01-31-2020, 09:08 PM | #507 |
Gettin It Figured Out
1820
Rep 2,669
Dorch Engineering S2 HPFP
Gotta love package delivery days!
Thank you Chris Dorch Engineering ! . .
02-01-2020, 06:40 AM | #508 | |
Rep 164
From the flow rates, does it look like it would be possible to run Full E85 with a stage 2 turbo?
2014 F30 335i xDrive 6MT - Pure Stage 2 GFB DV / Inlet | XDI-35 HPFP | Fuel-It PI w/ AIC and LPFP Upgrade | BM3 | Fabspeed Catted DP | Dinan axle back | VRSF Race FMIC/CP | Dinan CAI | KW V3 | Wiechers CF strut bar | Dinan ARB | Spec stage 2+ clutch SMFW | Full M Performance Interior | M Performance BBK | Vorsteiner VFF107 MPS4S | Jordan Tuned Full E85 - 558WHP/520TQ on Mustang Dyno
02-01-2020, 12:49 PM | #510 |
1296
Rep 3,533
Nope.. has nothing to do with it.
02-01-2020, 06:19 PM | #511 | ||
Rep 1,126
Can you elaborate? |
02-01-2020, 06:48 PM | #512 |
Rep 7,607
I think what he is getting at is that fuel flow will not be the limiting factor with pump gas. So getting a S2 HPFP is not going to provide you with any additional benefit over S1 HPFP with a pump gas (or even a race gas) tune for that matter. The primary reason to get S2 HPFP is for very high ethanol content (or any less energy dense fuel).
02-01-2020, 07:01 PM | #513 | |
1820
Rep 2,669
And Turbo.... .
02-02-2020, 09:07 AM | #514 |
Rep 282
M140i DP , OPF delete , MHD stg2 93oct , xhp stg3
02-02-2020, 01:11 PM | #515 | |
Rep 7,607
02-02-2020, 01:52 PM | #516 |
Rep 1,105
02-02-2020, 02:13 PM | #517 |
Rep 282
maybe a little background info ,
first of all this still a wip map that isnt finished ayou can see but to my own ignorance ive used the xhp and the sport and sport plus option incorrectly . for that reason the first revisions of thethanol map werent any faster than my 93oct maps . when i spoke with someone about it , he advised me to use xhp stg3 and sportplus but keep pressing the dsc button for another few seconds till its completly off . and that changed a whole lot of things . before that my best time with the ethanol map was a low 9 seconds for a 100-200 . then ive got an update and it did this 7.00 wgich was a as you president would say a yuuuuuuuge difference . so it the upcomming weeks i hope to see things get morr smooth in the logs . but the hdp6 has no problem pushing e30
02-02-2020, 04:26 PM | #518 | |
Rep 7,607
However can you clarify the underlined part? My understanding is that turning DSC off will result in the same settings regardless of what setting you initiate this from. In other words: Comfort mode --> hold dsc button --> DSC off is the same as sport + mode --> hold dsc button --> DSC off This is also consistent with the table that explains how the settings are affected in each mode (see below). Or are you talking about putting the tranmission into sport by moving the lever to the left? |
02-11-2020, 08:22 AM | #520 |
Rep 3,696
I just ordered Dorch Stage 1 for $999. Should be plenty of flow for my needs (more than XDI-35!)
I did see some BM3 guys were having to flash twice to get the Dorch HPFP to work correctly. I’m guessing that will get sorted out before I get around to installing my pump. |
02-11-2020, 08:32 AM | #521 | |
1820
Rep 2,669
Where did you see this? .
02-11-2020, 08:51 AM | #523 | |
1820
Rep 2,669
Found it, thank you 🍻 Worst case, I'll flash the 'Dorch Stock Tune' map Chris sent. I sent Chris Dorch my .BIN file...he added the calibration file and sent back to me. .
ZM22813.50 |
02-13-2020, 08:27 AM | #524 |
Rep 3,696
Hey guys, I asked this over in the M2 forum, but thought I’d ask here too bc of all the N55 expertise over here:
One reason I’m upgrading is so I can run a higher Emix year round and I don’t have to worry about HPFP drop outs when temps go below 60F. Are there any issues with running E45 year round if I only drive my car a couple times a week? What about if it’s been sitting outside when temps get below 30F? Regarding tune, would you expect the car to make any more power on the BM3 Stg 2 E30 map just by adding ethanol to E45? If not, any recommendations on the cheapest/easiest path to a custom tune that will add power in the meantime, before upgrading my Dinan turbo to a PS2 or something else? Thanks. |
02-13-2020, 11:04 AM | #526 |
Rep 153
ZM22813.50 Pray for Mojo429.50 |
02-13-2020, 11:08 AM | #527 | |
Rep 3,696
Otherwise, does a high Emix stay stable enough in the tank if only driving the car a couple times a week in the winter? |
02-13-2020, 11:30 AM | #528 |
Rep 142
Yes will be fine with that usage. It can sit for 2 months or more, I'd just want to have the tank nearly full or full to prevent condensation if just sitting for that length of time, which your car isn't in this scenario, but todays tanks are part of a sealed system, so usually no wories over water in them. You can add Stabil if want some more stability or some TCW3 2 stroke oil(1 once per 5 gallons gas) in there and also get gas stability and top end lube, as E85 is "dry" compared to gas.
ZM22813.50 |
