11-10-2019, 09:19 PM | #1 |
Rep 144
Was going forward and secure against rolling put my car in park
I have an F36 2015 gran coupe and I was going forward maybe about 5mph and I opened my door to greet my dog and the car slammed into P. I heard a weird noise, like maybe plastic gears grinding. Transmission seems to be fine drives and parks great. Does anyone know if this will cause damage down the road I kinda hate bmw for adding that feature.
11-10-2019, 11:02 PM | #2 | |
Rep 1,452
I won’t even ask why you were allowing your dog to approach a moving car. |
tex26702412.50 |
11-10-2019, 11:08 PM | #3 |
Rep 55
I learned about this the other day as well.. Pulling into my garage after I had done some mechanical work to my winter beater, tried pulling forward with my door open so I could gauge how much room I had to get out afterwards (narrow garage). Moved forward a couple inches and thought I plowed into something when the car went into park.
My new trucks never did this to me haha.
2018 340i X-Drive | M-Sport | MPPSK | Dinan Intake
11-10-2019, 11:23 PM | #4 | |
Rep 10,473
tex26702412.50 AngelFarelli56.50 |
11-11-2019, 12:14 AM | #5 |
Rep 2,805
Drives: F33 430 and F39 M35i
If you put your seatbelt on it will not shift to park on its own with the door open.
Billfitz8243.00 Carlosskrr32.50 |
11-11-2019, 06:54 AM | #6 |
Rep 16,080
Correct. If you have your seatbelt buckled the car is fairly certain that you're not going to exit the car, so it will let you open the door while moving. If you don't then not knowing if you're too stupid to put the car in park before getting out it assumes the worst and puts it in park, just in case.
11-11-2019, 07:54 AM | #7 | ||
Rep 144
11-11-2019, 08:01 AM | #8 | |
Gettin It Figured Out
1820
Rep 2,669
You're fine. I'm fairly certain this can be coded out as well. .
Carlosskrr32.50 |
11-11-2019, 08:33 AM | #9 |
Rep 2,670
I'd love to code this out - sometimes I'll need to quickly move the car a little in our driveway and buckling / closing door is not needed in those particular scenarios only.
Carlosskrr32.50 |
11-12-2019, 09:45 AM | #11 |
Rep 16,080
If Anton Yelchin's Jeep had this feature it wouldn't have killed him. I back into my very narrow circa 1938 garage, and I have to open my door to be sure that I've got it lined up with the foam rubber padding I glued to the concrete block garage wall that marks the right spot to park. If I pull the car into the driveway to work on it and then back it into the garage again I have to buckle my seat belt for that 20 foot trip. As with most First World Problems I manage to deal with it.
11-12-2019, 10:20 AM | #12 | |
Rep 5,995
11-12-2019, 01:59 PM | #14 |
Rep 1,502
I think if you start the car with the door already open, that’ll also allow you to move it with the door open without the seatbelt on.
I wonder why BMW doesn’t slam the brakes in addition to activating park? Seems like the brakes would be way more effective. I assume with ABS and e-Diff and all that other stuff, the car can fully activate the brakes on its own. |
11-12-2019, 06:23 PM | #15 |
In the garage
62
Rep 100
This is another stupid nanny option that some manufacturers have added. I found it a couple weeks ago when I drove down a road that just ended. There was no cul-de-sac, so I needed to back into a grassy driveway opening to turn around. Only problem is, I couldn't see. The back up camera washed out because my car is white, so it was useless. I opened the door so I could back up without going into the drainage ditch, but the car wouldn't let me move. I got very irritated with the car at this point.
I hate all of the nanny controls on these cars. Are drivers really this incompetent today that we're not allowed to make decisions ourselves?
2016 435i ZHP
Carlosskrr32.50 |
11-13-2019, 09:54 PM | #16 | |
Rep 79
Cut a small piece of black electrical tape to cover the lower portion of the camera lens such that the white bumper is obscured, and the camera will no longer adjust the contrast/exposure because of the bright white bumper. By doing so, your camera’s night vision will improve markedly. |
11-14-2019, 02:00 AM | #17 |
2JZ-GTE
3038
Rep 3,992
11-14-2019, 07:11 AM | #18 |
Rep 16,080
11-14-2019, 09:50 PM | #19 | |
Rep 257
2021 i3s AC Schnitzer BMW CCA #67486 |
11-14-2019, 09:52 PM | #20 | |
In the garage
62
Rep 100
And to the comment about the seat belt, I had to disconnect my seat belt after opening the door to lean out the door far enough to see what was behind me, so comments like that aren't needed. Also, if you've ever been in a bad car accident and you were trapped because of the seat belt, you might not like the idea of wearing one. There are pros and cons to wearing one, just like there are pros and cons to airbags, run flat tires, auto locks and every other security feature.
2016 435i ZHP
11-14-2019, 11:19 PM | #21 | |
Rep 2,294
2018 340i xDrive M Perf Edtn Sunset Orange
Previous BMWs - 19 others since 1971. |
Billfitz8243.00 |
11-15-2019, 10:18 PM | #22 |
M340i
393
Rep 968
Drives: BMW M340i
Carlosskrr32.50 |
