,000 RPMs and will start cutting out/backfiring. I will literally get thrown forward in my seatbelt the backfire/engine cutting is so pronounced I sent an older data log (stage2 -93 octane V1) to Steve at Fuel-it. http://www.bootmod3.net/log?id=5a197cb2d10b435804b57440 His excellent response. Your HPFP requested pressure is 2800psi but your rail pressures are dropping to 1200psi. Pretty common on the F-series N55 as the HPFP is pretty weak on those cars. Adding port injection will resolve the HPFP limitations. If running just 93 you can stick with an Stage 2 LPFP as that will be sufficient. However on the F-series, we often recommend a Stage 3 LPFP because it retains the stock LPFP during normal driving conditions and then activates the secondary under highboost. That saves wear and tear on the EKP that controls the LPFP and prevents it from overheated due to additional current draw from the upgraded pump. That also eliminates possible iDrive errors for the additional current draw. This stuff is pretty much over my head/new territory. Has anybody had similar issues and does this make sense? I've read many posts saying the fuel pump upgrade is not needed for 93 stage2 but i need another opinion. Do i go with a stage 3 or Port injection?
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is 2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3 2017 Alpina B6 22 Ram Trx / 22 M5 CS Last edited by PabloK; 03-22-2018 at 03:15 PM.. |
03-22-2018, 04:14 PM | #2 |
Rep 1,252
I doubt you need it just for pure stage 2 on 93octane, I use PI with 93octane for my doc-race but when I had pure turbo I was already at the limit of octane anyway didn't need to use PI.
anyways i use stage 2 lpfp and PI. 450walbro should support up to 700hp on pump gas Edit: Request tune update from PTF, if they could help even if you lose 10-20hp its not worth gaining 20hp and get PI + controller + Lpfp stage 2.
Docrace 6266
03-22-2018, 04:55 PM | #3 |
Rep 1,805
So stage 3 might be overkill but I'm reading the stage 2 can sometimes cause I-drive errors.
Seems like the stage 3 is a more complete package without any potential issues down the road Stage 2 can cause additional current draw on the EKP to run that pump. That alone would push me to the stage 3...
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is 2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3 2017 Alpina B6 22 Ram Trx / 22 M5 CS |
03-22-2018, 09:04 PM | #4 |
Rep 2,577
Did you just send the wrong log link? HPFP is fine from that one. Post the log with falling HPFP please.
Needing additional fueling or not depends on how hard and what range of RPM you push it. On pump gas, octane limit comes at the same time as, if not a little earlier than fueling one, if it's tuned properly.
Lemania 2320
PabloK597.00 |
03-24-2018, 10:05 AM | #5 |
Rep 1,127
Pablo you are at the end of the road on the N55 if you don't want to do E85. Just lower the boost target to around 16 and be happy :-D Assuming from your location it's really cold out, you can't hit the same boost targets in the colder air, just not enough fuel can be delivered.
PabloK597.00 |
03-27-2018, 08:55 PM | #6 | |
Rep 1,805
03-28-2018, 12:55 AM | #7 | |
Rep 1,805
Thats full throttle... and the drop in HPFP ACT. directly correlates to when I'm getting cutting out. I'll do a new log tomorrow, I just flashed v6...
FSociety3812.50 |
03-28-2018, 12:58 AM | #8 | |
Rep 1,805
I believe I'm around 16.5 Boost. New log coming tomorrow, supposed to be in the 50s
03-28-2018, 01:08 AM | #9 | |
Rep 1,805
03-28-2018, 07:17 AM | #10 |
Rep 1,499
Buy nice or buy twice!! Go for it.
03-28-2018, 07:30 AM | #11 |
Rep 2,577
It seems to be HPFP failing to keep rail pressure. But doesn't tell the whole story. Post the log link. It takes full data to know where and how. There're plenty of OTS users doing fine on stock fueling. Chances are you're an isolated case.
Lemania 2320
FSociety3812.50 |
03-28-2018, 10:21 AM | #13 | |
Rep 1,805
Thanks for the help boys. It's much much appreciated. I'll get a lot today!
03-28-2018, 06:36 PM | #14 | |
Rep 1,252
stage 3 runs sequential two-lpfp not sure how is it triggered, but stage 2 is much simpler and more than enough for your pure stage 2.
Docrace 6266
03-28-2018, 09:58 PM | #15 | |
Rep 10,473
03-29-2018, 12:54 AM | #16 | |
Rep 1,805
I'm going with the stage 3 to avoid idrive errors.
03-29-2018, 12:58 AM | #17 | |
Rep 1,805
I'm sure stage 2 is sufficient, but I don't want to fuck with i-drive errors. thats a deal breaker for stage 2 stage 3- overkill but better overall package with less potential issues down the road. I want the car to run properly, I'm not going to decrease boost if the issue can be fixed for $900.
03-29-2018, 08:12 AM | #18 | |
Gettin It Figured Out
1820
Rep 2,669
I've never experienced iDrive errors... .
03-29-2018, 02:24 PM | #20 | |
Rep 1,805
Thanks for the help guys......
03-29-2018, 02:25 PM | #21 | ||
Rep 1,805
11-15-2018, 06:36 PM | #22 |
Rep 23
Hey man did you ever figure this out? I’m having the same issues with my F33 N55 using any variant of the it’s stage 2 MHD tune. My stft’s are super positive around +20%. I’ve also had the lpfp recall. I notice when my stft’s are positive and I enter high boost, my HPFP dips from requested and I get throttle and boost cut as a result. I get the same stuttering symptoms too, just not backfires and heavy lurches.
A forum member who also custom tunes was king enough to send me a stft fix map, but running e20 my stft’s are still very positive, and HPFP issues remain. I ended up purchasing stage 3 lpfp for the same reasons you cited. I also ordered EOS PI with jb4. I’ll be upgrading to ps2 and want to run full e85 which is plentiful in Michigan, with minimum ethanol contents of 70%.
2014 Cabrio M-Sport 435i, MHD Stage 2+, Wagner HFC Downpipe, VRSF Race FMIC, CP & TIC, GFB DV+, EOS PI, AIC2-V, Fuel-IT Stage 3 525.
