10-02-2021, 06:41 PM | #1 |
Rep 383
Datalogging Questions
Hey so i just data logged my car with bm3, im stage 1 with catless dp on a n26 motor and Im a noob when it comes to reading them so can anyone help me out
https://www.bootmod3.net/log?id=6158...90c67c64a9c6aa https://www.bootmod3.net/log?id=6158...729b7f195b2bb6 |
10-02-2021, 07:21 PM | #2 |
Rep 263
No intercooler upgrade? Boost looks good, but timing looks low and a bit erratic. Most likely due to high IAT and crappy 91 fuel. Nothing to worry about though.
10-02-2021, 07:22 PM | #3 |
Rep 383
10-02-2021, 07:25 PM | #4 |
Rep 383
10-03-2021, 04:40 PM | #5 |
Rep 263
Not sure about the N26, but the N55 generally starts retarding timing around 120 degrees IAT. It reduces roughly 10%, then 25% at about 140 degrees, which is where you'll be on your shift to 4th. So even stage 1 could use an intercooler to maintain max power.
If you're in Cali, I would definitely run the ACN91 tune unfortunately.
2018 340i F30 Xdrive
10-03-2021, 04:42 PM | #6 | |
Rep 383
10-03-2021, 07:19 PM | #7 |
Rep 263
I never had luck with Shell gas on any of my previous tuned cars - even 93. Always chasing knock and timing issues. Costco gas is working perfectly - 93 of course in NC.
10-04-2021, 10:28 AM | #8 |
Rep 383
10-04-2021, 12:57 PM | #9 |
Rep 1,064
The timing is all over the place. the fuel system is keeping up with LPFP and HPFP targets. If you are in LA/Cali, you have more sulfur added to your gas for the entire state. Switch to ACN and it should clear up. On average you should be putting down around ~250whp from what your log shows on a dynapack. If you haven't yet, make sure you are running the stock plugs at .022 gap. your AFR looks pretty stable and in very safe ranges.
10-04-2021, 01:40 PM | #10 | |
Rep 383
10-04-2021, 01:48 PM | #12 |
Rep 383
yea i never saw any thread or info on it but ill run it when i get home from school, but i havent noticed anything off with normal 91 but if logs say other wise then im more than happy to make the switch if it means the car runs healthier ill run a log with it as well and send it over to you! probably some time this week
10-04-2021, 04:13 PM | #13 |
Rep 1,064
Lol don't send it to me. Just post it and ask for feedback. Not trying to be your tuner 😅
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block Build Thread: https://f30.bimmerpost.com/forums/sh....php?t=1742413 IG + YT: Sqwin_n20 |
10-04-2021, 04:15 PM | #14 |
Rep 383
10-04-2021, 11:39 PM | #15 | |
Rep 383
10-06-2021, 12:22 PM | #16 |
Rep 1,064
It looks drastically better but you really need to do a pull in 4th gear. There's not enough "load" to see how your car reacts. Making around the same power it seems too. Might have to change plugs or check cylinder 1 if it doesn't clean up.
10-06-2021, 01:50 PM | #17 |
Rep 383
ok ill do one later this week
