12-04-2015, 03:35 AM | #23 |
Rep 931
BMW F82 M4 Black MHD CS Map - GTS DKG - Navi -Performance Brake RSL1 Pads - USB - DivX-DVD - Bluetooth - VoiceControl - Connect - Apps - Online - H&K - TrafficInfo - SpLimInfo - WhiteMerino- PDC - Cam - Adaptive Led - Antitheft - CP Steering- Performance ST - Adaptive CP Setup - GarageDoorOpen - Pipercross - Stock Exhaust - Mdrivers Pack - 437M Wheels
12-04-2015, 10:47 AM | #25 |
Moon Parasite
654
Rep 1,336
Something has been getting hot, discolorations around certain component mount points.
2020 X4M Comp. (currently stock) - Was 2015 335 MSport -MPPK -Borla ATAK -Dinan Sport+ - E.R. Charge pipe / 2013 X1 35i Sport - Dinan tune / 2009 X6 50i Dinan badged |
12-04-2015, 10:52 AM | #26 |
Rep 902
Drives: 13' F30 385xi VNV Speed Custom
Garage List 2013 Mercedes SL63 ... [0.00]
2010 VW Tiguan 2.0 ... [0.00] 2015 Tesla P85D [0.00] 2014 Mercedes S63 AMG [0.00] 2007 Mercedes GL450 [0.00] 1967 Ford Mustang [0.00] 2013 BMW F30 335xi [0.00] |
I think I'm taking another stab at this today, while removing my Dinantronics and installing my JB4 and plumbing + wiring for BMS meth.
Will post back with results and pics from DME job. Waiting for engine to cool now.
13' 335xi, ACF Tuned, ACF Stage 3 Turbo Kit (67mm),PDU PI, ACF Stage 4 LPFP, M-Perf Brakes, AEM CM10 Meth/Nitro, CG DR-1 + VS-1 3.5" Turboback, AFe S2 CAI+Ram Scoop, ER Chargepipe, Wagner EVOII Comp. FMIC, Stop-Tech SS Brake Lines, BMS Sport Oil Cooler Valve+Spacers F10mm R15mm, 19" Bridgestone Potenzas, KW EDC Coilovers, CF Seibon Hood + CSL trunk. Track:Pagid Race Pads, Stop-Tech Custom Pads Front+Rear Racing Tow Hooks
12-05-2015, 03:47 PM | #28 |
Rep 902
Well I spent 13 hours straight working on my car yesterday and unfortunately got distracted doing other things after i pulled the manifold and DME.
I pulled my Dinantronics, rerouted some other wiring, installed my JB4 (after fixing some unfortunate harness defects), installed and plumbed my Meth tank and pump (again after fixing up some unfortunate defects), and after all of this I finally got around to hacking it yet again. And as soon as I tried to connect to my DME, the software alerted me to a new version of the software which had been released last week. I had some trouble getting the new version because the link it alerted me to was dead, so I had to dig a bit to find the new version. The new interface is much cleaner, and seemingly more complex, or perhaps just more verbose. Here's a screenshot of the new interface for the DME I'm using. Unfortunately this time around ended basically the same was as last, I physically hack the board, then run into software issues as soon as I'm ready. Since I already spent all day working on my car, I needed to get myself home so I had to put everything back together, but this time to save myself some time next time around I did things a little differently. Since the boot pin that requires shorting is so small, I found it very difficult to solder the larger gauge resistor wire to the board without risking damage to the surrounding area. I decided to use 30 AWG Kynar wire this time which fits perfectly through the hole. Using a very thin soldering iron tip it was much easier to secure the kynar wire to the board without any visible damage to the board. I taped up the remaining stripped kynar wire at the board connection, and led a long strand of insulated kynar wire out the seal of the DME up into a sealed bag stowed under my brake system cover, with hopes that when I finally get some real software support I can easily pop out the DME connections and short and hack the board while its still under the manifold, which would significantly reduce the time this job takes. And again, despite soldering my DME board, the car fired up and ran perfectly on my way home. Just waiting on software support for this very new version.
12-05-2015, 04:19 PM | #29 |
Rep 902
Here's some other background info I should have posted earlier.
This is the guide from the ECU Explorer devs to connecting + shorting the MEVD1762 (N55) DME board. I should also mention this is not the only DME the F30 N55s use, it's one of several. Also here is a screen shot of the default locked DME function Values decrypted via ESys that we are attempting to change. Specifically MIL_codierung (CEL suppression), KAT (catalytic converter efficiency monitor), VMax (electronically limited top speed), and mostly for EU users, Vartianten_config (which is necessary to bring limited output engines up to their full output capacity) and also Laendercodierung (Region/Country Selection).
Poochie9104.50 |
12-06-2015, 12:55 AM | #30 |
IG @bmwF9xG80
3813
Rep 7,593
Wow !! keep up the amazing progress
60-130mph 6.5s X4M #HCP
12-06-2015, 04:21 PM | #31 |
Rep 152
It's a russian tool that has been released over a year ago. When the first russians posted about this tool nobody believed them. It also allows for power class change. For instance, this tool allows you to change the engine salapa element and then use ISTA or INPA to upload the corresponding software. So my 320 would behave like a 328 since they share the same engine beside pistons (compression ratio).
OP, how much did you pay for hardware and software? The last time I checked it was 1000 EUR. |
12-06-2015, 05:21 PM | #32 | |
Rep 902
12-06-2015, 06:15 PM | #34 | |
Rep 902
Specifically from their NYC based partner who goes by the name Dashmaster.
01-28-2016, 11:16 PM | #35 |
Rep 1,563
Did anything come of this? I am considering purchasing this software to try to remove the security on my N55 e84 which shares the MEVD1726 ECU with the F30. Were you able to read your ISN?
01-28-2016, 11:49 PM | #36 |
Rep 902
Nope, still can't get it to work, but it may just be my DME (MEVD172Y), I've not tried another variant.
Your variant is listed in the compatibility page. I definitely cannot recommend this program to anyone because there is 0 support and its not the most intuitive tool and comes with essentially no documentation, the site documentation is fragmented and contradictory etc. I still can't say for sure whether or not this product works at all, since I've only had access to my own DME for testing.
01-29-2016, 08:30 AM | #37 | |
Rep 25
01-29-2016, 08:32 AM | #38 |
Rep 1,563
Thanks for the quick response.
What type of issue are you running into - is it that you don't know the process to read the ISN and reset the counter because there is no documentation, or that the software won't communicate with the car? I have been trying to reset the counter on my ECU for a long time, but it's virtually impossible to find info on this software outside of a few Russian forums. You're the first English speaking person I have found that has experience with this software, so I really appreciate the help. |
01-29-2016, 10:02 AM | #39 |
IG @bmwF9xG80
3813
Rep 7,593
cryptocar have you heard of DimSport ? or Smartecu ?
01-29-2016, 12:00 PM | #40 | |
Rep 902
01-29-2016, 12:02 PM | #41 | |
Rep 902
01-30-2016, 07:11 AM | #42 |
Moon Parasite
654
Rep 1,336
Watch out for paradoxical3, he's one of those crazy E84 35i owners
02-10-2016, 08:32 AM | #43 |
Rep 18
System time reset
Hello Cryptocar,
I am wondering, if this software you have can also reset system time in a dump when not connected to the DME directly. Why I am asking: I have a bit of problem with one MEVD172 ECU, in which we tried to change the VIN using BMW Explorer tool. This worked, BUT it messed up some variant coding which is only possible to access with the system time below 10 hours. I am willing to pay you, if it would be possible to send you the full dump of the ECU and you could reset the system time so that I will be able to recode the car back to the stock version. Now the car (F13 640i) has about a half power and I need to get a way out of this situation and I am not willing to purchase the tool only for one-car use. Thank you very much for any reply! Martin, Czech Republic |
02-10-2016, 03:51 PM | #44 | |
Rep 902
As far as I understand the program I have requires the physical ECU board or the Infineon tricore chip removed from board because the only way to access the chip's eeprom is via powering it on in boot mode to dump and write the hex data. Don't think the software does any good to dump files.
