05-10-2023, 04:47 PM | #1 |
Rep 26
Drives: 2013 328i Luxury Line
N20 With E85
Ive been on the fence about going to a full E85 tune, im currently FBO with a VRSF catless downpipe, intercooler, BM3 tune and an Ingen intake. I havent seen many people do E85 on their N20s, would a LPFP be good to run full E85 and can the engine handle it or are there other upgrades needed?
05-11-2023, 09:24 PM | #2 | |
Rep 28
You can get an E85 kit here https://iposmotorsport.com/products/n20-full-e85-kit |
05-12-2023, 07:36 AM | #3 | |
Rep 1,066
Engine will be fine. Stock n20/n26 turbo maxed out around 31-32 lb/min for air flow, and with multiple sets of data for n20/n26, on the stock turbo MAF readings is pretty close to power at the wheels. 100% stock turbo + all FBO (you are missing a turbo inlet to help a little more) + b58tu HPFP retrofit (doesn’t need a tune for this HPFP), custom tune you are looking 310-320whp on full ethanol. Fueling setup for this dyno and the bigger turbo: stock LPFP B58tu HPFP S63tu injectors https://youtu.be/qboROltR6gg
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block Build Thread: https://f30.bimmerpost.com/forums/sh....php?t=1742413 IG + YT: Sqwin_n20 |
03-30-2024, 06:37 PM | #4 |
Rep 26
Do the stock fuel lines handle the E85? I see many kits sending full lines as well? Is it necessary to do this change?
Also awesome build, I've seen it a couple times and love it! |
04-04-2024, 11:40 AM | #5 |
Rep 1,066
Nonissues with 3+ years of running the fuel setup.
You can’t fit the b58tu HPFP without a custom fuel feed line. This video will show how the factory lines line up and thus a custom line is required. https://youtu.be/FqYYnmYffEk?si=l2xrdbk6wwwIlwkB
