12-21-2020, 08:50 PM | #2267 | |
Rep 399
F20_M135i100.50 |
12-22-2020, 12:13 AM | #2268 | |
Rep 22
12-22-2020, 01:29 AM | #2269 | |
Rep 353
I installed dozens of these devices, sound was crystal clear in all cases without any noise. Some ppl said sound became even better than oem which is too optimistic I believe. Obviously AUX output cannot be better than oem digital, sound range and frequencies are better with the latter case, that's why ppl use USB DAC to obtain better sound from Android HU. |
12-22-2020, 01:38 AM | #2270 | |
Rep 551
SOUND RESTORER seems to restore the sound by switching from BMW OEM to ANDROID HU, and me it's the opposite, it's when I go from ANDROID HU to BMW OEM that the volume explodes in my ears and the sound quality becomes rotten (With GPS sound) |
12-22-2020, 01:52 AM | #2271 | |
Rep 22
12-22-2020, 02:16 AM | #2272 | |
Rep 353
If your OEM system is NBT normally sound doesn't require any AUX extension cable, you have sound right away. I had extra actions with AUX usually with CIC and CCC systems depending on OEM multimedia options. |
12-22-2020, 02:50 AM | #2273 | |
Rep 22
I bought it one year ago. My OEM system is NBT. EDIT: And here is a movie with this magic AUX noise: Last edited by krzysiek280; 12-22-2020 at 12:30 PM.. |
12-22-2020, 01:05 PM | #2274 |
Rep 168
12-22-2020, 01:36 PM | #2275 | ||
Rep 1,048
Unfortunately Swedish is no supported Language of the orignal KSW Software. What you can do is to edit the build your own Translation with editing english Strings with KswOverlay. For KswOverlay you will find the guides at the Theming Thread. I Uploaded you the full strings file here, so you can just copy it into the "values" folder of your KswOverlay then: kswplauncher_strings_258.zip The File can also be used for older OTA versions then 2.5.8. Kri |
12-23-2020, 03:54 AM | #2276 |
Rep 19
Bluetooth "Not activated" after update
Hi all, I have recently updated my head unit to android 10, using the v1.2.0 then v2.5.8 ota file. However, I had no luck in connecting my phone via bluetooth. It shows "Not activated" at the top right corner of the bluetooth page. I tried downgrading it to v2.3.6, but still, "Not activated" shows up and I cannot connect with my phone.
Does anyone know how to solve this problem? My MCU version is: 105242dLS-NBT-GTH-200103-B18 Thank you in advance. |
12-23-2020, 07:08 AM | #2277 | |
Rep 36
I something similar with the bluetooth settings. Once i connected the hu via wifi to my phone, it downloaded some updates and started working. Good luck |
12-23-2020, 08:20 AM | #2278 |
Rep 4
Regarding USB DAC set up,
Have you guys connected the DAC to the usb output of the HU? Did you use a USB extender for it to reach to the glove box or next to the armrest so the DAC can be place next to the AUX port? |
12-23-2020, 08:29 AM | #2279 | |
Rep 19
But for some reason the zlink app keeps connecting.... and I could never got into carplay. Did you have the same problem? Can anyone help? |
12-23-2020, 09:29 AM | #2280 |
Rep 36
12-24-2020, 01:10 AM | #2282 |
Rep 500
Just got my Navifly 12.4" pop up screen for F10. Would like to ask where to connect the front camera? I currently using aftermarket front and back camera with a third party box. Currently when the car is put into reverse, rear camera will activate with PDC info on the right hand side. When put into N or D, the camera will switch to front for 10s.
I would eliminate the box and connect the reverse and front camera directly to android box. Please advice for front camera, which connector should I use? The only one that logically make sense would be video 1 in. DVR video should be connected to DVR camera. Also, will it auto switch to front camera after I changed gear from R to D? Or I need to press certain button/icon to activate front camera? Last edited by pierreye; 12-24-2020 at 01:15 AM.. |
12-24-2020, 04:24 AM | #2283 | |
Rep 353
It should switch automatically when change R to D. It supposed to work with CVBS cams, not sure about AHD cams. Also one user reported that after firmware upgrade he lost the F-Cam functionality, so perhaps it works not on all FW versions. |
12-24-2020, 04:54 AM | #2284 | |
Rep 500
12-24-2020, 08:35 AM | #2285 | |||
Rep 19
12-24-2020, 09:49 AM | #2286 |
Rep 2
Why is the first boot screen like this?
It occurs randomly and is the same even though the MCU was updated as suggested by the seller. The APP is also updated to 2.5.8 https://youtu.be/mQZp__VzGl0 Last edited by park; 12-24-2020 at 10:31 AM.. |
12-24-2020, 10:29 AM | #2287 |
Rep 353
If the issue persists after the SW has been upgraded then it is highly likely the hardware issue, perhaps some screen micro-controller is out of order. Maybe it would be reasonable to return that defective HU and purchase another one.
12-24-2020, 10:37 AM | #2288 |
Rep 353
I didn't like the image quality of CVBS camera on HD screen (it was blurry), though it was just fine on my previous SD screen, also some annoying camera delay appeared. So then I swapped it to AHD camera which solved both issues.
