01-25-2018, 02:08 PM | #67 | |
Rep 2,083
I cannot just go and drop $1000 for bm3 then still need to use jb4 in the future for meth controller if I get the meth kit.
01-25-2018, 05:33 PM | #68 | |
Rep 1,499
If I already had JB4 as you do I would do exactly that. I never had JB4 so just went straight to BM3 and have been extremely happy with it. It's good to have MHD in the game though. Competition is a good thing.
yoandry692.50 |
01-29-2018, 11:21 AM | #69 | |
Rep 2,083
Before raise a bit to 15psi in the midrange and 16psi in the higher rpms, I want to know what's the lower AFR can go too rich? I'm seeing around 12 and 11 under load but it goes lower than that if there is boost spike and shifting which boost go higher also, then as AFR is running to rich, FP_h crash with 8-11 values.
01-29-2018, 11:30 AM | #70 | |
Rep 969
01-29-2018, 12:54 PM | #71 | |
Rep 2,639
yoandry692.50 |
01-29-2018, 01:30 PM | #72 |
Rep 2,083
So, flash tuner can set AFR values or it depends on something else? What's your psi target?
01-29-2018, 03:28 PM | #73 |
Rep 2,639
Yeah, flash can set AFR, on 91, it targets 15-15.5psi, and 93/94, it targets 16-17psi, though it goes to 18psi mid range and tapers to 16psi up top.
01-29-2018, 04:42 PM | #74 | |
Rep 2,083
https://datazap.me/u/yoef30/befjb4?l...4-5-8-10-18-20
F30_SixSpeed1170.50 |
01-29-2018, 06:57 PM | #75 | |
Rep 2,639
01-30-2018, 09:47 AM | #76 | |
Rep 2,083
This is on 15psi. Tried 16 and fuel pump crash at redline, throwing drivertrain malfunction, fuel pump pressure lower than expected code on jb4. As pwg boost is a wild horse15 will be fine as it goes over that sometime.
01-30-2018, 10:10 AM | #77 | |
Rep 2,639
IMO, you would highly benefit from BM3 flash over MHD as BM3 has access to tons of more tables than MHD does. They even found out how to control PWG boost right now and smooth it out. MHD is in beta and you are not getting the necessary flash tables that you need to get the full potential out of 93 oct.
01-30-2018, 11:12 AM | #78 | |
Rep 2,083
01-30-2018, 04:44 PM | #79 |
Rep 1,348
Consider the Active Autowerkes flash as well if I were you.
2k15 335i Msport xdrive 6spd
02-02-2018, 09:00 AM | #81 |
Rep 2,083
I may get meth sooner than expected as I got my $775 turbo core back
Now, with meth do I still need to upgrade the lpfp if I'm just going to use 93 and stay around 18-20psi? Not going to go over 20psi and maxout something. Just want the extra fuel help for the hpfp on 50/50 mix i guess. Meth is around $600 and PI starts @ $1200 + $500 for lpfp. I dont think is worth it as I dont want to go over 20psi.
terryd5150507.00 |
03-08-2018, 04:11 PM | #82 |
Rep 2,083
Guys, PI or Meth
This fuel-it DIY PI isn't that expensive than the regular one. Will this PI kit for $1225 be a better option than BMS meth kit @ $625 in a hot state like Florida? Which one will cool better, Ethanol or Methanol? I have e85 access but what about if have to use just 93 in a trip? I would need also stage 2 lpfp right? $299 I'll be running either 2 options with MHD bef + jb4.
03-08-2018, 04:31 PM | #83 | |
Gettin It Figured Out
1820
Rep 2,669
THIS EOS Intake Manifold is a cool option as well... .
03-08-2018, 04:34 PM | #84 | |
Rep 1,348
Ethanol Fuel will burn better ,cleaner,more HP and timing advance with out using meth. And imop more reliable like using race fuel but on the cheap.Meth will be used to cool the charge so you can run advance timing and boost. Id do port injection and E85 by far over meth with the proper OTS map. I like like pure E85 better especially because its more knock resistant if you do not go too nuts with the timing..
03-08-2018, 05:11 PM | #85 | ||
Rep 2,083
Yes, better cooling effect as Im in a hot area. What about if I have to pump just 93 when no e85 is around?
03-08-2018, 09:03 PM | #86 |
Rep 1,348
Meth or racing fuel in that case
03-09-2018, 08:36 AM | #87 |
Father of Frankenfold
299
Rep 531
Drives: Yo daddy's 2014 X3 M Sport
The EOS PI manifold is a pretty good deal for a trick manifold with integrated PI. I just bought the EOS PI spacer kit with JB4 controller and 52 lb injectors and added an E85 sensor on the supply line to the motor. Works well with my BM3/JB4 stack. The PI setup was less than $1K, since it's on sale. You can do a DIY Walbro LPFP for under $150.
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
03-09-2018, 09:01 AM | #88 | |
Rep 2,083
https://www.eospeed.com/collections/...=1822173855753 The only problem is that when time comes to ask Terry/Steve for help, I wont get as much support than fuel it. So Im actually trying to debate first between PI vs BMS meth. Which one will be better for a long run as a DD. Is it worth it the double price on PI from meth?
